#57 |
Drives: ‘16 4Runner, ‘19 Corolla HB
all motor any chance?
I just confirmed on the TIS that this engine does NOT use a hydraulic lash adjuster. It has a solid pivot with a shim to adjust for lash due to machining variance. So, for those of use most likely keeping the engine stock, that means valve jobs as the engine ages or it will tap tap tap. Be prepared to pull the engine to do that.
Sent from Tandy 400 |
#58 |
Resident Gear Head
I do have a set of stock head sitting in the house. I would dissect them but the wife has my schedule already prepared for the evening.
Subaru BRZ/FRS Facebook News and Tech Page
My FB Build page CLICK AND LIKE! Twitter and Instagram @misairubrz |
#59 |
Drives: 2013 Scion FRS
#60 |
Only happy when it rains.
Drives: series.blue
The problem is the oil just can't handle it. Even the 9k element tuning redone engines where they supposedly fixed everything have short lives.
The engine is a massive compromise and so far no one has figured out how to get enough oil pressure into the engine to make it last any length of time for high rpm use. |
| The Following User Says Thank You to why? For This Useful Post: | celek (07-20-2017) |
#61 | |
Señor Member
1974 TA22 Celica
2013 86 GT |
| The Following User Says Thank You to Turdinator For This Useful Post: | celek (07-20-2017) |
#62 |
Drives: series.blue
#63 | |
Señor Member
Yes element tuning did a v8 swap.
1974 TA22 Celica
2013 86 GT |
#64 |
Resident Gear Head
Dry sump is possible but not with all your regular accessories
i.e. lose Air conditioning I may be able to run it on my build only because I no longer have an intake manifold
#65 |
Drives: C5, GT-86, '24 Colorado TrailBoss
Would love to get this car at around the specs of a Alfa Romeo 4C which is right around crank 240hp and 2500lbs. Without E85 close buy and without tearing the internals of the engine ill probably be closer to 230hp crank and 2600. Already knocked 100lbs off with room for another 100 lbs and still have AC and be live able on a daily basis. Its that extra 10-20hp and 100+ lbs that get costly and can turn the car into something you only want to drive on the weekends.
| Seized motor!! What STX mods should I do while I have the motor out?? | BlaineWasHere | Tracking / Autocross / HPDE / Drifting | 27 | 12-11-2014 03:39 PM |
| BRZ or FRS for sale by any chance? | rickfreeze123 | Cars for Sale/Trade | 2 | 11-05-2014 12:22 AM |
| GTI fanboys, here's your chance. | Bg8780 | Other Vehicles & General Automotive Discussions | 72 | 06-10-2014 12:42 PM |
| Did you get a chance to order your BRZ? | kensic | BRZ First-Gen (2012+) — General Topics | 27 | 05-04-2012 07:59 AM |
