CANADA Canada
Old 09-18-2015, 02:23 AM   #57
steve99
Originally Posted by ShibaYuki View Post
Alright, I'll check the primary o2 sensor on Saturday. I may have to buy the chaser. The sensor looks and feels screwed all the way. I need a wrench to loosen the primary o2 sensor. I just really hope the front o2 sensor is not damage. These sensors are dang expensive. How would I be able to get to the front o2 sensor? Just take off the whole intake?
You should be able to get at primary (front) o2 sensor pretty easy without removing anything else its in header primary tube near base of dipstick.
If that washer is loose on 02 sensor id say the shop forced it in and its likely damaged threads on o2 sensor and its leaking. After you chase threads the sensor should screw in easily by hand then just torque it the last bit and the washer should not be loose. If your lucky you wont need a new sensor if the threads are not two badly damaged to seal correctly.
The maf sensor is the black plastic thing at top of air box again easily removed.
Old 09-18-2015, 06:35 AM   #58
ShibaYuki
Drives: 2013 WRB Subaru BRZ Sport-tech
Shouldn't the car throw a CEL though? I'm not getting any CEL in the car. But when I read it with OFT I sometimes get the p0171. Do I need to remove the maf sensor before I touch the primary (front) O2 sensor without moving the headers?
Also check the log I did yesterday and tell me if there's something wrong.
ShibaYuki is offline   Reply With Quote
Old 09-18-2015, 01:31 PM   #59
wparsons
wparsons's Avatar
What did you do to the log? It's sorted on rpm descending, not time ascending...
It's impossible to follow and make any useful conclusions the way it is. Can you re-upload it, but sort the whole data on time ascending first?
flickr
Old 09-18-2015, 07:04 PM   #60
ShibaYuki
Sorry, how do I do that? This is like my second time logging.
Old 09-18-2015, 07:17 PM   #61
steve99
if you have never touched intake and intake is stock and you have a dry filter ( not oiled type) then it very ulikely it a maf issue. just leave the maf alone till you have checked front o2 sensor.
Old 09-18-2015, 08:48 PM   #62
ShibaYuki
I do have a K&N filter though. I changed it a long time ago. I believe 1 month into owning the car, which is 1 year and 8 months.
Old 09-18-2015, 10:50 PM   #63
ShibaYuki
http://datazap.me/u/shibayuki/test-1...=1-7-8&solo=11
Guys, here's the updated log that I did tonight. I did 2 3rd gear pull till redline. Hope something comes out of this.
Old 09-19-2015, 09:22 AM   #64
wparsons
wparsons's Avatar
Are you opening the file with something else and saving it after pulling it off the OFT?
This is what the time line should look like:
http://www.datazap.me/u/wparsons/jul...d?log=0&data=0
Now look at yours:
http://datazap.me/u/shibayuki/test-1?log=0&data=0
If that's happening without opening the file in excel and sorting it, then I'd post up in the tuning section and tag Shiv in the post. The log should be ordered by time ascending by default. Your first files were sorted on engine speed descending, the latest is engine speed ascending.
Short term fix, open the CSV file in excel and sort it on time ascending then re-upload it.
Also, don't worry about wideband AFR unless you have added an aftermarket wideband. AFR is the stock sensor channel.
flickr
Old 09-19-2015, 10:44 AM   #65
ShibaYuki
Now look at yours:
Been trying to sort it in excel and dang! Ionno how the hell to use this program. Haha.
Yes, it's sorting itself out I believe. I literally, just save it from my OFT to the computer, then upload it to datazap.
Old 09-19-2015, 06:18 PM   #66
ShibaYuki
Now look at yours:
Alright! Here! I checked if the "Time" is ascending and it is! Hope you guys can find something out of this one.
http://datazap.me/u/shibayuki/updated?log=0&data=0-1
Also, driving around today and I started getting p2097 and the car also went to limp mode during a highway drive. Couldn't even push the car in 4th gear going 100 km/h.
I tried checking if the primary sensor is loose, and it's not loose at all.
