#729 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
http://www.cosworthperformance.com/
Discovered this! Should help anyone interested in Cosworth parts
#730 |
Drives: GT86
Guys Hope you can help,
Coolant for the supercharger just the same blue stuff toyota/subaru use from factory in OEM coolant system? |
#731 |
Drives: GT86 Cosworth
Just need to be standard ethylene glycol mix but the subaru blue should be fine. If you are topping it up, you should check whats in there already. Being in the uk I was ut fitted at fensport? They use the subaru blue i think.
#732 | |
Drives: GT86
It also do look blue in colour. My OEM system needs topped up and just got a 1 ltr bottle (blue) i was going to top the the supercharger coolant as well. You think it will be ok? |
#733 |
Id double check with fensport but im fairly sure they use the same stuff.
#734 |
Drives: GT86
#735 |
Drives: blue - Cosworth SC stage 3.0
Adrian is correct we recommend any ethylene glycol mix so the standard Subaru blue is fine
1 minor point though is the performance of the intercoolers will be slightly better with a milder mix, so 25% anti-freeze to water gives a slight improvement in heat transfer compared to the 50/50 mix |
#736 | |
Drives: GT86
#737 | |
Drives: 2016 Cosworth 2.2 BRZ
#738 | |
#739 |
Drives: 10 series fr-s
I shortened the length of the pcv hose and my 2.3 kit idles much smoother
#740 |
Please elaborate on this
#741 |
The hose from the block to the left side of the throttle body. I made the path as direct as possible. The hose i had was about 8 inches too long and was looped. The idle at start up levels out much faster. For the first time after 15k i feel the true refinement in the stock tune. I did this as a result of getting a lean on bank one at idle. I could still have a leak in the system somewhere, ill be checking that soon. No fault codes so far 3 days in.
#742 |
Interesting. I'll have to see how mine looks. I did have a running lean issue, but got that tweaked by Matt a while back. Though I don't know if that has anything to do with what yours was caused by.
| Jackson Racing Supercharger Owners Thread | enivid | Forced Induction | 6049 | 06-25-2026 10:40 PM |
| Kraftwerks Supercharger Owners Thread | projek_01 | Forced Induction | 4310 | 04-07-2025 01:12 PM |
| HKS Supercharger owners thread | wbradley | Forced Induction | 1054 | 10-26-2024 01:18 PM |
| Phantom FTS Electric Supercharger Owners Thread | TM | Forced Induction | 1206 | 12-15-2019 02:33 PM |
| Supercharger Kits! Vortech/Cosworth | RallySport Direct | Forced Induction | 61 | 06-29-2015 11:26 AM |
