Old 04-08-2014, 05:01 PM   #57
chimera118
Drives: DGM BRZ Prem AT
Originally Posted by CSG David View Post
LOL! RE-11A is a great all-around tire for street and track. It has a good balance of dry and wet grip. The feedback is good and audible and the sidewalls are quite stiff.
Hankook RS3 is the best street tire for dry grip. Dunlop Z2 is close to an RS3, but it's a little peaky. Yokohama AD08R is a great tire, but the grip level isn't quite as good as the RS3, but the wet grip is significantly better than RS3 or Z2. Federal 595RS-R and BF Goodridge Rivals are probably the bottom of the barrel in terms of EHP tires (140-200 TW). They are still much better than your 200+ TW tires, but they aren't as good in the list above.
thanks for the info. would you recommend the RE-11A or RS3 over Pilot Super Sports? i am currently debating between the three. im looking to go with a 245/40 on 18x8.75 wheels.
chimera118 is offline   Reply With Quote
Old 04-08-2014, 06:21 PM   #58
CSG David
CSG David's Avatar
Originally Posted by 53Driver View Post
I agree. Having had a 350Z, S2000 and a Shelby GT500 I think this car has a lot to offer from the factory. This is the first "sports" car I actually plan on keeping for a long time (though I do miss the S2000 at times).
Personally, I've always believed that upgrades should go in the order of tires/brakes, cooling, suspension, wheels and then power adders. Too often I see people jumping right to the big power adders before upgrading the others. My GT500 taught me real quick that big power can become useless without the others upgrades first.
Everything is a balance. Change one parameter and expect to change something else. That's how we build our cars, but everything is methodically thought out and executed.
RE-11A is like a Pilot Super Sport on a higher level. The RS3 has better grip than both tires in dry, but not as good in wet. Everything is a compromise.
Old 04-08-2014, 08:09 PM   #59
chimera118
thanks!
Old 04-10-2014, 10:05 AM   #60
Mikepage
Mikepage's Avatar
Drives: Scion FR-S 2013 Raven
Wheels and tires setup for 1000$
@CSG David , If I have a better budget, what is your opinion about these wheels TSW Nurburgring?
I found some guys on the web who say they are soft wheels...and some others guys who have some vibrations problems on the highway...
What is your opinion?
o= FR-S =o
Mikepage is offline   Reply With Quote
Old 04-12-2014, 11:48 PM   #61
Mikepage
Mikepage's Avatar
Or I can always look for a good set of Enkei PF01?
o= FR-S =o
Old 04-13-2014, 12:45 AM   #62
Kostamojen
Drives: 1993 Impreza w/ WRX Swap + FWD!
You seem to be moving from a $1000 budget up to a $1500 budget...
Kostamojen is offline   Reply With Quote
Old 04-13-2014, 12:58 AM   #63
Mikepage
Mikepage's Avatar
Maybe $700/$800 for tires and $1000/$1200 for the wheels, then maybe around $2000 budget
For my tires, I want g-Force T/A KDW on the oem or on a new set of wheels there is the question
o= FR-S =o
Old 04-13-2014, 01:32 AM   #64
Kostamojen
Then I petition for a thread title change.
Old 04-13-2014, 10:25 AM   #65
Mikepage
Mikepage's Avatar
I don't think I can do this.
o= FR-S =o
Old 04-13-2014, 12:35 PM   #66
bfrank1972
Drives: 2013 FR-S Argento
Nabbed a set of used XXR 530's (18") for $250, nabbed a very slightly used set of 235/40 18" Goodyear F1 Asymmetric 2's for $150. All in including mounting and balancing was under $500, there are deals to be had if you are patient - for instance the asymmetric 2 tires are great all arounders, they are standard equipment on the new Focus ST's. But then you have guys who want to swap them for a more hardcore tire like Dunlop ZII's and the like - often you see them dump the OEM tires for not much money.
bfrank1972 is offline   Reply With Quote
Old 04-14-2014, 10:52 PM   #67
Mikepage
Mikepage's Avatar
Wheels and tires setup for around 1000$ and 2000$
Ok I got it, i renamed the thread like you suggested
o= FR-S =o
Old 04-15-2014, 01:28 AM   #68
CSG David
CSG David's Avatar
Pure preference to be honest. What is the true goal in the end? I ask questions so you can come to a conclusion rather than purchase multiple parts and end up spending much more than your intended budget in the long run.
Old 04-15-2014, 12:27 PM   #69
Mikepage
Mikepage's Avatar
To be honest, at the beginning my goal was to get nice wheels keeping the OEM quality with a good set of tire, street/track...
For the tires am fines, I will take a set of g-Force T/A KDW but thank you for you suggestions, they are into my options list maybe Goethe future.
Then now with a better budget am looking for a good set of wheels...or keeping the OEM because as you said, OEM wheels are very good and solids compared to many cheap wheels.
I found a good deal on :
Gram Lights 57C
Spec:
5x100
17x7.5
Offset 48
Currently On Continental 245 for maybe 3 sessions.
I know, I can't run these type of tires Into the street... But I can finish the thread on the track and put the g-Force after....
o= FR-S =o
Old 04-15-2014, 01:00 PM   #70
CSG David
CSG David's Avatar
Gram Lights 57C
Spec:
5x100
17x7.5
Offset 48
G-Force is a not so good tire...once you get a taste of those higher end tires, you're going to realize what you have been missing out on.
SOLD: OEM BRZ Wheels + tires - 1000 miles - super clean, no TPMS xman11 Wheels and Tires 6 11-19-2013 11:55 PM
Stock Wheels and Tires (Less than a 1000 Miles) Complete Cross Wheels and Tires 4 09-23-2013 01:43 AM
17 in TSW TRACK STAR RIMS WHEELS WITH TIRES LIKE NEW - $1000 Ucmd03 Wheels and Tires 0 08-26-2013 01:52 PM
FS in IL - OEM tires only 1000 miles Captain Insano Wheels and Tires 9 07-21-2013 06:39 PM
FR-S wheels and tires, less then 1000 miles Vonsamhain Wheels and Tires 3 10-29-2012 04:27 AM
