Old 05-07-2014, 02:38 PM   #57
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Originally Posted by tinma View Post
all I read in this thread in Electric Supercharger... So I will just leave this here
Yes we all thought that at the beginning until we saw real world numbers and actually tried out the system. Please don't be a douche and post without researching.
As for the @jpit let us know what the dealer thinks and or whats going through your head. This seems like a simple issue to me. I dont think something major went down.
Installed Mods:
Sojhinn is offline
The Following User Says Thank You to Sojhinn For This Useful Post:
raven1231 (05-07-2014)
Old 05-07-2014, 02:40 PM   #58
tinma
Drives: '13 BRZ
wasnt being a douche :P was posting my future build. Please dont post if you have nothing nice to say, ok douche
tinma is offline
Old 05-07-2014, 02:42 PM   #59
jpit
Drives: Subaru BRZ
I have had the ESC for several months and it works providing up to 4.5 psi boost. That video is old and tests stupid products available on ebay. They did not test this product so it's a waste of time to even view it.
jpit is offline
Old 05-07-2014, 02:47 PM   #60
s2d4
s2d4's Avatar
Don't worry bud, it's their lost anyway.
s2d4 is offline
Old 05-07-2014, 02:50 PM   #61
Sojhinn
Sojhinn's Avatar
Aye. Shouldn't feed the trolls. I'll yell at my students instead.
Jpit when you had trouble starting did the phantom on/off switch show a charge?
Installed Mods:
Sojhinn is offline
Old 05-07-2014, 02:59 PM   #62
stugray
Drives: 2013 GBS BRZ Limited
Originally Posted by AVodka14 View Post
I already looked at it, 'genius'. They're weak. End of story.
You are completely clueless.
Hey I Think we should build a solar airplane! Skeptic: "It'll never work"
http://www.cnn.com/2014/04/15/tech/a...solar-impulse/
I want to build tiny capacitors that hold a huge amount of power. EE Professor just a few years ago: "A 1 FARAD capacitor bank would take up a room the size of this classroom"
16 Volt 5000 Farad capacitor bank the size of a small suitcase:
http://www.tecategroup.com/store/ind...102u1vue389q86
Hey I think we should build an electric turbocharger! Skeptic "It'll never work!"
http://www.roadandtrack.com/racing/r...1-tech-details
And Forumla 1 is now using the technology, so they must not know what they are talking about....
So why dont you just .... until you know how to use some manners?
stugray is offline
The Following 3 Users Say Thank You to stugray For This Useful Post:
clayrush (05-12-2014), GT86meMR2 (05-07-2014), Muskokan (05-07-2014)
Old 05-07-2014, 03:09 PM   #63
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
Originally Posted by jpit View Post
Sojhinn,
Was just driving down the highway and went to accelerate but there was no response and the car just died. Try several times to start it and it catches for a split second and then just dies. Doesn't seem like fuel starvation. Haven't had a chance to check the fuses yet but it will be the first thing I do when I get it back.
by catches for a slit second, do you mean it fires but then sputters out? If you really had any battery/alternator problems, It shouldn't turn over or get spark. And unless the compressor turbine has the brake locked on and is restricting air to the engine, the ESC has no other way to interfere with the engine without being triggered. The electronics complicate it, but If you have power to turn it over, and for the spark to cause it to catch, and the air is getting past the ESC, all I can think is fuel.
Hope it is something simple like a sensor.
also, is anyone any good with photoshop, I want a picture of a belt driven mechanical cooling fan pointing at my intake. Then I can point out how forced induction is a complete fraud, since we lack the technology to compress air.
.. extra points if you have a fan at the back of the car infront of the exhaust tips that is linked with a belt/pulley system to the fan in the intake, then we can call turbocharging a fraud too.
Target70 is offline
Old 05-07-2014, 03:22 PM   #64
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
OP, when you tried to restart the car, did the starter motor even crank the engine? If not, did you at least get starter solenoid clicks? Or was it *turn key* -> *silence*?
