Old 11-16-2015, 02:48 PM   #687
mrk1
Drives: Sterling BRZ Ltd
Originally Posted by ISDriven View Post
Are you thinking NA then? Will your try to mate it to the factory trans? Btw, I really enjoy/appreciate your work.
NA is the plan, I happen to have some BMW M5 individual throttle bodies hanging around and couldn't help but notice both a 4.4L V8 and a 3.3L H6 both have a cylinder displacement of 0.55L
As for the trans the plan is to keep the BRZ trans as the only change needed will be modify the bell housing to accept a starter on the other side, the bolt holes are there but need to make room for the starter to pass through. Other then that it will bolt up, BRZ flywheel and clutch seems to bolt onto the EG just fine.
Of course everything is speculation at this point.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
The Following 5 Users Say Thank You to mrk1 For This Useful Post:
civicdrivr (11-16-2015), DustinS (11-16-2015), Iceman (11-17-2015), ISDriven (11-16-2015), new2subaru (12-12-2015)
Old 11-16-2015, 04:02 PM   #688
ISDriven
ISDriven's Avatar
Drives: chill
Very cool! What kind of power output would you like to see form the H6? Do you think you will you do internals or any head work?
ISDriven is offline   Reply With Quote
Old 11-16-2015, 04:45 PM   #689
mrk1
Its been hard to find dyno's of SVX cars as thats what this motor came in. The few I have found show just under 200 hp and the same for torque which is the real goal. Also keep in mind those cars had awful automatics and are AWD so those numbers are down.
There is a well documented build of 3.3 with cams and head work making 320whp and 276wtq again in an AWD car, they also said it made more but they brought it down to meet some class rules.
I spoke to a engine builder in CA and they say they have gotten to 400whp but thats full on bored out high comp build which I am not into.
What I am searching for is a more analog feel from the car and to me this motor fits the bill more so then the Turbo FA
Once I have at least fired this thing once I would like to pull the heads for some basic work and a cam upgrade.
The Build Thread
The Following User Says Thank You to mrk1 For This Useful Post:
DustinS (11-17-2015)
Old 11-17-2015, 09:34 AM   #690
ISDriven
ISDriven's Avatar
Drives: chill
Well, damn! 320/276 on a stock bottom end, with some head work and minimal fabrication... why would you not! Those engines are cheap, it's not even going to cost that much to build (in comparison) It would be nice if the mounts, oilpan, etc fit.
If 320/276 was AWD, then you could realistically see 340hp and probably near 300tq, maybe more. Talk about potentail I would rather have that then FI for a daily driver. Do you have a link to that 3.3 build?
The Following User Says Thank You to ISDriven For This Useful Post:
mrk1 (11-17-2015)
Old 11-17-2015, 10:33 AM   #691
mrk1
I gathered more info from different pages but mostly all on NASIOC
http://forums.nasioc.com/forums/show....php?t=1652516
The Build Thread
The Following 3 Users Say Thank You to mrk1 For This Useful Post:
DustinS (11-17-2015), ISDriven (11-17-2015), new2subaru (11-17-2015)
Old 11-17-2015, 10:54 AM   #692
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
They just crushed the SVX in the local yard. It didn't have anything pulled of it either.. I would have snatched it up in a heartbeat had I know you had plans for this.
DustinS is offline   Reply With Quote
The Following User Says Thank You to DustinS For This Useful Post:
mrk1 (11-17-2015)
Old 11-17-2015, 10:55 AM   #693
mrk1
Sad news, cant say I really blame though. When I picked my motor up they were very curious why I wanted it haha.
The Build Thread
Old 11-17-2015, 11:26 AM   #694
ISDriven
ISDriven's Avatar
Drives: chill
ok, so 320/276 was on a built bottom end. Stock it ran 285/250, which is still good.
Old 11-17-2015, 11:32 AM   #695
mrk1
Either way, 250ft lbs! that new Edelbrock SC everyone is talking about makes what 185lbs. Also a fun note that the Edelbrock SC has been independently weighted at 81 lbs!
The Build Thread
Old 12-02-2015, 01:28 PM   #696
mrk1
Fixed some wires on my scales and tossed the car on, 3/4 tank of gas and a roll bar.
56/44 Front to Rear, not bad.
The Build Thread
The Following 2 Users Say Thank You to mrk1 For This Useful Post:
Freeman (12-02-2015), new2subaru (12-02-2015)
Old 12-03-2015, 03:05 AM   #697
Guillaume
Guillaume's Avatar
Drives: Exige S 240
Which BMW engine are you referring to? I don't recall the M62 4.4 V8 having ITBs.
The S62 (5.0 V8 from the e39 M5) or S65 (4.0 V8 from the e9x M3) sure, but not the M62.
Otherwise, I'm a long time reader of this thread, amazing work.
Old 12-03-2015, 11:06 AM   #698
mrk1
Your right I misspoke, these throttles are from the S62 which is 5L. I used to own a 4.4 M62
The Build Thread
Old 12-05-2015, 10:28 PM   #699
mrk1
Not sure where this is going
The Build Thread
Old 12-07-2015, 03:26 PM   #700
Slartibartfast
Klaatu barada nikto
Slartibartfast's Avatar
Drives: Raven FR-S MT
Not sure where you're going either, but I know we're all looking forward to finding out!
Fantastic thread, fantastic work.
I vow to do no harm.
2013 Raven FR-S Manual "Lenore"
1985 Silver RX-7 GSL-SE (Gone and missed)
Slartibartfast is offline   Reply With Quote
AMR Performance: How to remove the factory bumper (walk-through images inside) AMR Engine, Exhaust, Transmission 9 04-10-2013 07:45 PM
86 Modelista walk around and GT Limited SoCal_86 Scion FR-S / Toyota 86 GT86 General Forum 3 04-24-2012 11:53 AM
