#715 |
Drives: Sterling BRZ Ltd
Its a 30 degree fixed angle, snow will slide off to the right. Doesn't show in that pic to well. Since I'm just looking for something better then a shovel for my own driveway I decided right side works best.
#716 |
For info purposes the plow truck is a 6.2L F250
#717 |
Drives: 2013 Ultramarine FR-S
#718 |
![]() The bolt on the bottom mount on the blade can be adjusted to change the attack angle of the blade.
#719 |
Klaatu barada nikto
Drives: Raven FR-S MT
Ok... Someone needs to photoshop that.
(Sorry, off topic... Back to the awesome fabrication work.)
I vow to do no harm. 2013 Raven FR-S Manual "Lenore" 1985 Silver RX-7 GSL-SE (Gone and missed) |
#720 |
Plow is just about done
#721 |
Drives: FRS
that must be so awesome to have the skills and equipment to fabricate stuff. man if that were me, id just be making shit all day everyday lol
#722 | |
Drives: 2016 Oceanic, "base" model
I too like to read/watch mrk1's posts and see all the stuff he builds... |
#723 | |
All this needs to do is be better then shoveling.
#724 |
In more turbo related fabrication news, I had a T3 billet merge made up. Should open up turbo selection. The housing shown is from a 50 Trim T04E, maybe I'll give that a try. Element Tuning seems to like there T04E be it the slightly bigger 60 trim.
#725 |
Little side work, Ferrari 355 timing belt. Motor and Trans need to come out.
#726 | |
Proud of BOXER
Drives: Subaru Boxer
Might as well replace the known flawed OEM manifolds while it's out, if you haven't already.
#727 |
This car has a pretty solid service history, I'm not sure if these are the originals or not.
#728 |
T04E 50 Trim for the T3 manifold, solid performing journal bearing turbo. Little more flow capacity then the 28RS.
| AMR Performance: How to remove the factory bumper (walk-through images inside) | AMR | Engine, Exhaust, Transmission | 9 | 04-10-2013 07:45 PM |
| 86 Modelista walk around and GT Limited | SoCal_86 | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 04-24-2012 11:53 AM |
