Old 02-12-2014, 03:54 PM   #57
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by Porsche View Post
Am I mistaken, then, in thinking that a CDV only affects RELEASING the clutch pedal, the clutch engagement?
What you're saying here suggests that the CDV affects the clutch DISengagement as well, so that a fast shift might "beat" the clutch disengagement, which of course would result in gears grinding.
If so, I don't like the sound of that.
Not sure honestly. I've never looked into these systems as I've never really been affected by them.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-12-2014, 04:04 PM   #58
Porsche
Drives: 2013 BRZ Ltd. MT
Yeah, me either. Thanks, though.
Porsche is offline   Reply With Quote
Old 02-13-2014, 08:39 AM   #59
BRZfan
BRZfan's Avatar
Drives: 2013BRZ Premium St Silver Metallic
Her ya go. These are the rage in the Simi Valley. They are comfortable, really, really, quiet and project an atmosphere of aggressive and dominating behavior, i.e., (alpha male).
Originally Posted by SirBrass View Post
I'm looking for a good pair of shoes that will look good in the workplace, where normal professional dress is a neat button down untucked short sleeve w/ jeans or dockers.
My loafers are good for that, but a little too loose in the heel for driving with all the time (the back of my ankle on my left foot gets majorly tender).
I also have narrow feet, so I need something that fits, but isn't so foot - conforming that the sole is too narrow (even with the cusco accelerator pedal, my jazz sneakers are too narrow for secure heel-toe purchase).
I'll look at the drift cat 5's. I just need to find a store around here that has them so I can try them on & see if my normal size (8.5 or 9) is appropriate.
BRZfan is offline   Reply With Quote
Old 02-13-2014, 11:33 AM   #60
wheelhaus
wheelhaus's Avatar
wow thread derailed...
I feel like there is a CDV for engagement, because trying to double clutch quickly still has a notable "bump" in the shift as the synchros mate. I've tried many different timings and only If I DC slowly, the shifter nearly falls into place as it should. This makes me believe the clutch doesn't engage quickly enough between two quick stabs of the pedal.
I had an 06 Evo MR that had a CDV, but it was pretty simple to remove. The Evolutionm.net guys called it the clutch pill, and it was a little restrictor piece in the slave cylinder behind the hose threads. Remove the hose, extract restrictor pill, reinstall hose and bleed clutch.
IT'd be nice if someone was willing to tear down their 86 clutch master and slave to see just wtf is going on in there.
wheelhaus is offline   Reply With Quote
Old 02-14-2014, 12:13 AM   #61
Poodles
Drives: 2015 Series.Blue
Well, the exploded diagram I see of the master doesn't show anything that could be it, but the body of the master is oddly shaped (and the exploded diagram doesn't cover removal of the snap ring on the bottom and what's behind it). Given it's odd shape, it could very well be in there.
The slave looks conventional.
Old 04-02-2014, 01:19 AM   #62
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
Bump for this, because I HATE our clutch
Old 04-03-2014, 11:20 AM   #63
daiheadjai
daiheadjai's Avatar
Drives: 2003 S2000, 2008 Fit
I don't find the clutch release bothers me in terms of feel, but does anyone else get this noticeable "zzzt" sound when releasing quickly?
daiheadjai is offline   Reply With Quote
Old 04-06-2014, 05:43 PM   #64
CIAGDDS
Drives: BRZ-L
Originally Posted by ashtray View Post
Does the manual BRZ have a Clutch Delay Valve, or CDD?
been driving manual for 20 years, always rev-match my up and down shifts
Why are you rev-matching while shifting up? You don't need to do that and sounds like it is the issue.
CIAGDDS is offline   Reply With Quote
Old 04-06-2014, 09:58 PM   #65
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Unless you let your for lag on the clutch when upshifting, there's no need to blip on the upshift (that is, lag so long your revs drop below what they'd normally drop to on the upshift).
On phone I am. Therefore, if mistakes I make, Frank Oz blame you should.
^GT5 Replay Photo Mode^
Old 04-06-2014, 11:39 PM   #66
extrashaky
Drives: 2014 BRZ Limited
So everyone can see what you're talking about, here's the exploded view of the master cylinder:
By "oddly shaped," I'm assuming you're talking about the round bit below the cylinder where the diagram says "Clutch master cylinder body." That does look pretty suspicious.
Here's the slave cylinder:
And how it fits in the bigger scheme of things:
Looking at how other CDVs are installed, if there were one in there, my money would be on it being attached to the top end of that flexible hose to the slave cylinder. I don't think we have one.
Old 04-09-2014, 01:22 AM   #67
BradBot
Drives: 2013 DGM BRZ Limited
Any confirmation that there is actually a clutch delay valve on our cars? I happened to come across this thread; it sounds like this spring could be the cause of odd feeling of our clutch engagement: http://www.ft86club.com/forums/showt...t=35621&page=2
BradBot is offline   Reply With Quote
Old 04-11-2014, 07:47 AM   #68
ashtray
As Seen On The Internet
Drives: 2003 WRX, 2013 BRZ, 442
Think cold mornings before the car is warmed up. You're (hopefully) not slamming the shifter from 1-2-3 etc. If you're shifting at lower rpms (again, before the engine fluids are all warmed up), there is fewer rpms differences between gears (35mph in 3rd vs 4th for example). It's very easy to have the rpms falls below that if the next gear.
That said, in more spirited driving I adjust throttle input at the start of the shift and not at the end like when you downshift and rev match. It's just being a little more lazy sometimes with removing the right foot from the gas as you're hitting the clutch pedal. I don't raise the rpms, I just don't let them fall as fast. Just gives you smoother shifts, no driveline jerk, and earlier application of the throttle in the next gear without doing any clutch feathering.
ashtray is offline   Reply With Quote
Old 04-11-2014, 01:22 PM   #69
extrashaky
I do not see any mention of a CDV in the service manual. If we had one, I would expect to see it in that exploded diagram on the previous page, and I would expect it to be connected to the top of the pressure hose between the master and slave cylinders. Unless it's built into that hose or into the master cylinder itself, I really don't think we have one.
That clutch spring sounds like a more likely explanation for the behavior of this clutch. I'm up to 7500 miles on mine, and to me the clutch seems to have gotten better. I don't know if that's because that spring has had a chance to break in or because I have gotten used to driving with such a soft clutch. Personally I can live with it like it is.
Old 04-24-2014, 05:18 PM   #70
BradBot
I'm 11k in and the spring still drives me nuts. I just can't get the feel down, and I feel like I'm learning how to drive manual for the first time. It's very frustrating.
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 12:22 PM
Name that valve cover!!!! FA20???? ESBjiujitsu Engine, Exhaust, Transmission 3 06-05-2012 09:42 PM
Will adding options at the port delay delivery? Liquidsnake Scion FR-S / Toyota 86 GT86 General Forum 6 05-20-2012 06:34 PM
Clutch wear? Pakjk89 Engine, Exhaust, Transmission 102 04-12-2012 07:21 PM
ATS carbon clutch collaboration model prototype clutch 86 & BRZ kanundrum Engine, Exhaust, Transmission 41 02-27-2012 03:48 PM
