Old 04-27-2015, 02:12 PM   #57
HunterGreene
Hail Magnet
HunterGreene's Avatar
Originally Posted by BRZJunkie View Post
Mine had that exact rust spot 6 months after purchase. Now 18 months I mentionned it to my dealership at the 3rd service and they replaced this vertical metal divider on the driver's side. They said it was covered by the waranty because there was a recall on the part....?
Can't get more info.
BRZ 2013 - In canada
I believe there is a TSB, not a recall.
It has priests in it?
Old 04-27-2015, 02:15 PM   #58
Had my dealer check mine (it was OK) last oil change and they said that it was covered under a dealer "Notice" so not even at the TSB level according to them.
Some dealers may just call everything a "recall" since customers would know the word better than TSB or Notice.
HunterGreene (04-27-2015)
Old 04-28-2015, 08:25 PM   #59
+one
Drives: 2008 VW Passat 2.0T
Cut a piece of 3M black vinyl to size and cover the metal with it. So long as it's not rubbing painted metal it should be fine. Would the windows' up/down motion cause some rubbing as well?
+one is offline   Reply With Quote
Old 04-28-2015, 09:12 PM   #60
2much
I wanna go fast
Drives: 2013 FR-S 6MT
ultramarine for life!
2much is offline   Reply With Quote
Old 04-29-2015, 09:35 AM   #61
HunterGreene
Hail Magnet
That should help. I had a coating put over the pillar when my windows were tinted, seems to be working pretty well too.
The primary mode of wear is mostly from opening and closing the door, and the vibrations that causes. Window opening and closing doesn't have a huge affect on that particular area.
Old 04-29-2015, 09:37 AM   #62
brandonblt2
The Stig's African Cousin
brandonblt2's Avatar
Drives: 2014 wrb brz
I have the same issue except mine is visible without pulling the strip away. I can't even move the strip so it does not seem like rubbing caused it for me. Maybe it was a manufacturer error when they assembled the door
Instagram: brandonblt2
Build Thread: http://www.ft86club.com/forums/showt...86#post2219386
Flickr: brandonblt567
brandonblt2 is offline   Reply With Quote
Old 04-30-2015, 05:42 PM   #63
Zhangy
Drives: 2015 FRS
I'm gonna tape barricade mine asap and prevents the bare metal from being exposed
Zhangy is offline   Reply With Quote
Old 05-14-2015, 11:59 AM   #64
mynameisnick4
Drives: Focus RS (10 Series Prior)
Originally Posted by FRSupra View Post
I just wanted to share, I believe what causes this (obviously as stated above the trim rubbing on the metal) is the vibration from the door closing.
I have taken meticulous care of my car, and it's garage kept and not driven in winter. Sure enough, slight rust is present, but only on the drivers side. I have barely ever used the passenger side door, it's been opened maybe 15 times since I've owned it, and no rust is present.
If you shut the door you can almost watch it happen.
In mine, when you drive down the road with the window down and rest your hand on that spot, you can feel the vibration going to that area which is most likely causing it to rub and rust. I have rust showing on both the passenger and driver side which I am getting looked at tomorrow with my oil change.
mynameisnick4 is offline   Reply With Quote
Old 05-14-2015, 02:29 PM   #65
aghuman
aghuman's Avatar
Drives: 2013 Asphalt FR-S
I checked mine last week and it showed a little bit of rust, showed it to the dealer and they said it is only covered under the 3 year 60k bumper to bumper warranty. I'm out of that range due to km's and they said the corrosion warranty doesn't apply to things like this. Nonetheless Ill just seal it up myself to prevent it from growing/getting worse.
aghuman is offline   Reply With Quote
Old 05-31-2015, 06:13 AM   #66
xmadror
Drives: BRZ Sport Tech 13
Mines aren't as bad as some pictured here but they have started to show some rust. I showed them to the dealership at my last (free) oil change. After they tried and failed to clean it they agreed to replaced both pillars along with my peeling steering wheel.
It seemed to be the 1st time they had to deal with this issue.
xmadror is offline   Reply With Quote
Old 06-01-2015, 04:53 AM   #67
Teclis
Marine Electrician
Teclis's Avatar
Drives: Toyota TRD86, 2014
I got mine fix by Toyota for free
Warrenty is a great thing
Teclis is offline   Reply With Quote
Old 06-01-2015, 12:25 PM   #68
cycleboy
Drives: 2013 Scion FR-S - Argento
Are the replacement ones different somehow, or is this just likely to happen again with the new ones too?
cycleboy is offline   Reply With Quote
Old 06-01-2015, 05:52 PM   #69
FRSHunter
Drives: Asphalt FRS
I've already passed my 36,000 Miles/3 Year warranty bumper to bumper. Would this rust problem be considered under the 60 month/unlimited miles rust and corrosion warranty?
FRSHunter is offline   Reply With Quote
Old 06-01-2015, 05:59 PM   #70
HunterGreene
Hail Magnet
That I do not know...but you definitely can and should try. You can help the rest of us by finding out!
Beware: Excessive rust on suspension parts mav1178 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 11-20-2013 02:22 PM
Small rust spot look a like stain? Bach415 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 23 04-30-2013 02:35 PM
BEWARE DRL TSB! Hawaiian Issues | Warranty | Recalls / TSB 34 03-30-2013 10:21 AM
Rust? even with rust proofing? Chinadian Issues | Warranty | Recalls / TSB 8 01-26-2013 05:15 PM
