Old 01-08-2015, 01:42 PM   #57
vroom4
Next time, or else.
vroom4 is offline   Reply With Quote
Old 01-08-2015, 01:52 PM   #58
AZbrz89
Drives: 14 BRZ Crystal Black Silica Limited
@vroom4 Im interested in some other parts right now. Need lower control arms and rear toe arms. Spc brand is what im gearing towards.
AZbrz89 is offline   Reply With Quote
Old 01-08-2015, 04:36 PM   #59
M23
Drives: 86
How come no one rarely mentions B8 dampers (with good springs)?
B8's suck or something??
M23 is offline   Reply With Quote
Old 01-08-2015, 04:45 PM   #60
vroom4
Just cant get a high enough spring rate
Old 01-08-2015, 06:24 PM   #61
NLSP
NLSP's Avatar
Drives: 2014 Ultramarine FR-S
Because all the cool kids think cheap coilovers are best
Here's a detailed review of Swift springs with B6:
http://www.ft86club.com/forums/showthread.php?p=1962327
RCE Tarmac and B8:
http://www.ft86club.com/forums/showthread.php?t=65467
http://www.ft86club.com/forums/showthread.php?t=68083
NLSP is offline   Reply With Quote
The Following User Says Thank You to NLSP For This Useful Post:
M23 (01-10-2015)
Old 01-10-2015, 08:51 PM   #62
TravelingMatt
Drives: FR-S 10 Series
Originally Posted by KoolBRZ View Post
Before you jump in the deep end, you should try some BRZ coils on the back of your FR-S. I've tried 4 different sets of coil-overs, 1 of them Airlift, and didn't find the comfort I was looking for. If you want comfort, look up a BRZ owner in your area who has upgraded their ride to coil-overs and offer them $20 apiece for their old ones. I'm driving a BRZ with FR-S springs in front, and BRZ springs in back. I've never had a better ride from my car. The struts are all the same, BRZ or FR-S, so you don't need to change those if you don't have to.
Save your money for intake/header/OFT instead.
I have an FR-S and looking for a comfortable lowered ride. Did you lower your BRZ after putting on the FR-S coils? I only want to lower mine 1", so I was thinking of getting BRZ coils like you said and adding H&R sport springs.
TravelingMatt is offline   Reply With Quote
Old 01-11-2015, 01:44 PM   #63
KoolBRZ
KoolBRZ's Avatar
The struts are all the same, it's just the springs which are different. For a comfortable, lowered ride, keep the stock FR-S struts but get the softest lowering springs available, no more than 1" drop, with the softer springs up front. The bump-stops will also have to be trimmed or replaced with shorter ones, and of course your alignment will be off. I had a 1" drop with my HKS Hypermax GT IV's and they rode better lowered than they did at stock height. I'm going to try using my HKS Hypermax GT IV's for a 1" lowered summer setup. Although they come with 59 N/mm front and 38 N/mm rear springs. I'm going to try switching the springs front to rear, because that ratio, (64%, or 38f/59r) is about the same as I'm currently running, (67%, or 23f/34r) with FR-S 23 N/mm front, and BRZ 34 N/mm rear springs, and my car seems to ride better with softer front springs.
I currently have the stock FR-S springs/struts in front, stock BRZ springs/struts in back, Delryn steering rack mount inserts, Camber is 0 LF, 0 RR, 1 LR, and 1.3 RR, Toe angle is 0 LF, 0 RF, .05 LR, and .05 RR. My car steers perfectly on the streets and highways, and even handles pretty good on hard corners, I would definitely switch to my firm setup for the track though.
The Following User Says Thank You to KoolBRZ For This Useful Post:
Mikepage (01-11-2015)
WTB: Coils _frs Want-To-Buy Requests 4 08-28-2014 07:40 PM
08+ wrx coils on a brz? bee_are_zee Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 04-01-2014 07:26 PM
st coils vs stance jdmblood Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 01-18-2014 04:39 PM
St coils vs BC BR? motorsports3 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 11-26-2013 06:01 PM
Need help picking coils WolfsFang Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 03-11-2013 09:31 PM
