Old 03-10-2014, 02:21 PM   #57
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
Originally Posted by AustinTX View Post
I do not know what the camber numbers are, as I've never racked the car. It's as much as I could get, so that's all I've got anyway I may get real numbers just for grins at some point, but I don't want to know if it's a bad number right now. Tire wear is very good, so I'm assuming it's fine.
Rear toe is around 1/8" per side and front toe is 0 based on string checks.
Fair enough, I'm interested in finding what type of variation we see in these cars, I know some people have claimed as much as 1.25 degrees with the camber bolts. I'm not surprised nor necessarily unhappy with my 0.95, street tires aren't going to wear shoulders as bad as race tires as long as I rotate them regularly.
Toe wise, I was thinking of going a little less toe in for the rear, but within the same ballpark... but again, no personal experience yet with the new setup. Wont this weather just break already
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop
2007-08: #54 STX 05 WRX Sedan
2009-12: #92 BSP/ASP 07 Solstice GXP
2013-14 : #192 CS 13 Subaru BRZ
Sccabrz192 is offline   Reply With Quote
Old 03-10-2014, 02:40 PM   #58
AustinTX
Pawn in game of life
AustinTX's Avatar
Drives: 19 STX BRZzz
We were talking about rear toe yesterday, and the general feeling is that more would not be beneficial, but the car does need some to account for the soft suspension bushing interaction during cornering. You can definitely feel the rear suspension loading up and deflecting outward on corner entry.
Autocross nut
AustinTX is offline   Reply With Quote
Old 03-10-2014, 03:06 PM   #59
Rexpelagi
Drives: 2013 Subaru BRZ
Originally Posted by Sccabrz192 View Post
John, are you willing to comment on what you've settled on for toe, and what camber values you were capable of achieving?
I measured my camber this weekend after I got the car uncovered and found I am around 0.95 degrees front on both sides with the crash bolts and about 0.8 degrees on the driver side of the rear (couldn't access the passenger side where the car was parked). This is using a longacre bubble gauge with the quickset adapter. I didn't try to level the car in my garage, so there is a bit of a grade towards the front of the vehicle.
Less than 1° is low. You may try getting up on an actual rack?
I know I'm over that by at least a few tenths, and I found some more this weekend I think when installing Konis (haven't been to a rack since I know it is maxed and I have toe plates). There is some play in the top mounts, so you may get a few tenths by loosening the 3 bolts and pushing in the top of the wheel.
What worked for me was to have the camber bolts loose along with the top mount nuts and to use a jack on the hub part of the brake rotor (wheel removed). I didn't apply a lot of force but enough to force all the slop to max negative camber. It is definitely worth a try.
-John L.
2011 BMW M3 - 57 FS
2007 Ford SGT - 57 FS
2013 Subaru BRZ - Sold
Rexpelagi is offline   Reply With Quote
Old 03-10-2014, 03:42 PM   #60
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Thanks. That was just a spot check, so yea, I'm sure the accuracy isn't great considering I didn't bother to check how level the floor was and haven't checked the gauge calibration.
Additionally, the upper mount slop is probably where I could gain more static camber... When I set it up initially, I biased the upper mounts for max caster, which would help improve the dynamic camber curve.
Old 03-11-2014, 11:18 AM   #61
AustinTX
AustinTX's Avatar
For grins, I checked the tread depth on the Z2's yesterday. I've got 45 runs on them (mostly asphalt, averaging 40 seconds each), and they are all in the 7/32 range with very even wear. Not bad.
Autocross nut
Old 03-11-2014, 01:12 PM   #62
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Not bad, how often do you rotate them?
Old 03-11-2014, 01:26 PM   #63
AustinTX
AustinTX's Avatar
Every couple events. They also have maybe 500 miles of street driving to/from events.
Autocross nut
Old 03-31-2014, 01:50 PM   #64
AustinTX
AustinTX's Avatar
The TX National Tour is over, and I got the W! The car was fast and fun, though I did start missing the raw power/fun of the STI at this event. You could probably see my car from space with the new fluorescent yellow livery I tested some stuff during the Friday practice, but I ended up settling on 38F/34R on the Z2's (up from 32R to add some rotation on the grippy concrete). Shocks were left unchanged at .5 down from full stiff up front and 1 up from full soft in the rear. This setting gave the car a nice driveable understeer that was stable enough to be tossed around.
Day 1 was fast and fun. Much rev limiting. I almost DNF'ed the first run, but nice progressive improvements on following runs. My fastest run was still pretty janky and should have used 3rd through the long kinked slalom at least.
[ame="https://www.youtube.com/watch?v=T3CDnt2BYHk"]TX National Tour Day 1 - YouTube[/ame]
Day 2 was faster and funner Much less rev limiting, because I went to 3rd 4 times per run. My fastest run was pretty decent here.
[ame="https://www.youtube.com/watch?v=8qKUyWGS62Y"]TX National Tour Day 2 - YouTube[/ame]
Autocross nut
The Following 2 Users Say Thank You to AustinTX For This Useful Post:
jdrxb9 (04-02-2014), SubiePig (03-31-2014)
Old 03-31-2014, 02:19 PM   #65
SubiePig
Drives: -'02 PSM WRX, '94 Miata, '13 BRZ
Very nice runs, tight and controlled. I see a lot of the places I was giving up time, thanks for posting!
Sponsered by:Chasebays/Corr Performance Tuning/KartBoy/Bad Panda Motorsports/Racer-X Fabrication
STX Build thread 14th/67 SCCA Nationals (2014)
SubiePig is offline   Reply With Quote
Old 03-31-2014, 02:28 PM   #66
vroom4
Well done! Stefan took the win in STX too correct?
I got spanked in CS this weekend...ugh. Hoping its just the cold weather and last seasons rivals.
vroom4 is offline   Reply With Quote
The Following User Says Thank You to vroom4 For This Useful Post:
Old 03-31-2014, 03:09 PM   #67
SubiePig
Yes sir! Found out a lot about the car and tire setups this weekend. John got me on raw time heavily on day one, day two I squeaked by, by only 0.050.
Old 03-31-2014, 03:41 PM   #68
vroom4
Well done. I saw a FB update come through because Im friends with the hymans.
Old 03-31-2014, 06:53 PM   #69
chucky12012
Drives: 2013 Asphalt Scion FR-S
Well done John, sorry I never gave you much of a run! Saturday was a bust, but felt better on Sunday, still never put it all together though. I'll be curious to see how you did in the overall pax results.
chucky12012 is offline   Reply With Quote
Old 03-31-2014, 07:10 PM   #70
SubiePig
http://home.comcast.net/~paxrtp/resu...tour_Texas.pdf
DC's Progression Thread. DC@RoadRace Member's Car Journals 8 11-10-2014 10:22 PM
Henry's C Street (SCCA Solo) progression Kido1986 Tracking / Autocross / HPDE / Drifting 74 05-04-2014 09:20 PM
[Elysiam]Kayhettin's 1st '86 Firestorm 6MT Progression kayhettin Member's Car Journals 1 12-06-2013 09:01 AM
What is your progression with Toyotas? WLY AFRICA 26 11-18-2013 02:08 PM
