Old 02-10-2017, 11:48 PM   #729
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
http://www.cosworthperformance.com/
Discovered this! Should help anyone interested in Cosworth parts
MS, CSCS, TSAC-F, CPT
The Following 2 Users Say Thank You to weederr33 For This Useful Post:
Insurme1 (02-20-2017), sly (02-24-2017)
Old 02-24-2017, 02:47 PM   #730
BRZUK
Drives: GT86
Guys Hope you can help,
Coolant for the supercharger just the same blue stuff toyota/subaru use from factory in OEM coolant system?
BRZUK is offline   Reply With Quote
Old 02-24-2017, 02:49 PM   #731
ajc209
Drives: GT86 Cosworth
Just need to be standard ethylene glycol mix but the subaru blue should be fine. If you are topping it up, you should check whats in there already. Being in the uk I was ut fitted at fensport? They use the subaru blue i think.
ajc209 is offline   Reply With Quote
Old 02-24-2017, 02:59 PM   #732
BRZUK
Drives: GT86
Yea Buddy it was fitted at fensport it just down by about 2".
It also do look blue in colour.
My OEM system needs topped up and just got a 1 ltr bottle (blue) i was going to top the the supercharger coolant as well. You think it will be ok?
Old 02-24-2017, 03:07 PM   #733
ajc209
Id double check with fensport but im fairly sure they use the same stuff.
The Following User Says Thank You to ajc209 For This Useful Post:
BRZUK (02-24-2017)
Old 02-24-2017, 03:10 PM   #734
BRZUK
Drives: GT86
Thanks Buddy
Old 02-24-2017, 03:13 PM   #735
Matt@Cosworth
Drives: blue - Cosworth SC stage 3.0
Adrian is correct we recommend any ethylene glycol mix so the standard Subaru blue is fine
1 minor point though is the performance of the intercoolers will be slightly better with a milder mix, so 25% anti-freeze to water gives a slight improvement in heat transfer compared to the 50/50 mix
Matt@Cosworth is offline   Reply With Quote
The Following 2 Users Say Thank You to Matt@Cosworth For This Useful Post:
BRZUK (02-24-2017), Insurme1 (02-27-2017)
Old 02-24-2017, 05:33 PM   #736
BRZUK
Drives: GT86
Thank you very much Matt, appreciate it will add slightly more water.
Old 02-25-2017, 12:24 AM   #737
sly
sly's Avatar
Drives: 2016 Cosworth 2.2 BRZ
That's awesome. Noticed they now have a 2015 WRX intake. http://cosworthperformance.com/part/...-15-subaru-wrx I've been waiting eagerly to put Cosworth parts on my WRX. Any chance @Matt@Cosworth that you will be offering a tune for the 2015+ WRX soon?
sly is offline   Reply With Quote
Old 02-25-2017, 12:41 AM   #738
weederr33
weederr33's Avatar
Yup! Also today RallySport Direct did a live stream with Cosworth about upcoming things for the FA20 motor such as forged internals (both WRX & Twins) and other topics. It's on their Facebook. Cool fact: Rick from RSD answered one of my questions!
The Following User Says Thank You to weederr33 For This Useful Post:
Old 02-28-2017, 06:17 PM   #739
TxFrs10
TxFrs10's Avatar
Drives: 10 series fr-s
I shortened the length of the pcv hose and my 2.3 kit idles much smoother
TxFrs10 is offline   Reply With Quote
The Following User Says Thank You to TxFrs10 For This Useful Post:
weederr33 (02-28-2017)
Old 02-28-2017, 06:35 PM   #740
weederr33
weederr33's Avatar
Please elaborate on this
Old 02-28-2017, 08:38 PM   #741
TxFrs10
TxFrs10's Avatar
The hose from the block to the left side of the throttle body. I made the path as direct as possible. The hose i had was about 8 inches too long and was looped. The idle at start up levels out much faster. For the first time after 15k i feel the true refinement in the stock tune. I did this as a result of getting a lean on bank one at idle. I could still have a leak in the system somewhere, ill be checking that soon. No fault codes so far 3 days in.
Old 02-28-2017, 08:52 PM   #742
weederr33
weederr33's Avatar
Interesting. I'll have to see how mine looks. I did have a running lean issue, but got that tweaked by Matt a while back. Though I don't know if that has anything to do with what yours was caused by.
Jackson Racing Supercharger Owners Thread enivid Forced Induction 6041 11-28-2025 08:08 AM
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 01:12 PM
HKS Supercharger owners thread wbradley Forced Induction 1054 10-26-2024 01:18 PM
Phantom FTS Electric Supercharger Owners Thread TM Forced Induction 1206 12-15-2019 02:33 PM
Supercharger Kits! Vortech/Cosworth RallySport Direct Forced Induction 61 06-29-2015 11:26 AM
