Old 01-03-2018, 01:57 PM   #729
Chamaco
Drives: Silver FR-S
Originally Posted by Teseo View Post
Quien te va hacer el tuneo?
going with Ruben from Dynocenter. Hope to have him back soon (according to him he'll be back on 13 of january) in the island after his shop got torn apart by Hurricane Maria. I'll post back with number once all of it is said and done.
Chamaco is offline   Reply With Quote
The Following User Says Thank You to Chamaco For This Useful Post:
Teseo (01-03-2018)
Old 01-12-2018, 01:12 AM   #730
FunnyGopher
Drives: 2015 BRZ Limited
I have successfully installed my Ace header and front pipe, and flashed my car with the CSG Delicious tune, and it's amazing. There's so much power up top. There's no immediate acceleration from a stop, but up top, holy cow.
The pedal range is so much wider on the tune than from stock, so initially, what I thought would be WOT was actually just 30% throttle or something. I initially thought the tune was way wrong, or something was off, because I wasn't pressing the pedal far enough to give any significant amount of gas to the car. Haha, a little embarrassing, but I'm glad I learned, because the car just goes now.
There's a club dyno day coming up, so I'll post results after that happens.
Harrop Supercharger | Delicious Tuning Flex Fuel Kit | ACE Type-A 350 Header + OP | CSG Touring 86 Catback | RacerX Fabrication Catch Can | Jackson Racing Dual Radiator/Oil Cooler | Tuned by Zach from CSG
FunnyGopher is offline   Reply With Quote
The Following 2 Users Say Thank You to FunnyGopher For This Useful Post:
CSG Mike (01-12-2018), ThatAsianBradah (01-12-2018)
Old 01-12-2018, 10:04 AM   #731
nico_rsx
Drives: BRZ 2017 Pure Red, MT
Hi, can you explain what you meant by the pedal range change? Does the delicious tune change the throttle pedal response/scaling? Also does it have an impact on the throttle delay (increased/decreased, or no impact)?
Thanks
nico_rsx is offline   Reply With Quote
Old 01-12-2018, 11:42 AM   #732
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
With Ecutek when you flash the vehicle the gas pedal has to relearn positioning basically but usually after the first 15 minutes you should be good to go. So right after you flash you will notice that you're having to use more gas to get the same effect before the tune, it's not permanent and it goes away.
Trueweltall is offline   Reply With Quote
The Following 2 Users Say Thank You to Trueweltall For This Useful Post:
nico_rsx (01-12-2018), strat61caster (01-12-2018)
Old 01-12-2018, 12:07 PM   #733
nico_rsx
Thanks, usefull to know.
Do you know if the same thing happens when you unplug the battery?
Old 01-12-2018, 12:09 PM   #734
Trueweltall
I'm not too sure about that, I have yet to unplug mine.
Old 01-13-2018, 02:31 AM   #735
RJasonKlein
RJasonKlein's Avatar
Just an FYI - you can recalibrate the drive-by-wire accelerator pedal sensor by putting the ignition switch in the on position without the car running and slowing cycling the accelerator pedal through its full range of motion 20 times. This essentially forces the ECU to go through a re-learn throttle sequence.
RJasonKlein is offline   Reply With Quote
Old 01-13-2018, 05:09 PM   #736
steve99
Any time ecu is flashedwith new tune, with any tune system ecutek tactrix oft kess it will reset all the ecu learned parameters in RAM memory, same thing happens if the power is completly removed from ecu ie battery terminal removed. Their is a whole bunch of stuff learned like fuel trims knock control, throttle calibration cam calibration.
Its important to let the car idle for a least a minute after reflash\reset to let ecu do its thing, the ecu continuously learnes and adjysts these parameters, you just notice it more during the initial phase as everyting was set to default
Old 01-14-2018, 05:04 PM   #737
FunnyGopher
Thanks
The pedal position has nothing to do with the time after flashing the tune in the case I'm talking about. The tune has the pedal position set up to be at WOT at 80.4% pedal position. The stock tune is WOT something around 40%. Having a wide pedal range makes it easier to be more precise with the gas. I'm actually liking it more and more every time I drive the car.
Throttle delay would only be caused by the driver not slamming the pedal to the floor fast enough. After getting used to the full range of the pedal, this is no longer a problem. I can give it precisely as much gas as I want, when I want.
The Following User Says Thank You to FunnyGopher For This Useful Post:
nico_rsx (01-14-2018)
Old 01-14-2018, 05:07 PM   #738
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
This is how our cars should be. You need to have a motive to rev this engine.
Old 01-14-2018, 10:43 PM   #739
nico_rsx
Maybe with the 2017 the pedal scaling is different, because I verified that with the Torque app, and for the electronic throttle body to be 100% open, the pedal need to be physically around 90%. The 90% is an approximation of pedal travel before hitting the stopper, because when the pedal is on the stopper, there is still a lot of travel left (I saw that when I removed the pedal to installed a spacer).
Old 01-15-2018, 12:58 AM   #740
FunnyGopher
Hmmm, interesting. I don't know about the '17s. I have a '15, and the info I shared was the info Delicious shared with me. If you're pedal needs to be at 90% to be WOT, then I imagine the pedal scaling on the tune will feel right at home.
Old 01-15-2018, 01:07 AM   #741
FunnyGopher
Oh, I have a motive now, and it's addicting.
Old 01-15-2018, 06:07 AM   #742
Kodename47
Kodename47's Avatar
Drives: UK GT86
It varies with RPM. However 40% is an exaggeration, actual WOT won't be achieved until ~85% pedal. That's me just looking up the pedal mapping. However it's definitely not linear and at lower RPM you get more throttle angle per pedal degree.
.: Stealth 86 :.
Kodename 47 DJ:
nsfwseriouslythisisporn
[REQ]BRZ Independent Fog Lights 1stGenBRZ86 DIY (Do-It-Yourself) Guides 3 04-17-2016 06:34 PM
What do I need for an independent tuner.. Shady195 Software Tuning 2 07-23-2014 09:04 PM
Subaru BRZ/Scion FR-S UEL Header by JDL -- Testing by Moto-East JPxM0Dz BRZ Photos, Videos, Wallpapers, Gallery Forum 13 05-08-2014 08:06 PM
Vortech Finale Review Video | Track Testing | Part 4 of 4 Dezoris Forced Induction 75 04-12-2014 12:45 PM
The Independent Review: Toyota GT86 Boxer-4 Scion FR-S / Toyota 86 GT86 General Forum 31 01-09-2012 06:22 PM
