Old 04-10-2014, 10:22 PM   #701
The Racers Line
The Racers Line's Avatar
Drives: FRS, Supra, Colorado D, GLC63
@AVOturboworld
What is the best way to ensure making boost to redline on low psi? I want this kit, but I don't want a peaky torque monster that loses boost before redline. This car loves to rev, and I love to rev it out.
Strong waste gate actuator?
EBC?
3" exhaust?
Looking to make around 250whp
The Racers Line is offline   Reply With Quote
Old 04-10-2014, 10:27 PM   #702
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by WiebTech Performance View Post
@AVOturboworld
EBC?
3" exhaust?
at 8 psi you will not see the psi taper off at the end. You should make 250 with 8 psi.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
The Racers Line (04-10-2014)
Old 04-10-2014, 10:31 PM   #703
brz2013
brz2013's Avatar
Drives: 2013 wrb brz
@AVOturboworld
EBC?
3" exhaust?
I made 252whp and 202tq at under 7psi and the power pulls so smooth until redline that it's easy to hit limiter if you don't pay attention. No psi drop at all
brz2013 is offline   Reply With Quote
The Following User Says Thank You to brz2013 For This Useful Post:
Old 04-10-2014, 11:36 PM   #704
The Racers Line
This is what I wanted to hear, thank you. My roommate has a cobb stage 2 08 wrx. The thing makes its peak power and torque at like 4k rpm and drops off drastically. I can't stand it.
Old 04-10-2014, 11:38 PM   #705
brz2013
brz2013's Avatar
Ya it's great....I'm using a greddy ebc and I make full boost from like 3500 to redline.
Old 04-11-2014, 12:20 AM   #706
DesertFrs
DesertFrs's Avatar
Drives: Scion FRS 10 Series AVO Turbo
@AVOturboworld
EBC?
3" exhaust?
If u have free time on Friday the 25th, I ended up scheduling a tune when I go visit Mann Engineering at their Tuning Event this month. Will be installing some new things, hoping to make over 410 on E85.
I made about 270 hp and 215tq on 8psi stock injectors fuel pump and just 2.5" exhaust.
AVO STG1 Turbo w/ 8PSI Actuator, AVO 3" Catless Turbo Back Exhaust, AVO Air Filter, ACT 6 Puck Clutch, DW65c Fuel Pump, 900cc DW Injectors, Grimmspeed EBC, Delicious Tuning Custom Tune, 0W-20 Purol, AEM Strutbar, GrimmSpeed Hood Struts, Mann Engineering Coilovers, RacerX UCA, Gram Lights 57Xtreme, 275/35/18 BfGoodrich G-Sport Comp2 Tires, MV Designz Aero Kit, Beatsonic Shark Fin & Roof Spoiler, Five Axis Trunk Spoiler, OEMAudioPlus Reference 400
DesertFrs is offline   Reply With Quote
The Following User Says Thank You to DesertFrs For This Useful Post:
SkAsphalt (04-11-2014)
Old 04-11-2014, 11:29 AM   #707
The Racers Line
If I'm free, I'll defintely take the trip down.
The Following User Says Thank You to The Racers Line For This Useful Post:
DesertFrs (04-11-2014)
Old 04-11-2014, 01:02 PM   #708
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
what will your entire setup consist of? we maxed mine at 399whp on e84. trying to up the boost just didnt do anything at all past that. @gdrider77 had basically the same results
Old 04-11-2014, 03:23 PM   #709
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Looking for some advice guys;
My over pipe is not perfectly lining up with the turbo's downpipe flange so I have a small exhaust leak at the bottom. I was hoping the gasket would pinch it closed but there is a leak and I certainly smell it inside the cabin if I am stuck in traffic.
Do you think any sort of gasket sealant would work for this application? Or would the pressure/heat from the exhaust gas just blow it out? Other options would be a small tap weld where the leak is, or cutting off the existing flange on my over pipe and getting a properly sized one installed. My SRT header-back exhaust is v-band fitted, so it isn't a typically 3-piece with flanges like the factory, so I can't just throw in my OEM over pipe (and cat) to fix this problem)
Any ideas would be great, just wondering if you have any thoughts on the matter.
Thanks!
Old 04-11-2014, 03:25 PM   #710
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
That sucks!
Did you try the gasket + RTV?
Also, what kind of overpipe do you have again?
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
Old 04-11-2014, 03:31 PM   #711
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Originally Posted by protpibe View Post
That sucks!
The over pipe is part of my exhaust package, The Swift Racing Technologies header back that went from forum queen to junk bin deal within a few months here haha.
You cannot really see the flange there, but it is smaller in overall size than the OEM one. Naturally the hole is the same size, if not bigger, but because it is a smaller flange and does not perfectly line up (cant really undo bits to get it to line up when it is one long piece with Vband and slip sleeves that certainly binded by now)
It does sound great with my turbo though, I always liked my car's sound - now it is quieter (good) but deep (awesome)
Old 04-11-2014, 03:39 PM   #712
FrX
Drives: 2013 Scion FR-S, 1993 Lexus SC300
I've got the SRT catback (with a PLM overpipe and front pipe). It *does* sound good. And I love the look. But yeah, there are definitely fitment issues. Once I get another welder in here, I will probably end up cutting it apart and fitting it with new flanges and hangars, etc.
FrX is offline   Reply With Quote
Old 04-11-2014, 03:46 PM   #713
protpibe
protpibe's Avatar
So the overpipe and front pipe are one piece that bolts into the SRT catback?
If that's the case, i would buy a proper overpipe and then I'll sell you my T1R catless front pipe o2 Bung pre welded in!
Old 04-11-2014, 04:04 PM   #714
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Nope, it is all one piece, sleeve fittings and vbands - no flanges except up to the down pipe.
avo, avoturboworld
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
OFF TOPIC: Spotted a Gallardo markmatley Hawaii 4 02-24-2013 04:26 PM