Depending on which one you got, it'll help identify what WAS working. If you got the starter motor running, then the power systems work. If just solenoid clicks, then not enough battery to run the starter, but the signal was getting there. If just silence, then you've got a short or a blown fuse somewhere. Get a good multimeter and get to work with a continuity tester.
^GT5 Replay Photo Mode^
SirBrass is offline
Old 05-07-2014, 05:46 PM   #65
jpit
Drives: Subaru BRZ
It would almost start then die. Maybe the compressor isn't allowing any air to get through.
I assume the engine would act that way with no air. Rob has recommended to check the PVC hose which I will do. By the way, thanks for all the input. I told the dealer to give it two hours then I'm bringing it home.
jpit is offline
Old 05-07-2014, 05:51 PM   #66
Muskokan
Drives: white Sport-tech
Sounds like fuel/air starvation and/or ecu/ tune problem.
Muskokan is offline
Old 05-07-2014, 06:12 PM   #67
shif7i7down
Erected Member
Drives: frs
HAHA! What's weak is when I get the FMB kit on my car and roll on an ESC. Just a matter of time. I am saving my money for better things bro. Keep talkin.
There comes a time in a mans life when he must quote himself and for me today is that day
Originally Posted by shif7i7down View Post
After reading all the comments, my only wish is that technology would have advanced far enough to the point were we could give e-slaps. I would definitely back hand e-slap some of the idiots posting in this thread
Last edited by shif7i7down; 05-07-2014 at 07:57 PM. Reason: added another quote of the people i was referring to
shif7i7down is offline
The Following 2 Users Say Thank You to shif7i7down For This Useful Post:
GT86meMR2 (05-07-2014), raven1231 (05-08-2014)
Old 05-07-2014, 07:32 PM   #68
AVodka14
AVodka14's Avatar
Drives: 2013 Raven FRS MT
Originally Posted by Boofneenee View Post
Your acting like an idiot. This holds especially true when you stated "only gays buy the ESC" if your such a macho tough guy why did you buy a car with a tiny 2 liter engine?
This type of electric power energy is still in development but used successfully in many of todays applications. I am pretty sure the maclaren p1 uses some type and we have really fast electric cars like the Tesla.
I dont own an ESC but am appreciative of the technology and its growth. So how about you keep your childish comments to yourself and stick with being constructive.
To the OP, have you or the dealer simply tried to uninstall the Esc and put it back to stock. Wiring is fussy and any shorts will cause a car not to work. I feel like you would have heard something explode or pop had it been an engine problem.
Good luck.
I was kidding dude. Relax. I am sure the electric supercharger adds some benefit. Not something that impresses me. That's all. I will be more swift and smooth with stating my opinion next time so i don't upset you.
AVodka14 is offline
Old 05-07-2014, 07:33 PM   #69
AVodka14
AVodka14's Avatar
What's "weak" is your car without one!
AVodka14 is offline
Old 05-07-2014, 07:36 PM   #70
AVodka14
AVodka14's Avatar
Physics class all over again. I thought my pre-med classes were over. It is so much fun messing with some of you guys on here. Relax. I am sure it is helpful in adding a little power. As I stated in to the other sensitive sally above it is just something that I am not sold on nor ever will be. Where would be without electricity? It's genius. F1 just went to V6 from turbo 2.4 L V8. Where does the ESC come in?
AVodka14 is offline
First problem with the STX Brz Simmons Tracking / Autocross / HPDE / Drifting 94 06-23-2014 12:05 AM
Problem with car Atticus808 Other Vehicles & General Automotive Discussions 1 02-19-2014 11:14 PM
A bit of a problem Gost Other Vehicles & General Automotive Discussions 13 02-12-2013 07:07 PM
ABS Problem chrislee2423 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 07-09-2012 04:06 PM
anyone with this problem? debs0712 Scion FR-S / Toyota 86 GT86 General Forum 2 06-30-2012 10:17 AM
