Old 07-20-2021, 08:46 AM   #43
BleedingRust
Drives: BRZ S
Originally Posted by Gamace View Post
I have this same issue, however, the problem for me, is that the end on my reverse light switch has been rubbed down. When the reverse gear is engaged, it's not sinking the switch down enough to trigger the reverse light/camera.
So I need a new switch overall. Does anyone know where I can order one of these?
Sent from my SM-N975U1 using Tapatalk
How did you remove it? I can't get at it from the bottom because the cat is in the way and I can't get reach from the fire wall even with a wrench.
BleedingRust is offline   Reply With Quote
The Following User Says Thank You to BleedingRust For This Useful Post:
norcalpb (07-20-2021)
Old 07-20-2021, 09:46 AM   #44
BleedingRust
Drives: BRZ S
It's depressed to turn on not a constant on like a door switch. I checked the user guide and i tried to unplug the switch up top when in gear. It's so strange I have reverse indicator and the reverse beep is working but the lights flicker when i wobble the shifter or when it moves when in motion. Super frustrating.
Old 07-20-2021, 02:31 PM   #45
norcalpb
norcalpb's Avatar
Originally Posted by e1_griego View Post
I did it from up above, just reaching back.
It's not super fun.
Did you end up removing any parts to make access easier? I can’t seem to get my arm back their either and I really want to remove my janky “fix”
Old 07-20-2021, 05:13 PM   #46
e1_griego
e1_griego's Avatar
Drives: Many
I had a buddy down below and I worked from up above, if i remember correctly.
I have a lift at home now, so if it happens again it should be easier to deal with.
e1_griego is offline   Reply With Quote
The Following User Says Thank You to e1_griego For This Useful Post:
Old 06-30-2025, 09:42 PM   #47
uras300
Resurrecting this thread since it was helpful to fix the reverse light not coming on and to comment the method that worked for me.
I've removed the old/faulty switch clip and plugged in the new one temporally so it dangles from above and to make it easier to grab the bolt end from below. Then, I've jacked up the car and accessed the bolt from below. In order to access the bolt, I needed to remove front pipe so my hands could fit through the area. Once I've created the space, an open ended wrench could be snaked between transmission and transmission tunnel to loosen the bolt. Reverse the sequence to install. *Keep in mind the wire will twist as the bolt is tightened so the clip end needs to be removed to unwind and reinstalled*
uras300 is offline   Reply With Quote
FR-S / BRZ Reverse/Backup LED Bulbs! See Comparison Photos, Ships Same-Day! Diode Dynamics Exterior Parts - Lighting 72 11-30-2021 02:19 PM
Diode Dynamics Tail-as-Turn™: Make your LED tail a turn signal & add backup LEDs! Diode Dynamics Exterior Parts - Lighting 192 10-04-2017 11:51 AM
Reverse gear signal on factory HU harness? Panman Electronics | Audio | NAV | Infotainment 2 01-24-2014 10:24 PM
Interior LED + Reverse backup package? Intake Scion FR-S / Toyota 86 GT86 General Forum 1 07-12-2013 11:46 AM
Radio Signal Issue When shifting into Reverse ruskymx Scion FR-S / Toyota 86 GT86 General Forum 13 01-22-2013 09:05 PM
