Old 12-08-2017, 05:05 PM   #701
Grady
Grady's Avatar
Originally Posted by sales@delicioustuning.com View Post
Working on cooking up some updates for you all with the upcoming RaceROM release...should be yuge!
-Zach
Just ordered my tune for the AVO yesterday! I better get the updates when they come out
Old 02-09-2018, 04:54 PM   #702
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Small update! Still waiting for the official Phase 10 RaceROM release from EcuTek, but we are starting to test beta versions on in house vehicles.
In other news, we have come up with updated forced induction tunes for 2017+ model years. These updates include optimized VVT, ignition advance, fueling, and sensor scaling specific to the facelifted vehicles. This applies to both manual and automatic transmission versions. Only tunes ordered after 2/1/18 have the updates applied in the initial tune revision, otherwise the standard $75 fee to update the tune applies here.
- Zach
Old 04-18-2018, 07:44 PM   #703
DeliciousTuning
Update: Phase 10 RaceROM has not yet seen a full release for model years newer than 2013/2014, but we have a separate update to the Flash & Go, Edelbrock, Harrop, & Jackson specific tunes.
The latest version is denoted as V23.00, and improvements are as follows:
- Improved midrange throttle response
- Finer control over closed loop fueling control during high load conditions
- Improved power delivery in Flex Fuel Tunes
- *Much* quieter EBCS operation on turbo specific Flash & Go tunes
- Improved drivability across all versions
Updates to the latest versions are the standard $75 fee. If you have any questions, feel free to contact me via email at sales@delicioustuning.com.com.
Old 04-18-2018, 07:59 PM   #704
gahooligan
Drives: 2017 BRZ Premium
I will state for the record Zach and the FI tunes are absolutely awesome! Great people, awesome service and value! Car runs and tracks great!
Sent from my SM-N950U using Tapatalk
gahooligan is offline   Reply With Quote
Old 04-18-2018, 08:12 PM   #705
DeliciousTuning
I appreciate the compliment!
I try to give each vehicle and its tune the same level of attention and care that I would give my own car. It helps when you love what you do!
-Zach
Old 05-28-2018, 09:27 PM   #706
frscory
frscory's Avatar
Drives: 2013 scion frs firestorm red
RaceROM features
Im sure this has already been asked/answered but do I need to have the RaceROM add on in order to take advantage of the features you guys offer in your flash and go tune? thank you
frscory is offline   Reply With Quote
Old 05-29-2018, 12:33 PM   #707
Kodename47
Kodename47's Avatar
Drives: UK GT86
No
.: Stealth 86 :.
Kodename 47 DJ:
Old 05-29-2018, 03:59 PM   #708
paiceyfan
paiceyfan's Avatar
Drives: 2014 Porsche Cayman S
Zach,
I have been having throttle issues with the Edelbrock tune (v21, I believe) from the beginning, which is nearly 18 months now. Do you think the v23 will improve on this, or is it unrelated. You can read my issues in the current Edelbrock thread.
Thanks.
It's not speed or the attention that matters, it is that unexplainable moment when man and machine become one! At that time, nothing else exists except the path before you.
paiceyfan is offline   Reply With Quote
Old 06-11-2018, 03:47 PM   #709
paiceyfan
paiceyfan's Avatar
Anyone here have throttle response issues and moved to version 23 with a Edelbrock, but stock otherwise? If so, any changes?
Thanks.
Old 07-05-2018, 03:29 PM   #710
DeliciousTuning
RaceROM 10 Released!
Big Update Folks: Phase 10 RaceROM is finally here for all model years and all regions of the world, from 2013-2018 models on USDM, European, Asian, JDM (Yes it's different), and Gulf spec ECU's. Our entire tune library has been updated to accommodate the new software, and we are now rolling out these tunes to new and existing customers.
