Old 08-31-2014, 01:13 AM   #57
b1gb2olo
b1gb2olo's Avatar
Drives: 2014 BRZ A/T Limited
Originally Posted by Antstronaut View Post
Update you DO have a map for your CAL ID:
Ok, so I finally am in front of the computer with RomRaider and all of my maps downloaded and can confirm I see a map for B00D. See attached image:
These are for the v2.03 maps so you may have to download those in order to get one with your CAL ID. (See my previous comment for the thread with the releases or click here for v2.05 maps which might include B00D.)
Let me know if you are still having issues and we can go from there.
Ok i 'll try tomorrow I tried downloading that it shows files that don't have an icon next to it
b1gb2olo is offline   Reply With Quote
Old 08-31-2014, 03:20 AM   #58
s2d4
s2d4's Avatar
Yeah, he was stuck on the auto generate part as OFT would've been based on the 1.5x where there wasn't any for B00D.
Good that there is one for the 2.05 beta, shouldn't have assumed there wasn't one just because he couldn't upload it even after all the pointers to the cal ID.
The Following User Says Thank You to s2d4 For This Useful Post:
Antstronaut (08-31-2014)
Old 08-31-2014, 07:24 AM   #59
Antstronaut
So Hot Right Now
Antstronaut's Avatar
Drives: '14 BRZ
Makes complete sense and I was only able to piece it together after looking at my own downloads and confirming one for B00D so I know just where you are coming from
To be fair everyone was right as there are no auto generated tunes for 1.5x (which is what OFT ships with) as you pointed out.
Someone would have to erase the versions currently on the tablet and then upload the new versions in order to have a functioning device.
Installed: | Perrin: Resonated 2.5" Catback, Oil Cooler, Radiator Hoses, Inlet Tube, Filter, and Shorty Antenna | Openflash Tablet | Cusco AOS Catch Can | FBM Radiator | RCE Yellows | Whiteline Camber Bolts & Rear Adjustment Bushings | Michelin Pilot SS | Konig Feathers | Valenti Smoked Tails | ProTeckt Skidplates | Diode Dynamics LED Int/Ext
Antstronaut is offline   Reply With Quote
Old 08-31-2014, 07:27 AM   #60
Antstronaut
So Hot Right Now
Drives: '14 BRZ
The icon will look just like a file or have no icon unless you have something default to Open With, VLC in my case.
So don't worry if you don't have the traffic cone like my picture since that is a completely separate and independent piece of software
Old 08-31-2014, 09:34 AM   #61
b1gb2olo
b1gb2olo's Avatar
Thanks you guys I'll try soon I'll be home in a hour or so
Old 08-31-2014, 12:27 PM   #62
b1gb2olo
b1gb2olo's Avatar
Just got home... going to upload 2.05v maps if I can
um do I need romraiders, because that's where im confused romraiders seems werid on my pc.. doesn't update defeinitons
Old 08-31-2014, 01:44 PM   #63
Antstronaut
So Hot Right Now
Drives: '14 BRZ
You won't need RomRaider for uploading the new versions; RomRaider is for editing tunes.
You will only need OpenFlash Manager software to upload the new versions.
[ame="http://www.youtube.com/watch?v=92SV3VpV_1E"]How to Upload Files to OpenFlash Tablet[/ame]
Old 08-31-2014, 01:54 PM   #64
b1gb2olo
b1gb2olo's Avatar
its flashed did it for 91 oct and will redo 93 when my tank is on E n I can fill up with the 93.... I let it idle for 2-3mins and than went off to drive...
I swear the engine makes a different sound now when around 3-4 RPM I like it
Old 08-31-2014, 02:46 PM   #65
Antstronaut
So Hot Right Now
Drives: '14 BRZ
Make sure you let your ECU learn the new map before going too hard on her. (I.e. fuel trims under 10% both ST and LT.)
The noise is from the VVT angle being more aggressive to help with the torque dip if I remember correctly and it sure is sexy!
Glad to see it's all worked out and welcome to the club!
The Following User Says Thank You to Antstronaut For This Useful Post:
b1gb2olo (08-31-2014)
Old 08-31-2014, 03:06 PM   #66
b1gb2olo
b1gb2olo's Avatar
Now need a header haha but im not sure if I want catless cause of inspections..
but I heard catless is a lot more power than catted
Old 08-31-2014, 09:02 PM   #67
xlid007
Drives: Scion FRS
It makes a huge difference. I don't know if it's just me, but I barely feel the torque dip anymore on map 1. It drives very smooth.
xlid007 is offline   Reply With Quote
Old 08-31-2014, 10:00 PM   #68
b1gb2olo
b1gb2olo's Avatar
Im very curious on 2.0 maps 91 vs 93 on performance, which would be better
Old 09-23-2014, 01:05 PM   #69
UrmyboyBLUE
UrmyboyBLUE's Avatar
Drives: 2015 Subaru BRZ "Series.Blue"
I am getting the exact same issue here. I just received my OFT this morning and when I go to "read" ECU for the first time I get the same "mode file error". My CAL ID is ZA1JD00C. It appears there ARE maps for my CAL ID in the 2.061OTS maps...however, how to I get the proper READ of the the ecu to begin with? I've tried erasing the data off the OFT and trying again .....but I get the same error.
UrmyboyBLUE is offline   Reply With Quote
Old 09-23-2014, 01:10 PM   #70
UrmyboyBLUE
**Nevermind......got the issue resolved
WTB: Stock MAP Sensor, Stock Frontpipe, Stock Midpipe. Sterz Engine, Exhaust, Bolt-Ons 4 07-02-2014 10:22 PM
TYC Colin Smoked Tail Lights | Stock FRS Tails | Stock FRS Reverse Bar BumpersFRS Exterior Parts (Aero, Lighting, Etc.) 1 01-11-2014 04:42 AM
WTS: Airaid Intake System, Stock Exhaust, Stock Radiator Hoses Sony Engine, Exhaust, Bolt-Ons 0 11-21-2012 12:10 AM
FS: Ecutek Cable, stock axleback exhaust, stock springs Philly Canada Classifieds 4 11-02-2012 09:50 PM
