Old 05-01-2014, 07:17 PM   #687
D-VO
Drives: Whiteout FR-S, Evo 8 RS
@Td-d:
It's still not working. It's set up properly now.
paramname = Defogger
paramid = 0xFFF8939F
isfloat = 1
; logging trigger condition
conditionrpn = Defogger,1,==
action = start
conditionrpn = Defogger,0,==
action = stop
Edit*
I'm assuming that when I get a value that looks like this (2.35E-38) under the defogger that its still the wrong address no?
D-VO is offline   Reply With Quote
Old 05-01-2014, 08:59 PM   #688
steve99
Originally Posted by D-VO View Post
@Td-d:
isfloat = 1
action = start
action = stop
Edit*
I gave up on the defogger trigger on G series ROM. Could log it fine but triggering never seemed to work.
I just use RPM trigger or you can use something like coolant temp , or just plug tatrix in when your ready, it seems remarkably tollerant of being plugged in on the fly.
Old 05-01-2014, 10:08 PM   #689
D-VO
I was thinking the same thing. I'm just worried that I'm going to inadvertently rip the port right out of the car. HAve you had success with those triggers?
Old 05-02-2014, 02:24 AM   #690
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
@D-VO - my bad, it is an 8 bit value... It's curious - Vgi if I'm not mistaken got it working? Otherwise, I'll get back on trying to see what the issue is.
Td-d is offline   Reply With Quote
Old 05-02-2014, 08:51 AM   #691
steve99
I just bought a OBD extension with 90 degree plug for port under dash. 90 degree plug keeps it out of the way and the other end routed to come out at centre console where its easier to plug in and not wearing out obd socket on car.
D-VO (05-02-2014)
Old 05-02-2014, 09:46 AM   #692
Td-d
Try and clean out your logcfg file to only what you want logged (i.e. not just commenting out) - that's what Adriang did, and that seemed to sort it out.
The Following 2 Users Say Thank You to Td-d For This Useful Post:
D-VO (05-02-2014), steve99 (05-02-2014)
Old 05-02-2014, 05:45 PM   #693
D-VO
I'm gonna give it a shot on the way home.
By the way: Whats the difference between KC Advance and KC Advance IAM in OP2?
I have my Knock Correction Advance Max table set to all 8.09's, so when using the OFT the KC Advance line would decrease in the event of knock. Which one of these lines would mirror that function? It's hard to tell currently since the KC_Advance lines raises temporarily to 8.086 then drops back down to 7.84, whereas the KC_Advance_IAM stays solid at 7.84. IAM is currently 0.97.
Old 05-03-2014, 12:01 AM   #694
D-VO
Dang...still no good. I've removed all comments and only have a few parameters left.
Code:
type = obd
protocolid = 6          ; ISO15765
mode23txaddrwidth = 4   ; mode23 req format info
mode23txlenwidth = 1    ; mode23 req format info
mode23rxaddrwidth = 0   ; mode23 req format info
mode23uds = 1           ; lets OBD channels know you are using mode23 UDS
sortpids = 1            ; sort these PIDs by value to potentially make for fewer requests (=faster)
calcsampinterval = 1000 ; timing parameter - leave as is - will make default for release version
paramname = Throttle_Plate_Open_Angle
paramid = 0xFFF89030
isfloat = 1
paramname = RPM
paramid = 0xFFF893F8
isfloat = 1
paramname = Speed
paramid = 0xFFF8DB9C
isfloat = 1
scalingrpn = x,0.621371,*
paramname = Ignition_Advance
paramid = 0xFFF8DB88
isfloat = 1
databits = 8
;offsetbits = 0
isvisible = 0
action = start
action = stop
Strangely enough it logged just fine when triggered by the brake pedal (0xFFF89393). I still have a feeling the defogger has the wrong value in the logcfg fiile.
Old 05-03-2014, 09:19 AM   #695
Td-d
@D-VO - if you want to see whether it's the defogger switch or not, remove the isvisible=0 line (that basically means you don't see the value in the log). That will let you know if it's switching or not - I'm pretty certain it is the right value.
I have a theory - in Vgi's logcfg, the addresses are ordered contiguously, which follows the request to sortpids = 1, making for faster logging. Yours are not - maybe that's the issue.
Old 05-03-2014, 10:07 PM   #696
D-VO
@Td-d: Strangely enough removing the isvisible line from the defogger value made it work as its supposed to, but it still logs the defogger value...? It now shows the proper value of 1, and logs when the defogger switch is depressed. Success!! I still have my addresses scattered by the way. Now all I have to do is find the proper IAT and coolant addresses in the list provided.
Old 05-04-2014, 12:43 PM   #697
Td-d
Excellent!
Old 12-14-2014, 06:21 PM   #698
ztan
Drives: Toyota 86
CAN Mode 23 requests
Been playing around with CAN addressing again - pulling RAM data gives faster update speeds than the OBD routines.
Mode 01:
Request:
Code:
00 00 07 E0   01            10
ECU address   OBD mode 01   MAF PID
              request
Response:
Code:
00 00 07 E8   41            10       00 55
ECU response  OBD mode 01   MAF PID  Data
              response
00 55 converted from int to dec/100 = 0.85 g/s
Mode 23:
MAF RAM address in my ROM is FF F8 7C 70
The 14 after mode 23 request: first 4 bits are size of response length descriptor, second 4 bits are size of ram address descriptor.
Request:
Code:
00 00 07 E0    23           14       FF F8 7C 70   04
ECU address    OBD mode 23  Length   RAM address   Response length
               request
Response:
Code:
00 00 07 E8    63                    3F 59 99 9A
ECU response   OBD mode 23           RAM data
               response
3F 59 99 9A converted to float = 0.85 g/s
ztan is offline   Reply With Quote
Old 03-22-2015, 12:10 PM   #699
ztan
Drives: Toyota 86
Originally Posted by Td-d View Post
I've already defined intake and Exhaust AVCS - did I not post it up?
Code:
RAM:FFF8C0E8 Intake_VVT_Advance_Angle_Right:.res.b 1 ; DATA XREF:
RAM:FFF8C0EC Intake_VVT_Advance_Angle_Left:.res.b 1  ; DATA XREF:
RAM:FFF8C130 Exhaust_VVT_Retard_Angle_Right:.res.b 1 ; DATA XREF:
RAM:FFF8C134 Exhaust_VVT_Retard_Angle_Left:.res.b 1 ; DATA XREF:
A01G AVCS RAM addresses:
Code:
paramname = Intake_AVCS_Right
paramid = 0xFFF8BF80
isfloat = 1
scalingrpn = x
paramname = Intake_AVCS_Left
paramid = 0xFFF8BF84
isfloat = 1
scalingrpn = x
paramname = Exhaust_AVCS_Right
paramid = 0xFFF8BFC8
isfloat = 1
scalingrpn = x
paramname = Exhaust_AVCS_Left
paramid = 0xFFF8BFCC
isfloat = 1
scalingrpn = x
The Following 3 Users Say Thank You to ztan For This Useful Post:
aagun (10-03-2015), D-VO (03-22-2015), steve99 (03-22-2015)
Close iJason Member's Car Journals 1 08-04-2013 08:26 PM
Close pche Engine, Exhaust, Bolt-Ons 3 08-04-2013 02:04 AM
Sorry. please close. finch1750 Scion FR-S / Toyota 86 GT86 General Forum 1 07-31-2013 01:00 AM
please close abutterman Wheels and Tires 0 07-05-2013 09:40 AM
