Old 09-01-2015, 09:34 PM   #57
OkieSnuffBox
Drives: '23 BRZ Limited
Originally Posted by solidONE View Post
Just for that, I will test your theory myself. Who has a spare stock airbox laying around?
I already did test it. This weekend.
Old 09-01-2015, 10:07 PM   #58
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Results? did you do a shielded and non-shielded back to back and take logs with different throttle percentages steady?
There are guys in the 86Cup using the shielding, and they seem to think it works (butt dyno).
Intent > Content
Old 09-01-2015, 10:09 PM   #59
solidONE
solidONE's Avatar
If you want to provide any benefit, you want an external blanket material that has a high emittance and a low absorptance.
This means it is good at radiating heat, but poor at absorbing it.
Low "absorbtance to emittance ratios" are typically made with Clear teflon coatings with a shiny surface mirror finish.
And they are directional.
For this application you would use a "second surface mirror" teflon flim with the aluminized surface down towards the intake tube.
So a DIY solution would be to apply real gold leaf (actually not that expensive) covered in a teflon based clearcoat.
Can this special coating you speak of be sprayed on? Link to product?
Intent > Content
Old 09-01-2015, 10:49 PM   #60
OkieSnuffBox
Sorry, I could have sworn the person I was originally responding to was talking about doing this to the stock intake.
At speed, on my stock intake in 94° ambient temps, the IAT was never above 11° over ambient and most of the time within 5-7°.
Old 09-01-2015, 11:01 PM   #61
solidONE
solidONE's Avatar
What temp was the intake box at? Did you let the heat soak in first before measuring? Lets see some logs, if you don't mind.
Kenji of Winmax seems to think it helps. The air box looks pretty stock to me.
One sure way for me to find out, I guess. I'll do it for science! lol
Intent > Content
Old 09-02-2015, 07:57 AM   #62
OkieSnuffBox
At one point when I stopped to fill up (car up to temp), and got back in to leave. The IAT had heat soaked to 145°. Just pulling out of the lot it was already starting to come down and within a few miles of stop and go traffic was already back down to around 115°.
I suspect if I got on the highway it would have dropped to the 7-10 range very quickly.
No logs, I was just reading the OFT screen.
Could there be a difference? Possibly. But I suspect when you are talking about that close to ambient it would fall in the "statistical noise" category.
Old 09-02-2015, 08:12 AM   #63
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Hey guys I am partly dont my TRD air box. Taking so god dam long to do haha. I am not doing true proper testing with this but rather just the torque app on my headunit. I will report back when I am all done and have taken it for a few drives. I would upload some pics but they are too large and I cant edit them from my phone
Old 09-02-2015, 08:35 AM   #64
raven1231
What? No true experimental designs for aluminum foil wrapped intakes? I'm very surprised.
Old 09-02-2015, 09:30 AM   #65
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Lol I don't want to put that kind of effort into this. Thinkof it as a "pre test" and if I feel it makes a difference thensomeone can come along and do a proper test. If I feel it makes no differencethen no one else has to waste their time with this haha! It does look kind of cool but I am not sure if I will keep it on when I am all done
Edit: and I am using @Mishimoto gold foil tape and it is really nice to work with.
raven1231 (09-02-2015)
Old 09-02-2015, 09:49 AM   #66
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
I'm really excited about this thread.
Thermal management really interests me, and I'm curious to see if this is a potentially meaningful modification. Even if the difference is very small, the cost is low.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
The Following User Says Thank You to JazzleSAURUS For This Useful Post:
notout86 (09-02-2015)
Old 09-02-2015, 09:57 AM   #67
raven1231
If you like the way it looks then that is reason enough to keep it man!
Old 09-02-2015, 10:48 AM   #68
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
I will keep you up to date then. I will also be doing a header wrap but I need to order more wrap. It will be coming with my new oil cooler core some time later this month.
Old 09-02-2015, 11:59 AM   #69
s30series
Drives: 2015 BRZ Series.Blue
If you use the search function, you'll see that I've already done this, and I've already used an infared gun to measure and record tempatures....
since this pic was taken I've added the silver heat shield to the front of the mishimoto pipe....
IAT temps are extremely low even sitting in traffic on this car.
s30series is offline   Reply With Quote
Old 09-02-2015, 12:06 PM   #70
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Lol I didn't even think to search. Do you got any numbers??
Engine Dress-Up, Heat Shielding & Motor Oil products @ OAKOS.com OAKOS Automotive Engine, Exhaust, Bolt-Ons 192 02-13-2015 01:38 PM
'14 FR-S OEM Air Intake System w/ K&N Filter and Zeta Performance Intake Tube SoCalArgento Engine, Exhaust, Bolt-Ons 4 02-06-2015 10:40 PM
Intake tube and heat soak mike the snake Forced Induction 17 02-05-2015 01:46 PM
DIY Gold Foil heat wrap intake box autoCAR DIY (Do-It-Yourself) Guides 35 02-20-2014 02:22 PM
.: GReddy Air Intake System · Increases intake airflow · 4 Layer filter :. Speed Element Engine, Exhaust, Bolt-Ons 14 05-20-2013 06:06 PM
