Old 07-27-2015, 12:53 PM   #687
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by Icanfaptothis86 View Post
Perhaps you could post your laptimes around local track in your car vs a slightly modded mostly stock frs/brz
I dont want to start a huge debate or any drama but my understanding was that wings arent doing a whole lot below speeds of like 100mph ... most of the tracks I go to with this car I struggle to hit 90 but I go to some really small twisty tracks MSRH and Gransport speedway in Houston... please dont flame me I just want to see you hit your goal of lowest weight 86 out there.
Also a possible suggest acid dipping the body work or sanding down the body work ?
I am currently gutting my 2005 mini cooper R53 S for dedicated track usage and I find myself rereading your build thread for ideas. ... once the BRZ is off warranty I will be doing some similar modding.
anyways dude huge respect for your build and your low weight ethics. I am all about that qoute from Colin. If you are ever down in Houston Texas give me a shout.
I know my wing definitely works at speeds under 100 MPH.
Old 07-27-2015, 01:01 PM   #688
Icanfaptothis86
tickle fight referee
Icanfaptothis86's Avatar
Drives: 2015 Subaru BRZ
how do you know ?
Icanfaptothis86 is offline   Reply With Quote
Old 07-27-2015, 01:04 PM   #689
King Tut
NASA SpecE30 Racer
King Tut's Avatar
how do you know ?
Laps before it was installed and after it was installed and the way the feel and balance of the car changed with no other changes. The car moved from oversteer to understeer in corners slower than 100 MPH.
Old 07-27-2015, 01:05 PM   #690
MicheleAbbate
MicheleAbbate's Avatar
Drives: Grr Racing FRS & BRZ
Send a message via AIM to MicheleAbbate
FWIW my team will be testing between having a wing or a diffuser the next time we hit the track.
www.GrrRacing.com - Won Scion's first Road Racing Championship in 2011. Raced the Grr Racing Scion FRS from 2014-2018. Have lots of OEM Part FS. lol Check my thread. Now I race in Trans Am TA2.
MicheleAbbate is offline   Reply With Quote
Old 07-27-2015, 02:44 PM   #691
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
I still haven't tracked it yet, I've only done some autocrosses. I got the wing because I was losing traction in the rear on streets. I have some decent roads around my house, so that's where I actually make use of the car. Before the wing, I was losing traction at the peaks of hills and rolling over bumps. I was doing burnouts at like 60mph, not even accelerating. Shit would get sketchy when the traction would catch again. So I got the wing and all that nonsense went away.
As for tracks, my nearest track is NOLA, and it's flat, smooth, and high speed. I did about 5 track days out there on my R6, and you spend a lot of time over 100 on that thing. Of course an FR-S wouldn't be as fast as an R6, but still. That track is fast. So the wing would probably actually have some effect out there.
Once I start going out there, after I've gotten my lap times consistent, I'll take the wing off and see if there's any difference. My car understeers like crazy, so I could see it actually having some benefit. But... the car is so slow, the drag from the wing might cancel out the time saved in corners.
As for acid dipping, I'm aware that people do that, but I would think that would be a huge amount of work and probably be expensive.
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
Old 07-27-2015, 05:16 PM   #692
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
Out of curiosity, why the wing over a diffuser? The diffusor has been shown to lower drag while lowering rear lift.
Luckrider is offline   Reply With Quote
Old 07-27-2015, 07:55 PM   #693
Anthony
Weight Nazi
Anthony's Avatar
Easy! I didn't know that.
Old 07-27-2015, 08:39 PM   #694
JS + BRZ
Drives: 2010 MS3
Get on that Velox diffusor bandwagon now!
JS + BRZ is offline   Reply With Quote
Old 07-27-2015, 09:02 PM   #695
Luckrider
Luckrider's Avatar
Driveway Labs is where my money would go.
Old 07-27-2015, 10:18 PM   #696
phobos512
phobos512's Avatar
Drives: 2014 FR-S 6MT Whiteout
I'm not sure either setup is usable for @Anthony without a bit of work given his removal via sawzall of the stock grey plastic diffuser thing...
Matt | '14 FR-S 6MT Whiteout | '13 Sonata Hybrid | '11 CBR1000RR
phobos512 is offline   Reply With Quote
Old 07-27-2015, 10:25 PM   #697
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
I've seen a few that just use some metal bands bolted to diffuser and where the bumper/crash beam bolt to the body.
Old 07-27-2015, 10:35 PM   #698
phobos512
phobos512's Avatar
That'd be the bit of work
Old 08-03-2015, 11:31 AM   #699
Icanfaptothis86
I always see these extreme car weight reduction threads and I'm like ok thats cool but there is always so much low hanging fruit driver weight reduction to be had:
-spleen dont need it
-remove left leg and upgrade to clutchless sequential
-only need one teste hitler-style
-shaved head and full body wax
-get regular enemas to clear out impacted shit
-remove some extra fingers and toes that arent entirely essential to the driving process
-tonsils
-donate heaps of blood before any competitive driving event
-remove fingernails vietnam POW style
-circumcision
-ears
-septum
-replace joints with titanium rivets
-appendix
needless to say if you can get past your tech inspection without a nomex suit on or head sock driving naked is a fantastic way to shave some unnecessary poundage. I for instance wear only a nomex thong rather than nomex underware to get a small edge on my competition
Just some ideas and stuff ive pulled off other medical forums - food for thot
Celery man
Electrical space wizard
Old 08-16-2015, 04:47 AM   #700
NARFALICIOUS
NARFALICIOUS's Avatar
Drives: 88 Supra 1JZ, 16 FRS, 25 GR Corolla
Nice. Skimmed through all the pages of the thread. Is there an official weight of the car currently? I see "367lbs" but that would put it above 2300lbs
NARFALICIOUS is offline   Reply With Quote
mother fu(king winning!
