#729 | |
Drives: Sonic Blue 86GT Manual
#730 |
Drives: 2013 raven black fr-s
very sexy look and sound, but I'm still looking forward to getting turbo'd. I would love to see this thing in real life though. It's becoming more of a unicorn project at this point haha
#731 | |
Drives: A lot of supercars.
Heres a senior's members (2forme) dyno NA Stock with SRT exhaust/e85 tuned. |
#732 |
Drives: 13' SSM BRZ
looks incrediably simpler to install than some of the turbo kits out there...
#733 |
That Guy
Drives: 2013 asphalt FRS MT
#734 | |
I Love custom Turbo kits
Drives: Limited BRZ
Torque is the measure of force and I understand why some people say that's the only thing they care about. NOW, looking at horsepower and understanding its meaning you can deduct what is torque doing given any RPM range. If you see HP curve flattening out, that's not good, you are loosing torque. If you see HP curve rapidly increasing, that is good most probably your torque is increasing. If HP curve is increasing, but not at a big rate, most probably your torque flattened out which is not bad as long as it is a healthy high number. So even though Torque is the most important number, you can get a good idea of what torque is like if you have a curve. In the below graph, TQ is pretty much flat, that is why you see an increasing HP curve (sine the HP equation depends on TQ and RPM, if you keep TQ constant but increase RPM at a linear rate, the HP will increase linearly). ![]() In the other hand, in the below plot you see the TQ mostly flat up to 5000 RPM and HP curve increasing mostly linearly. Then at 5K RPM, TQ falls off. Again, since the HP equation depends on TQ and RPM, the RPM keeps increasing but TQ starts to decrease. This causes the HP curve to start leveling out and even decrease. That is what I meant, looking at the HP curve you can at least have an idea of what the TQ curve is doing. ![]() Disclaimer: Of course none of this works with just the peak HP, but it is no good either if you only have peak TQ, you need to see the curve to be able to tell how good does a system perform.
#735 | |
That Guy
| The Following User Says Thank You to Calum For This Useful Post: | Sportsguy83 (12-30-2012) |
#736 |
This is true in theory, but keep in mound that there are other anomalies that can cause these numbers to deviate from the norm
#737 |
That Guy
Could you elaborate a little farther? Are you saying that real world conditions can allow horsepower to not equal torque at 5252 rpm. Or that horsepower could be higher then torque below 5252 rpm? If so, you're wrong.
#738 | |
The 5252 never changes, as this is a constant (unless you are factoring in parasitic losses in the particular system), but the tq and hp numbers are derived from each other. However, the amount of tq required to reach a certain hp number is derived from the RPMs. |
#739 |
That Guy
So, horsepower varies directly with both torque and rpm.
#740 |
Drives: waiting on a 2021...
You guys have to remember that the only thing a dyno measures is torque. Horsepower is mathematically derived from the torque measurement. That's why the horsepower & torque will always be the same at 5252 RPM. Horsepower is just torque over a certain period of time.
#741 |
Correct, I was just stating that tq being measured at different rpm levels will yield varying results. TQ and HP are only varying factors when you remove the variable for RPM and keep this number at a constant rate, which in this case is what I think you guys were doing (which can make sense).
I always just like to let people know that if you are calculating TQ and HP, numbers may vary, based on the RPM number you are using. |
#742 |
Drives: FR-S 6MT Ultramarine (BeeDrill)
Most straightforward way to put it:
HP = Torque * RPM . . . . . 5252
2013 Scion FR-S - Ultramarine 6MT
| The Following 3 Users Say Thank You to A5D5TRYR For This Useful Post: |
| ***Recaro / Racetech / OMP / STATUS / Defi / Apexi / HKS / Innovate / AEM / Cobb***** | Touge Factory | Interior Parts (Incl. Lighting) | 9 | 11-29-2012 03:13 PM |
| lost screw for sensor intake | Mr.Jay | Engine, Exhaust, Transmission | 5 | 10-21-2012 10:26 PM |
| Lowest Prices on all Gauges and Electronics! Defi|STRI|AEM|INNOVATE+More | Rev Works | Audio/Visual, Electronics, Infotainment, NAV | 28 | 10-09-2012 06:04 PM |
| Innovate Wideband Air/Fuel Ratio LC-1 Wideband Kit **Special Price** | Titanmotorsports | Audio/Visual, Electronics, Infotainment, NAV | 2 | 09-14-2012 01:42 PM |
| Missing rubber piece for intake screw | ngabdala | Engine, Exhaust, Transmission | 1 | 08-31-2012 07:10 AM |
