Old 09-14-2015, 11:01 AM   #57
Astroboy
Astroboy's Avatar
Drives: None
Attachment 120215
Attachment 120216
Attachment 120217 I too have Eibach 20mm and 25mm on my BRZ. I think 25mm up front may push the wheel out too far, see photos below.
Do you track or do any hard driving with the spacers?
Astroboy is offline   Reply With Quote
Old 09-14-2015, 12:39 PM   #58
JD001
JD001's Avatar
Drives: Subaru BRZ
Not tracked but will do. Not aware of any issues related to track use. Interestingly when I was in the process of ordering the spacers I was informed that the European spec is different from the American spec as we drive our cars harder....
Old 09-16-2015, 08:46 PM   #59
CenCali86
CenCali86's Avatar
Drives: FRS 10 Series
I did not get a chance to take mine back to the track after the springs and spacers were installed before I sold the car.
I can say the handling got a little stiffer from the sportline drop but it was not too bad for daily use. The Pro sports didn't have enough drop for me personally, although I would guess those are a more track worthy spring. Overall I was still happy with my purchase.
Originally Posted by Astroboy View Post
Have you noticed any differences in handling? Also, do you track with this set up?
CenCali86 is offline   Reply With Quote
Old 09-22-2015, 09:56 AM   #60
Astroboy
Astroboy's Avatar
Drives: None
Would you need alignment after installing spacers?
Old 09-30-2015, 06:55 PM   #61
CenCali86
CenCali86's Avatar
If you are just putting spacers on the car I would say no. If you are dropping the car on springs or coils with the spacers than yes.
Old 09-30-2015, 06:58 PM   #62
Astroboy
Astroboy's Avatar
Drives: None
I'm dropping the car first and then getting it aligned, before installing the spacers
Sent from my LG-D850 using Tapatalk
Old 10-12-2015, 11:49 PM   #63
pcuerpo
pcuerpo's Avatar
Drives: Toyota 86
Send a message via ICQ to pcuerpo Send a message via Yahoo to pcuerpo
got a question.. i currently have extended wheel studs since im using 10mm spacers but i'll be changing back to stock specs (wheels and tires) and i'll be putting those hubcentric spacers
my question is, we only have 20mm hubcentric spacers available locally, can i combine my extended wheel studs and the 10mm spacers then add the 20mm hubcentric spacers? is this possible and safe? otherwise, i'll have to order those 30mm hubcentric spacers if ever this is not possible or safe
2013 Toyota 86
Sterling Silver Metallic
IG: @pcuerpo.images
pcuerpo is offline   Reply With Quote
Old 10-13-2015, 03:21 AM   #64
PeterFRS
PeterFRS's Avatar
Drives: FRS
Here's mine when I had stock wheels on
Tein flex coilovers with 20mm spacers all around
'14 Scion FRS
Tein Flex
TE37
PeterFRS is offline   Reply With Quote
The Following User Says Thank You to PeterFRS For This Useful Post:
Mr.Impreza (01-30-2016)
Old 01-12-2016, 06:57 AM   #65
Paulo86
Paulo86's Avatar
Drives: Toyota GT86 euro version
My gt86.
With eibach pro kit springs, 20mm eibach front and 30mm eibach rear.
Paulo86 is offline   Reply With Quote
The Following 2 Users Say Thank You to Paulo86 For This Useful Post:
Astroboy (01-13-2016), Mr.Impreza (02-12-2016)
Old 01-13-2016, 08:46 PM   #66
Astroboy
Astroboy's Avatar
Drives: None
Originally Posted by Paulo86 View Post
My gt86.
Loving the look. Why not plastidip the wheels black?
Old 01-14-2016, 05:20 AM   #67
Paulo86
Paulo86's Avatar
i'm planning on this for a moment now ^^ never had the time yet :/
Old 01-30-2016, 12:26 PM   #68
Mr.Impreza
Mr.Fujitsubo
Mr.Impreza's Avatar
Drives: 2018 STI
Wow looks perfect...I will be doing spacers also for the stock rims, just will need to figure out width
2018 Subaru WRX STI ~ The Weekend Car ~
2015 Toyota 86 ~ The Sold Car ~ Build Journal
OFT Stage 1 Tune Review
Mr.Impreza is offline   Reply With Quote
Old 01-30-2016, 12:39 PM   #69
86 South Africa
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
Originally Posted by PERRIN_Chris View Post
I have the 25mm spacers all the way around on my car, here's a pic with H&R sport springs next to a lowered car without spacers! Sorry I don't have any pics with the stock springs handy. There's plenty of room though, not even close to rubbing ever.
Any difference in the feel / handling / ride?
I like driving!
86 South Africa is offline   Reply With Quote
Old 02-01-2016, 03:08 PM   #70
PERRIN_Chris
Drives: 2014 Subaru BRZ
Send a message via AIM to PERRIN_Chris
I actually noticed the handling was a little better. The rear end didn't come out so much when I was gunning it around corners, when it normally always would on the stock tires if it was slightly wet outside. It felt nice!
PERRIN_Chris is offline   Reply With Quote
The Following User Says Thank You to PERRIN_Chris For This Useful Post:
Mr.Impreza (02-03-2016)
Best springs+spacers for stock wheels? retrosmiths Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 09-22-2015 09:52 AM
Spacers on all 4 corners / stock wheels (20mm/25mm) zoltiz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 09-14-2015 12:43 PM
Spacers and stock wheel studs solidONE Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 08-31-2013 09:55 AM
Stock Wheels Need Spacers? theom Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 08-17-2013 12:49 PM
Spacers with Stock Wheels Starscream15 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 06-05-2012 02:31 PM
