| Software Tuning Discuss all software tuning topics. |
#687 |
Drives: Whiteout FR-S, Evo 8 RS
@Td-d:
It's still not working. It's set up properly now. paramname = Defogger paramid = 0xFFF8939F isfloat = 1 ...................................... ; logging trigger condition conditionrpn = Defogger,1,== action = start conditionrpn = Defogger,0,== action = stop ![]() Edit* I'm assuming that when I get a value that looks like this (2.35E-38) under the defogger that its still the wrong address no? Last edited by D-VO; 05-01-2014 at 07:44 PM. Reason: more info |
#688 | |
Drives: FT86
I just use RPM trigger or you can use something like coolant temp , or just plug tatrix in when your ready, it seems remarkably tollerant of being plugged in on the fly.
#689 | |
#690 |
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
@D-VO - my bad, it is an 8 bit value... It's curious - Vgi if I'm not mistaken got it working? Otherwise, I'll get back on trying to see what the issue is.
#691 |
Drives: FT86
I just bought a OBD extension with 90 degree plug for port under dash. 90 degree plug keeps it out of the way and the other end routed to come out at centre console where its easier to plug in and not wearing out obd socket on car.
| The Following User Says Thank You to steve99 For This Useful Post: | D-VO (05-02-2014) |
#692 |
Try and clean out your logcfg file to only what you want logged (i.e. not just commenting out) - that's what Adriang did, and that seemed to sort it out.
#693 |
I'm gonna give it a shot on the way home.
By the way: Whats the difference between KC Advance and KC Advance IAM in OP2? I have my Knock Correction Advance Max table set to all 8.09's, so when using the OFT the KC Advance line would decrease in the event of knock. Which one of these lines would mirror that function? It's hard to tell currently since the KC_Advance lines raises temporarily to 8.086 then drops back down to 7.84, whereas the KC_Advance_IAM stays solid at 7.84. IAM is currently 0.97. |
#694 |
Dang...still no good. I've removed all comments and only have a few parameters left.
Code:
type = obd protocolid = 6 ; ISO15765 mode23txaddrwidth = 4 ; mode23 req format info mode23txlenwidth = 1 ; mode23 req format info mode23rxaddrwidth = 0 ; mode23 req format info mode23uds = 1 ; lets OBD channels know you are using mode23 UDS sortpids = 1 ; sort these PIDs by value to potentially make for fewer requests (=faster) calcsampinterval = 1000 ; timing parameter - leave as is - will make default for release version paramname = Throttle_Plate_Open_Angle paramid = 0xFFF89030 isfloat = 1 paramname = RPM paramid = 0xFFF893F8 isfloat = 1 paramname = Speed paramid = 0xFFF8DB9C isfloat = 1 scalingrpn = x,0.621371,* paramname = Ignition_Advance paramid = 0xFFF8DB88 isfloat = 1 paramname = Defogger paramid = 0xFFF8939F databits = 8 ;offsetbits = 0 isvisible = 0 conditionrpn = Defogger,1,== action = start conditionrpn = Defogger,0,== action = stop Last edited by D-VO; 05-03-2014 at 12:03 AM. Reason: missing info |
#695 |
@D-VO - if you want to see whether it's the defogger switch or not, remove the isvisible=0 line (that basically means you don't see the value in the log). That will let you know if it's switching or not - I'm pretty certain it is the right value.
I have a theory - in Vgi's logcfg, the addresses are ordered contiguously, which follows the request to sortpids = 1, making for faster logging. Yours are not - maybe that's the issue. |
#696 |
@Td-d: Strangely enough removing the isvisible line from the defogger value made it work as its supposed to, but it still logs the defogger value...? It now shows the proper value of 1, and logs when the defogger switch is depressed. Success!!
I still have my addresses scattered by the way. Now all I have to do is find the proper IAT and coolant addresses in the list provided.
#697 |
Excellent!
#698 |
Drives: Toyota 86
CAN Mode 23 requests
Been playing around with CAN addressing again - pulling RAM data gives faster update speeds than the OBD routines.
Mode 01: Request: Code:
00 00 07 E0 01 10
ECU address OBD mode 01 MAF PID
request
Code:
00 00 07 E8 41 10 00 55
ECU response OBD mode 01 MAF PID Data
response
Mode 23: MAF RAM address in my ROM is FF F8 7C 70 The 14 after mode 23 request: first 4 bits are size of response length descriptor, second 4 bits are size of ram address descriptor. Request: Code:
00 00 07 E0 23 14 FF F8 7C 70 04
ECU address OBD mode 23 Length RAM address Response length
request
Code:
00 00 07 E8 63 3F 59 99 9A
ECU response OBD mode 23 RAM data
response
#699 | |
Drives: Toyota 86
A01G AVCS RAM addresses: Code:
paramname = Intake_AVCS_Right paramid = 0xFFF8BF80 isfloat = 1 scalingrpn = x paramname = Intake_AVCS_Left paramid = 0xFFF8BF84 isfloat = 1 scalingrpn = x paramname = Exhaust_AVCS_Right paramid = 0xFFF8BFC8 isfloat = 1 scalingrpn = x paramname = Exhaust_AVCS_Left paramid = 0xFFF8BFCC isfloat = 1 scalingrpn = x |
| Close | iJason | Member's Car Journals | 1 | 08-04-2013 08:26 PM |
| Close | pche | Engine, Exhaust, Bolt-Ons | 3 | 08-04-2013 02:04 AM |
| Sorry. please close. | finch1750 | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 07-31-2013 01:00 AM |
| please close | abutterman | Wheels and Tires | 0 | 07-05-2013 09:40 AM |