The latest version is denoted as V25.00. Though RaceROM 10 is really a complete and utter overhaul of the way we do tuning on these cars, some of the more important changes are as follows:
- Improved tip in throttle response throughout entire rev range
- Completely overhauled closed loop correction outside of factory closed loop scenarios
- Completely overhauled boost control on turbo systems, implementing a variety of fail safe and target compensations to correct for and protect against overheating oil/coolant, poor quality fuel, AVCS being inactive, and more. We also have a lot more adjustment room to have features like boost by gear, ethanol content, map-switch mode, and more working in tandem with one another.
- Completely overhauled Flex Fuel implementation. Ethanol content, ethanol ignition advance, and more are now all dedicated parameters in EcuTek. The way Flex Fuel is programmed is also far superior in RaceROM 10, and allows much tighter integration into the tune. What this means for the end user is a smoother transition between fuel types, and a smoother ramp in power delivery as ethanol content increases or decreases.
- Dedicated custom map to warn you when your AVCS system has failed to activate in a timely manner, letting you know before you push the car and risk potential damage.
- Vastly improved control over fueling in medium to full load areas.
- Improved transition from low load MAF calculation to high load VE calculation.
- Improved drivability across all versions.
- Addressed a particular bug where some vehicles would experience a hesitation in high gear, partial (20-40%) throttle pulls. This was typically experienced when trying to pass on the highway, for example.
Due to the fact that RaceROM 10 adds so much functionality and extra control over prior RaceROM versions, updates to the latest versions are a $150 fee to cover one hour of our time dialing the new setup in for you remotely. New customers will be started off on RaceROM 10 by default. If you have any questions, feel free to contact me via email at sales@delicioustuning.com.com.
Old 07-27-2018, 03:56 PM   #711
paiceyfan
paiceyfan's Avatar
Thanks.
In addition to a post elsewhere in this forum...Neal at The Racer's Line cleaned the throttle body and secured the MAF wires with hot glue. No issues since. This does not appear to be related to the tune. Just ordered the v25 tune now...
Old 10-21-2018, 11:00 AM   #712
mrg666
pessimistic skeptic
mrg666's Avatar
I have JRSC (c30 with default pulley) installed on a stock engine (stock header, injectors, fuel pump, etc) with CARB tune. I am interested in Delicious tune because the CARB tune does not seem to perform well in colder weather. I can understand that hot or cold temperature can affect the performance (power) but the engine should still be smooth at least. The engine feels different on a cold day in the same week with the same gas in the tank. Do you think Delicious tune can help? If I order Flash & Go tune, do I need to replace the MAP sensor?
Old 10-21-2018, 12:17 PM   #713
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
@mrg666
It seems like there is something off. Normally power and response increases with cooler temps, so maybe the CARB tune is limiting power by retarding ignition or decreasing throttle output proportional to accelerator input or something, so that emissions stays low. If so then DT should improve your situation. In general, the tune will be better. There is a possibility there is something else odd going on, but I can’t think of what.
Old 10-21-2018, 12:21 PM   #714
GrabTheWheel
Drives: 16' BRZ
I originally had a C30 with everything else stock on the CARB tune. Jackson’s CARB tune is one of the the better ones out there but it is still tailored towards emissions. My biggest issue was the engine just felt sluggish below 3K RPM like slower than stock. It didn’t matter if it was warm or cold out. A tune completely fixed this along with picking up about 20 whp. I don’t think you should need a MAP sensor unless you’re increasing boost or something is wrong with your current one.
GrabTheWheel is offline   Reply With Quote
P&L Oil Cooler for Forced Induction Applications!! Compatible with FMICs!!! P&L Motorsports Forced Induction 9 03-26-2017 01:27 PM
Most *fun* forced induction bfrank1972 Forced Induction 45 12-22-2016 11:36 AM
Infamous Performance is now offering dyno tunes by Delicious Tuning!!! Infamous Performance Announcements, Contests, Giveaways 115 02-28-2014 12:38 PM
February Sale. All Delicious Tuning e-tunes are 10% off!!! Infamous Performance Announcements, Contests, Giveaways 19 02-28-2014 12:37 PM
Infamous Performance is now offering dyno tunes by Delicious Tuning!!! Infamous Performance Forced Induction 107 02-13-2014 11:36 AM
