#701 |
Drives: FRS, Supra, Colorado D, GLC63
@AVOturboworld
What is the best way to ensure making boost to redline on low psi? I want this kit, but I don't want a peaky torque monster that loses boost before redline. This car loves to rev, and I love to rev it out. Strong waste gate actuator? EBC? 3" exhaust? Looking to make around 250whp |
#702 | |
I Love custom Turbo kits
Drives: Limited BRZ
#703 | |
Drives: 2013 wrb brz
I made 252whp and 202tq at under 7psi and the power pulls so smooth until redline that it's easy to hit limiter if you don't pay attention. No psi drop at all Sent from my iPhone using Tapatalk |
#704 |
This is what I wanted to hear, thank you. My roommate has a cobb stage 2 08 wrx. The thing makes its peak power and torque at like 4k rpm and drops off drastically. I can't stand it.
#705 | |
Ya it's great....I'm using a greddy ebc and I make full boost from like 3500 to redline. Sent from my iPhone using Tapatalk |
#706 | |
Drives: Scion FRS 10 Series AVO Turbo
I made about 270 hp and 215tq on 8psi stock injectors fuel pump and just 2.5" exhaust.
AVO STG1 Turbo w/ 8PSI Actuator, AVO 3" Catless Turbo Back Exhaust, AVO Air Filter, ACT 6 Puck Clutch, DW65c Fuel Pump, 900cc DW Injectors, Grimmspeed EBC, Delicious Tuning Custom Tune, 0W-20 Purol, AEM Strutbar, GrimmSpeed Hood Struts, Mann Engineering Coilovers, RacerX UCA, Gram Lights 57Xtreme, 275/35/18 BfGoodrich G-Sport Comp2 Tires, MV Designz Aero Kit, Beatsonic Shark Fin & Roof Spoiler, Five Axis Trunk Spoiler, OEMAudioPlus Reference 400
#707 | |
#708 | |
Drives: 2JZ FRS
#709 |
Ridge Racerrrrrrrrr
Looking for some advice guys;
My over pipe is not perfectly lining up with the turbo's downpipe flange so I have a small exhaust leak at the bottom. I was hoping the gasket would pinch it closed but there is a leak and I certainly smell it inside the cabin if I am stuck in traffic. Do you think any sort of gasket sealant would work for this application? Or would the pressure/heat from the exhaust gas just blow it out? Other options would be a small tap weld where the leak is, or cutting off the existing flange on my over pipe and getting a properly sized one installed. My SRT header-back exhaust is v-band fitted, so it isn't a typically 3-piece with flanges like the factory, so I can't just throw in my OEM over pipe (and cat) to fix this problem) Any ideas would be great, just wondering if you have any thoughts on the matter. Thanks!
#710 |
That sucks!
Did you try the gasket + RTV? Also, what kind of overpipe do you have again?
#711 | |
Ridge Racerrrrrrrrr
![]() You cannot really see the flange there, but it is smaller in overall size than the OEM one. Naturally the hole is the same size, if not bigger, but because it is a smaller flange and does not perfectly line up (cant really undo bits to get it to line up when it is one long piece with Vband and slip sleeves that certainly binded by now) It does sound great with my turbo though, I always liked my car's sound - now it is quieter (good) but deep (awesome)
#712 |
Drives: 2013 Scion FR-S, 1993 Lexus SC300
I've got the SRT catback (with a PLM overpipe and front pipe). It *does* sound good. And I love the look. But yeah, there are definitely fitment issues. Once I get another welder in here, I will probably end up cutting it apart and fitting it with new flanges and hangars, etc.
#713 |
So the overpipe and front pipe are one piece that bolts into the SRT catback?
If that's the case, i would buy a proper overpipe and then I'll sell you my T1R catless front pipe o2 Bung pre welded in!
#714 |
Ridge Racerrrrrrrrr
Nope, it is all one piece, sleeve fittings and vbands - no flanges except up to the down pipe.
| Tags |
| avo, avoturboworld |
| Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 10:58 PM |
| FA20Club Turbo Kit Owners Topic | pixel67 | Forced Induction | 1531 | 09-09-2014 12:36 PM |
| OFF TOPIC: Spotted a Gallardo | markmatley | Hawaii | 4 | 02-24-2013 04:26 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
