#57 | |
Drives: 2014 BRZ A/T Limited
#58 |
Yeah, he was stuck on the auto generate part as OFT would've been based on the 1.5x where there wasn't any for B00D.
Good that there is one for the 2.05 beta, shouldn't have assumed there wasn't one just because he couldn't upload it even after all the pointers to the cal ID.
| The Following User Says Thank You to s2d4 For This Useful Post: | Antstronaut (08-31-2014) |
#59 | |
So Hot Right Now
Drives: '14 BRZ
To be fair everyone was right as there are no auto generated tunes for 1.5x (which is what OFT ships with) as you pointed out. Someone would have to erase the versions currently on the tablet and then upload the new versions in order to have a functioning device.
Installed: | Perrin: Resonated 2.5" Catback, Oil Cooler, Radiator Hoses, Inlet Tube, Filter, and Shorty Antenna | Openflash Tablet | Cusco AOS Catch Can | FBM Radiator | RCE Yellows | Whiteline Camber Bolts & Rear Adjustment Bushings | Michelin Pilot SS | Konig Feathers | Valenti Smoked Tails | ProTeckt Skidplates | Diode Dynamics LED Int/Ext
#60 | |
So Hot Right Now
Drives: '14 BRZ
So don't worry if you don't have the traffic cone like my picture since that is a completely separate and independent piece of software
#61 |
Thanks you guys I'll try soon I'll be home in a hour or so
#62 | |
![]() um do I need romraiders, because that's where im confused romraiders seems werid on my pc.. doesn't update defeinitons |
#63 | |
So Hot Right Now
Drives: '14 BRZ
You will only need OpenFlash Manager software to upload the new versions. [ame="http://www.youtube.com/watch?v=92SV3VpV_1E"]How to Upload Files to OpenFlash Tablet[/ame]
#64 | |
did it for 91 oct and will redo 93 when my tank is on E n I can fill up with the 93.... I let it idle for 2-3mins and than went off to drive...I swear the engine makes a different sound now when around 3-4 RPM I like it
#65 | |
So Hot Right Now
Drives: '14 BRZ
The noise is from the VVT angle being more aggressive to help with the torque dip if I remember correctly and it sure is sexy! Glad to see it's all worked out and welcome to the club!
| The Following User Says Thank You to Antstronaut For This Useful Post: | b1gb2olo (08-31-2014) |
#66 | |
but I heard catless is a lot more power than catted |
#67 |
Drives: Scion FRS
It makes a huge difference. I don't know if it's just me, but I barely feel the torque dip anymore on map 1. It drives very smooth.
#68 |
#69 |
Drives: 2015 Subaru BRZ "Series.Blue"
I am getting the exact same issue here. I just received my OFT this morning and when I go to "read" ECU for the first time I get the same "mode file error". My CAL ID is ZA1JD00C. It appears there ARE maps for my CAL ID in the 2.061OTS maps...however, how to I get the proper READ of the the ecu to begin with? I've tried erasing the data off the OFT and trying again .....but I get the same error.
#70 |
**Nevermind......got the issue resolved
| WTB: Stock MAP Sensor, Stock Frontpipe, Stock Midpipe. | Sterz | Engine, Exhaust, Bolt-Ons | 4 | 07-02-2014 10:22 PM |
| TYC Colin Smoked Tail Lights | Stock FRS Tails | Stock FRS Reverse Bar | BumpersFRS | Exterior Parts (Aero, Lighting, Etc.) | 1 | 01-11-2014 04:42 AM |
| WTS: Airaid Intake System, Stock Exhaust, Stock Radiator Hoses | Sony | Engine, Exhaust, Bolt-Ons | 0 | 11-21-2012 12:10 AM |
| FS: Ecutek Cable, stock axleback exhaust, stock springs | Philly | Canada Classifieds | 4 | 11-02-2012 09:50 PM |