Old 09-19-2015, 07:50 PM   #67
steve99
OK
1. the "wideband afr" which is signal from REAR o2 sensor is constantly at 18 which is full lean and it never changes.
either their is
1. a air leak near sensor
2. rear o2 sensor not plugged in or plug/cable damaged
3. REAR 02 sensor is stuffed
also the long term fuel trim is 37% in places this is almost at the limit of correction (40%) this indicates leak or problem with FRONT 02 sensor , the sensor FRONT 02 seems to be reading ok and with that huge fuel correction its running reasonable AFR, but its likely the sensor is seeing fresh air so it thinks car is running lean, then ecu is adding 30% more fuel to compensate
1. massive air leak near sensor (could be same leak)
Are the sensors plugged in correctly and plugs in all the way, grey to grey and black to black.
I dont think its possible to screw the front o2 sensor into the rear connection on the header due to the cable length but its kind of looking that way or something rearly weird is going on.
If one of the 02 cables is very tight this may have been done, both cables should have plenty of "slack " in them.
See above GREY plug is FRONT 02 Sensor front sensor should be in the single tube at front of OFH
BLACK plug is REAR 02 sensor should be after the collector on OFH where all four tubes have come togeather.
then BLACK plug to black socket,,grey to grey on connectors
Its difficult to diagnose stuff from the other side of the planet and i would hate for you to spend more money on sensors ect when the problem my be wiring or install issues.
I think its time to take it to a shop they has experience with 86 or subaru and let them have a look :-)
Old 09-19-2015, 08:12 PM   #68
ShibaYuki
OK
either their is
Rear o2 sensor is brand new. Shop chased/tapped the rear bung and screwed in the brand new rear o2 sensor on thursday. Now it's snug and screwed in there.
Also, both sensors are plugged in correctly. Gray on gray, black on black. Primary is in front, and Rear is at the back.
How do I tell if the rear o2 sensor is stuffed? Man, this means I gotta take off the headers again!
So right now, you're telling me, I may have a leak at both sensor?
My wrists are pretty skinny, so I just opened the hood and checked if any of the sensors are loose(yes, i can reach the rear sensor, barely). And none of them were loose. They're screwed in there. But when I started the car, I tried to put my whole head in there if I can hear any some what air leak. But all I can hear is the belts wooshing but I can smell gas though. Ugh! Such a headache. I don't wanna give it to Subaru because the car is not really throwing any CEL. It's just showing in the OFT that I do have those codes. So if they look at it, they're just going to say nothing is wrong since there's no real CEL.
Old 09-19-2015, 11:57 PM   #69
ShibaYuki
Here's another quick log I did tonight.
Please let me know, if there's any difference.
http://datazap.me/u/shibayuki/log-1?log=0&data=0-1
I started getting P219A (Air fuel ratio imbalance) in the OFT.
But no CEL at all in the car.
Old 09-20-2015, 01:17 AM   #70
steve99
Ok that log is looking heaps better, the ltft is now below 10% which is good.
It may have been because the ltft was so bad with crook original sensor ecu took a while to stabilse fuel trims. which now look ok
The wideband afr signal is still weird but it may be a logging error with oft.
I would clear the error code ad do some more driving and see if it returns as that code may have triggered when old sensor was installed or prior to leak fix.
I probably should have asked if you had reset ecu and how much driving you have done.
but it looking much better now, hopefully after you clear that code it will be good
anyone have these installed? ft86me Cosmetic Modification (Interior/Exterior/Lighting) 3 04-05-2015 12:36 PM
KDT 925 installed. Racecomp Engineering Suspension | Chassis | Brakes -- Sponsored by 949 Racing 54 08-14-2014 04:29 PM
Scion installed vs dealer installed fog lights subiestyle Cosmetic Modification (Interior/Exterior/Lighting) 10 02-16-2014 01:55 PM
Tint, lights and backup cam installed, and camber kit installed in Gainesville area? husker741 Southeast 2 08-16-2013 04:59 PM
Innovative SC Installed!!! Pics and dyno installed. uspspro Forced Induction 15 04-02-2013 01:09 AM
