#57 |
Spline Reticulator
Drives: 2013 FR-S Whiteout
If you just want to know the E level, there are already things that will let you do that. But having it integrated with a tune will be awesome. Who wants to sample the E, edit tables, and re-flash every time you go to the pump? Looking forward to seeing this released too - great work, guys!
Johnny was a chemist's son, but Johnny is no more. What he thought was H2O was H2SO4. ![]() |
#58 |
Drives: FR-S Whiteout
^ Join the ztan fan club. lol Patiently waiting...
Intent > Content
cowardice is the mother of cruelty. |
| The Following User Says Thank You to solidONE For This Useful Post: | Awstryker (06-17-2016) |
#59 |
Drives: Saab 92x
what is VSC module?
#60 |
#61 | |
Drives: 2012 Toyota 86
Hi. I'm trying to install Ptuning's Flex Fuel System into my Toyota 86.
In the instructions, one of the steps required wire tapping into Pin 20 on the A35 ecu connector. Apparently, in the US, there is a wire in that spot. But my Toyota 86 here in the Philippines does not. So basically, i was searching online to see if it's possible to hook up a wire into the empty spot. Luckily I saw your post. Just to confirm,putting a wire into #20 will provide an input signal needed for the flex fuel system? Thanks! Quote:
#62 |
Pretty sure the info in this post is *not* applicable for the Ptuning kit.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
#63 | |
If your kit and tune is set up for evap input then yes hook signal wire up to pin20 an connector A35 of ecu, and yes in some countries like australia and appears yours their will be no wire on that ecu pin as evap system not used on stock car. The ecutek software or ztans code will tell the ecu to now use that input for flex sensor. |
#64 |
#65 | |
Thanks! Yea, I'll be getting it tuned via ecutek once the flex fuel system is installed. I just wanted to make sure if pinning a wire in that empty evap pressure sensor slot will still provide a signal
#66 |
The more fiddling i do with these ecu's it appears that the actual ecu hardware is likely the same accross many countries. I seen people put Australian/european roms in USA cars , Australian/european roms in japanese cars and they still work. But their are wiring differences and other subtle difference in the cars.
#67 | |
Drives: Toyota 86
Test after installing to make sure you can get sane data from whichever software system you are using in the place you expect it... |
#68 | |
thanks! |
#69 |
Drives: Toyota 86 GTS
I started ramping up the timing and leaning it out at E10 as my NA 98RON maps don't drop IAM like the openflash maps do on E0 and run fairly rich.
Fuelling Compensation Fuelling Interpolation Timing Interpolation E10 is up to around 0.3 extra advance, E20 is up to around 0.9 extra advance. Cranking Compensation I didn't understand why ztan's values were so high between 20 and 40, but it makes sense when you have zero IPW compensation. 10C will still be a little thin I think, but it's not generally that cold here. Everywhere else including 0C, 20C, 30C should have plenty. END |
#70 |
Will this work with the OpenFlash Tablet without disabling emissions controls.
If I say yes, will that make you think I understand?
| Open source Over Boost Fuel Cut | ztan | Software Tuning | 19 | 02-15-2026 01:32 AM |
| Open Source Electric Supercharger | neutron256 | Forced Induction | 913 | 08-22-2021 05:16 PM |
| open source software question | GeeTee86 | AFRICA | 15 | 02-15-2015 06:52 PM |
| The Retrofit Source summer open house! | soundman98 | Southeast | 0 | 06-23-2014 08:41 PM |
| ECUtek Flex Fuel REVOLUTION: World's First Flex Fuel Factory ECU GTR - BRZ soon! | Visconti | Engine, Exhaust, Transmission | 356 | 05-20-2013 09:36 AM |
