09-02-2020, 02:34 PM | #72325 | |
Drives: Subaru BRZ
09-02-2020, 03:22 PM | #72326 | |
Sent from my SM-G975U using Tapatalk |
09-02-2020, 04:04 PM | #72327 |
Drives: Mazdarati
Like Madonna. Like Lourdes (AKA like mother like daughter)
The Following User Says Thank You to IceFyre13th For This Useful Post: | p1l0t (09-02-2020) |
09-02-2020, 05:24 PM | #72328 | |
The Following User Says Thank You to Tcoat For This Useful Post: | Spuds (09-02-2020) |
09-02-2020, 05:40 PM | #72329 |
The Dictater
Drives: '13 Red Scion FRS
The Following User Says Thank You to Spuds For This Useful Post: | soundman98 (09-02-2020) |
09-02-2020, 06:47 PM | #72330 | |
Anybody in here smart with OBD connectors?
I'm super confused. So when I was tuned on Ecutek last year, one of their recommendations was that if you plan to use the Ecutek Connect BT OBD plug then you should get an OBD extension, otherwise the plug isn't guaranteed to work all the time. I noticed this to be true if I had the Connect plugged in directly, there were times that it would power on but the data connection seemed faulty. But every time I plugged it into an extension first and the extension into the OBD plug it worked fine. Then the issue from last week came up with that P3 Gauge, where when it's plugged directly into the OBD port it works completely fine every time. But I tried 3 different OBD splitters plugged directly into the OBD port first, and none of them worked. Until... I tried daisy-chaining by plugging my OBD extension into the port first, the splitter into the extension, and then the P3 into the splitter. This daisy-chain works fine but gives me a metric shit ton of cables to figure out how to secure. I know I've heard our OBD port can be faulty but I don't get this. What does the extension do differently here to work more consistently?
Instagram: @spike.brz
09-02-2020, 08:23 PM | #72331 | |
The Dictater
We really take consumer electronics for granted these days, forgetting that a shit ton of work and testing went into the standards and interface hardware that lets most products be mostly idiot-proof. |
The Following User Says Thank You to Spuds For This Useful Post: | spike021 (09-03-2020) |
09-02-2020, 08:27 PM | #72332 |
Drives: Crapcan
Sometimes I hate taking time off work. I will probably be here till 9 tonight making sure shit gets done so I don't have to rely on someone else when I am not here tomorrow.
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post: |
09-02-2020, 08:46 PM | #72333 |
chicken tonight
The factory connector isn't designed for frequent connect-disconnect cycles. Using an extension moves the eventual failure mode to a relatively inexpensive replaceable part. My extension has held up well. I have it glued into the little box in front of the gearshift.
09-02-2020, 09:19 PM | #72335 | |
The Dictater
The Following 2 Users Say Thank You to Spuds For This Useful Post: | NoHaveMSG (09-02-2020), Ultramaroon (09-02-2020) |
09-02-2020, 09:47 PM | #72336 |
The Following 3 Users Say Thank You to humfrz For This Useful Post: |
09-02-2020, 09:49 PM | #72337 |
09-02-2020, 10:24 PM | #72338 |
The Dictater
The Following 3 Users Say Thank You to Spuds For This Useful Post: |
Similar Threads | ||||
Language Rant Part Deux | MuseChaser | Off-Topic Lounge [WARNING: NO POLITICS] | 43 | 04-23-2017 07:55 PM |
Random thoughts thread | MrVito | Off-Topic Lounge [WARNING: NO POLITICS] | 37188 | 02-25-2016 10:00 AM |
Random Rubber Part | OoLong | BRZ First-Gen (2012+) -- General Topics | 8 | 01-28-2014 10:31 AM |
Crew Carshow : Part Deux 9/7/13 | saiyajinimports | Great Lakes | 0 | 08-17-2013 05:18 AM |
