Old 12-05-2017, 11:41 AM   #715
Imp
Bring out your dead
Drives: '14 BRZ (SSC), '00 S2000
Yeah, that shows up on google maps as closed. I should be going through the area around 6-7pm if all goes well, which is just after peak. The way I look at it when I drive far distances is "it is what it is".
I'll be watching traffic on Waze as I approach and have a few options, best being take 36E to the new St Croix crossing (staying north of the City) and head south on 39 by the docks for a few miles until picking up 94 again. If the city is jammed, then probably head south around on 494. At least there are lots of options in addition to those 2.
Using googlemaps is ineffective now, though, because people are trying to remember how to drive in the snow again after the summer.
--kC
Imp is offline   Reply With Quote
Old 12-05-2017, 07:29 PM   #716
iLuveKetchup
My VTEC fluid is full
iLuveKetchup's Avatar
Drives: EFF JAY
Legal to weld the eccentric bolts/washers on the rear LCA? Asking for a friend..
iLuveKetchup is offline   Reply With Quote
Old 12-05-2017, 10:11 PM   #717
Imp
Bring out your dead
Probably not. Why? Do they keep adjusting on their own? I don't think some loctite Blue would be out of the realm though.
Old 12-05-2017, 10:26 PM   #718
iLuveKetchup
Drives: EFF JAY
Rear camber has moves like Jagger.
Old 12-06-2017, 12:59 AM   #719
ka-t_240
I would guess not. I have had the SPC arms for 2-3 years. No issues with them moving. Car sees probably 15 autox events a year and 10 track days a year and I use the curbs.
ka-t_240 is offline   Reply With Quote
Old 12-06-2017, 08:21 AM   #720
Imp
Bring out your dead
Two other suggestions:
1) Torque them more.
2) Paint a line on bolt and surface once you know it's aligned right. Then at events - check it. If it's moved, you know where it needs to go back to. I used to do this on my RX8. I had 2 lines. One for autox, and one for daily driving.
--kC
The Following User Says Thank You to Imp For This Useful Post:
Shark_Bait88 (12-06-2017)
Old 12-06-2017, 11:17 AM   #721
iLuveKetchup
Drives: EFF JAY
So the rear camber never deviated from your alignment setting? Stays perfect i.e. -1.5 after 2-3 years? How many times are you checking?
--kC
1) It still moves.
2) yes I do this but it's more of guess work.
I'm going to take the initiative and weld.
Old 12-06-2017, 11:54 AM   #722
Imp
Bring out your dead
Adding paint or a mark should remove any guesswork (and if you're within a 1/16 left or right from the mark, the effect will be unnoticeable/negligible when driving - whereas toe that much would be). How much does it move???
--kC
Old 12-06-2017, 12:10 PM   #723
Twinz
Twinz's Avatar
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
There is A LOT of cross-talk between the camber and toe on the back of this thing. I marked mine, but I'm pretty sure the car won't drive straight if the camber moves. (Because I expect it to jack up the toe if/when it moves)
Twinz is offline   Reply With Quote
Old 12-06-2017, 01:05 PM   #724
Imp
Bring out your dead
Like I said, I would avoid doing that unless you've exhausted all other resources, because it's not legal for competition in Solo.
That said, I just want to be sure, as I haven't yet installed or even looked at the underneath of these cars to get familiar with setup...
The eccentrics, are they part of the SPC arms? I mentioned this issue you brought up on another forum, and someone said (about the arms) "if they're the bolts factory says 150, their alignment guy did 180 and they haven't moved."
I wouldn't weld unless you've exhausted all other resources. You don't wanna do it only to find out your out of compliance (and then have to buy new parts).
--kC
Old 12-06-2017, 01:06 PM   #725
Imp
Bring out your dead
So on the rear, adjusting camber effects toe? Not separate? (Looking at parts install now... I guess so... hmmm)
--kC
Old 12-06-2017, 01:12 PM   #726
Twinz
Twinz's Avatar
--kC
Front isn't bad in that regard. I picked up more than a degree of camber and my front toe was almost unchanged. The back is a PITA though.
Old 12-06-2017, 01:41 PM   #727
Imp
Bring out your dead
Did you try without the "new" toe arm bushing in the rear? Or did you put both on at the same time?
This adjustable control arm kit is designed to replace the rear lower control arm. A new offset toe arm bushing is included with this kit. Toe bushing installation is not required if desired rear camber and toe can be achieved with the stock toe adjuster. A complete bolt-in rear toe adjusting arm, #67655 is available for easier toe adjustment if desired.
That reads to me that you don't have to run it if you can still get the range you want in the rear with the stock stuff.
--kC
Old 12-06-2017, 01:45 PM   #728
iLuveKetchup
Drives: EFF JAY
--kC
That bushing is not used. It is for the OEM LCA which you are removing in place of the SPC LCA.
Upgrading brakes on the lower spec GT86 (the standard spec outside of US market) OnionTou Suspension | Chassis | Brakes -- Sponsored by 949 Racing 55 07-01-2016 02:36 AM
what's the difference between twin screw, centrifugal, single turbo and twin turbo? warplane95 Forced Induction 86 04-17-2014 03:36 PM
my twin RWDGUY Mid-Atlantic 2 04-08-2013 10:23 PM
JDM Spec-C V9 Twin Scroll VF36 complete Nico TURBO Engine, Exhaust, Bolt-Ons 0 12-05-2012 12:20 PM
