#7477 |
Drives: 4 wheels
I agree with hamwich. This system sounds great but I'm not a fan of the black or white use. It's either on or off unlike real turbos or SCs.
Not sure what the solution would be but it's definitely something that needs exploring. |
#7478 |
Lightning McQueen Driver
Drives: Limited Red 6MT BRZ
This has been beaten like a dead horse already. The system is fairly linear even with the on/off nature of the system. Also the system is controlled by both the controller and the switch... There's more then one way to skin a cat with this setup.
Installed Mods: Phantom Electric Super Charger | Open Flash Tune | Perrin OP/ HFC Front pipe | Invidia Q300 catback | ST Suspension | JDL Header | Flex Fuel |
#7479 | |
What don't you like about the on and off nature? Do you know why it is done this way?
#7480 | |
Drives: WR Blue BRZ, 240Z
Full throttle Electric Supercharger Build Thread
Telling someone that a product isn't commercially available IS helpful. You have a real attitude problem. But thanks for your constructive input. I'm enjoying my boosted BRZ. You?
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
#7481 | |
It was decided that picking different boost levels wasn't valuable because we are dealing with so little already...especially at redline...who wants to pick between 2psi or 1psi at redline? Also it obviously couldnt "crank up the boost" you always have the 5psi max to 2psi at redline. The only thing that I may ask Rob to try and integrate is a 2 switch engagement... If it is even possible...set the first switch at about 60 percent throttle and make it only run the compressor at half speed... Once it gets to 90 percent throttle it goes to 100 percent boost. This would help with the highway lower acceleration where you don't want to go WOT but you want to move faster than NA and realistically your car is already running in closed loop anyways. |
#7482 |
Also remember that I'm not running DR right now so I am missing that slight boost that Dr pulses give you in the above situation
#7483 |
Everyone just chill. These are all valid questions and although they have been asked before many times not everyone knows that as the thread is extremely long.
The reason nothing has been implemented yet is there is no easy solution. Any time you want to add boost outside of closed loop there is going to be a lot of tuning that needs to happen to make it run like stock. The awesome thing about the phantom is you have ALL of the driveability of stock but when you go WOT you just get a lot more power. This is akin to a small turbo spooling up...it feels absolutely great. Would it be great to have a fully fledged system that had modular boost... absolutely.....but running the system as a full time FI replacement is not possible....you would find yourself running the batteries down I would think. The other great thing is it is so simple the cost can stay down. Adding other things increases cost, increases complexity and also adds more things that can fail. This system is amazing for the money.... Will technology keep growing and the product get better? Absolutely....this is the first stab at the system and its been pretty swell so far. It was only a year and a bit ago I was getting .8 to .9 psi at redline....today with my experimental system I am getting 3 to 3.2.. .yes its using more power and won't run for as long on the batteries but its still damn exciting stuff. ![]() Thanks for everyone's continued discussion and interest in the product....should be stopping by robs in the next couple days for a chat ... Will let you know if I hear anything about the orders. |
#7484 | ||||||||||||||
You know you want it.
Drives: '13 FR-S
Interestingly enough, this was my first impression of you. Unfortunately as you've continued to interact with me, I suspect you might have another problem entirely. In light of this, I'm going to address this problem by giving you a bit of a breakdown of past events. This might go a long way into alleviating your confusion! Let's check out my first post... Quote:
For the sake of comparison let's see what Fenton wrote for an example of a reply done right! Quote:
Now, let's take a look at your first response to me! Quote:
There are a few problems here, let's REALLY break it down! At absolutely no point in that first message did I contest this. Again, at no point did I contest that it even worked well! Quote:
This explains my comment... Quote:
This finally brings us to... Quote:
So here we are at the end at last. It's been a long journey, but we made it together. We've learned a lot during this trial. Such as how, in my post there, I totally didn't suggest or wish for a different control method, and how what I actually did was ask fenton if a different control method was ever used, and how we learned that yes in fact a more advanced setup was experimented with, and we laughed and cried at what wonderful memories we shared. We also learned a little bit about ourselves and how maybe, when someone asks a question about a product we own, we should take some time and actually read what they have to say instead of assuming QUESTIONS=BAD. We know that while we get passionate about the products we own and enjoy, we can keep an open mind and not overreact just because someone may want to know more or has a concern. Afterall, we're just here to have fun and learn, right guys? There we go, something positive to say at last!
The Following User _________ Stay_Puft(09-13-2014) Says Thank You to MmmHamSandwich For This Useful Post: |
#7485 | |
Drives: '13 FR-S
Such an arrangement may be possible without utilizing a true brushless electronic speed control. While it would be neat to integrate one into this system, it would probably raise costs a non insignificant amount, add a considerable point a failure, and there probably wouldn't be a large benefit. Hobbyists do indeed use ESC's in model aircraft that can support these kinds of loads, but they're generally well cooled and not exposed to inclement weather among other technical difficulties. Would be an interesting idea for a test model just to see what it does.
#7486 |
Drives: FR-S,GTI
Geez
I don't understand all this talk about a different much more complicated method than the on-off switch. I have no problem with the system just as it is. No changes need to be made. It works perfectly the way it is. Not to say more boost wouldn't be nice. But I'm perfectly happy with what I have. In fact I feel honored to be one of the early adopters. |
#7487 |
Drives: DGM BRZ 6MT
I love the on-off nature of the ESC. If I really want to accelerate and pass someone on the highway, I just let my car breathe and go WOT.
There's just not enough boost for it to be useful at half speed at the moment. I would rather save all of my battery for the full boost at WOT rather than to have it being drained to power it at half speed. If you want to accelerate, why only use it at half-boost? Sent from my iPhone using Tapatalk
#7488 |
Drives: FR-S,GTI
I agree completely.
#7489 | |
Drives: 2013 FR-S Argento
#7490 |
Go-Kart Enthusiast
Drives: Toyota Scion FRS
I'm still waiting for the post when one calls the other a doo doo head.
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels |
| Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 04:45 PM |
| Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 06:43 PM |
| 86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 07:07 AM |
