Old 02-18-2014, 11:35 PM   #57
Captain Insano
I did find this thread, but not sure which of these options you used. There are a couple different variations in here. Which one of these did you do?
http://www.ft86club.com/forums/showthread.php?t=49634
Your original description of what you did to the intake in your 200whp for $1000 thread...
*For the intake, the only thing I modified was the snorkel. I cut the front bit in half and then widened the remaining duct by heating it up and forcibly opening it up with my hands. Took maybe 15 minutes and didn't cost me anything. But by my accounts, it was worth ~5whp compared to the stock unmolested air duct/snorkel. On the road, the modified snorkel kept logged intake temps only 5 deg F above ambient. By comparison, removing the snorkel completely, intake temps rose up to 20-25 above ambient. With the higher IATs, the car is noticeably less snappy and far more prone to knock retard.
Old 02-20-2014, 09:15 PM   #58
Captain Insano
Bump... @shiv@vishnu and @Robert@vishnu
Any pics or better info on how you modified the intake? I have on intake and don't want to F it up when I make my cuts!!
Old 02-20-2014, 09:32 PM   #59
steve99
http://www.ft86club.com/forums/showthread.php?p=1297833
I think shiv also shoved in a 20oz soda bottle and heated it to expand the intake of the cut down snorkel.
Old 02-25-2014, 07:17 PM   #60
jc2532
Drives: '13 FRS
e85 Logs
Here are my e85 logs. I am not sure what to look for; let me know what you think!
http://www.datazap.me/u/jtchupp/e85-...log=0&data=1-4
jc2532 is offline   Reply With Quote
Old 02-26-2014, 03:20 PM   #61
jc2532
Drives: '13 FRS
nothing?
Old 02-26-2014, 03:39 PM   #62
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by jc2532 View Post
nothing?
Not much to say yet. Doesn't look like you gave it much learning time since the fuel trims are still at 0%. Definitely needs more driving before you can datalog anything useful.
Old 02-26-2014, 04:02 PM   #63
jc2532
Drives: '13 FRS
ok cool, thanks!
Old 02-27-2014, 10:50 AM   #64
Kronos
Kronos's Avatar
Drives: Asphalt FR-S MT
OpenFlash Tablet off-the-shelf E85 Datalogs on stock car
Hello everyone! I got my OFT a week ago and I have been running the e85 tune ever since. So far I've put just over 100 miles on the tune.
I think I know what to look for regarding a few parameters (ie the afr should be as close to 12 during wot as possible) however I still have absolutely no idea what I'm doing sometimes the afr hit close to 20 during cursing which made me nervous. I have no idea if this is acceptable or not. This might have happened when I let off they gas pedal. I don't quite remember but it's in the log.
Here is a log I took yesterday.
A pull in 3rd gear.
Temps were high 20's.
About 100-120 miles on the tune I'd say.
The road was ok at best. Not the smoothest and had very slight incline.
http://www.datazap.me/u/kronos/e85-data-log-1
It looks like my afr went down to around 11.5 in the higher rpms. Was this because i was slightly letting off the gas pedal? I noticed in the log at the higher rpms I started letting off the gas a bit.
Let me now what u guys think!
I'll do another log tomorrow. On a much better road where I will be able to get more clear results
Thanks in advance
Kronos is offline   Reply With Quote
Old 02-27-2014, 03:33 PM   #65
jc2532
Drives: '13 FRS
A pull in 3rd gear.
Thanks in advance
When you let off the gas pedal you're afr should go really high. Afr is the air to fuel ratio. The higher the number the less fuel is being injected and the more air. As you coast, the car drops the amount of fuel to almost nothing since the momentum and the inertia of the car keeps the engine running and not fuel.
Anyway, a high AFR (aka running lean) is normal when you have the throttle closed (foot off the gas). The AFR numbers that you should be concerned about are afaik when the throttle is around 20-30%.
Old 02-27-2014, 03:35 PM   #66
jc2532
Drives: '13 FRS
Also this is why to keep the car in gear while you're coasting. The momentum is keeping the car running instead of fuel. If you're coasting and the car is in neutral, the engine needs fuel to keep running at idle.
Old 02-27-2014, 04:01 PM   #67
Kronos
Kronos's Avatar
Thanks jc2532. That explanation really did help. It was very clear .
I've heard shiv say that what matters are the numbers a WOT.
I'm not saying you are wrong, you sound like you know what you are talking about. I'm just curious why partial throttle is significant as well. I have lots and lots to learn. And I've always heard it's better to keep it in gear while cruising but never knew why. That makes so much sense now.
Also, how do you think my log was looking . During my run in third gear when I was at 6000 rpm and 90% throttle I was around 11.5 afr. Is this normal or is this running a bit low or rich as I should put it. Or was it rich because I was partial throttle? So many questions!! Haha
Thanks for taking the time to explain this stuff. It is very much appreciated
Edit: i think i found my answer in the sticky tuning reference guide thread
"Typically a ratio above 14.7:1 is considered lean where under 14.7:1 is considered rich. The engine application determines the optimal point. Typically tuners will run a richer mix through higher RPMs (more fuel than the engine can burn) to cool the cycle and help catalytic converter performance. "
Old 02-27-2014, 05:31 PM   #68
jc2532
Drives: '13 FRS
I read the thing about the 30% throttle somewhere, I may be wrong. I also am new and have the same questions. I just happened to know about the coasting/fuel cutoff thing from a long time ago. Here is a wikipedia article about it if you wanna read more.
https://en.wikipedia.org/wiki/Energy...ing_or_gliding
when I have time I want to read more into tuning. [ame="http://www.amazon.com/Engine-Management-Advanced-Greg-Banish/dp/1932494421/ref=sr_1_2?ie=UTF8&qid=1393540233&sr=8-2&keywords=tuning+car"]I heard this is a great book to start with.[/ame]
Old 04-18-2014, 08:16 PM   #69
Proof
Proof's Avatar
Drives: 2007 STI Limited / 2014 BRZ Limited
Anyone car to critique this log? 4th tank of E85 and power feels great!
http://datazap.me/u/professor/e85-lo...ta=1-6-7-10-12
Proof is offline   Reply With Quote
Old 04-18-2014, 10:04 PM   #70
Shiv@Openflash
Drives: 2013 FRS
Looks excellent. I'm currently running our Stage 2 car on E85 too. Forgot how good it felt!
Cheers
shiv
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
FS: Openflash Tablet Sgt.Beardface Engine, Exhaust, Bolt-Ons 8 01-04-2014 11:12 AM
FS: Openflash tablet nguyen_er Engine, Exhaust, Bolt-Ons 6 12-30-2013 12:31 PM
new OpenFlash tablet autobrz Engine, Exhaust, Bolt-Ons 5 12-23-2013 09:05 AM
***VISHNU OpenFlash Tablet IN STOCK*** Garrett@Openflash Engine, Exhaust, Bolt-Ons 15 12-17-2013 01:30 PM
