Old 02-26-2014, 07:45 AM   #57
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Originally Posted by Blown_xa View Post
Some have mentioned spool up and other good points to look at. Best spool doesn't necessary mean best transient response and best low end power. A well designed kit will have excellent volumetric efficiency even below the boost curve. PTUNING kit is a great example of this. Utilizing a GT3076r but still making more power as soon as the pedal is depressed, and this is compared to other top kits out there with smaller turbos. It is nice to have an out of the box kit capable of 500whp
I like Ptunings kit, only negatives I see are no diagonal "chassis" bracing due to design and using stock header. I'd be that guy getting the cat breaking down and Effin up the turbo. I understand they have a header of their own in development but meanwhile there is some risk in existing design?
Old 02-26-2014, 11:02 AM   #58
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Risk? Technically yes, but the rate at which the cat will decay and throw things into the turbo is highly unlikely in a new car like this. Albeit I'm waiting on their racing header to pull the trigger on the kit so I can feel safe about it, but @ptuning told me in some PMs that it shouldn't be an issue for a long time.
So the PTuning kit deletes the diagonal chassis bracing? Is there some aftermarket diagonal chassis bracing to add after the fact or would it just be in the way?
Old 02-26-2014, 11:44 AM   #59
Deadspool
Much title. Wow.
Deadspool's Avatar
Drives: 2013 BRZ Sport-Tech
It has already been established that turtles are just as sweet as a turbocharger.
Stay safe, adopt a turtle and name him turbo.
༼ つ ◕_◕ ༽つI PUT A SPELL ON YOU ༼ つ ◕_◕ ༽つ
Deadspool is offline   Reply With Quote
The Following 2 Users Say Thank You to Deadspool For This Useful Post:
jamesm (02-26-2014), Ralph Spoilsport (02-26-2014)
Old 02-26-2014, 11:48 AM   #60
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Before making a decision, I highly recommend you find someone to give you a ride with each setup you're considering. Ask them to start with their foot off the gas, and then "stomp" on the pedal so that you can audibly hear it, and then note how long it takes for the turbo to spool.
^^ this. If I ever go FI that's what I'll try to do, even if it means flying out to california to 'borrow' the CSG car lol
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
CSG Mike (02-26-2014)
Old 02-26-2014, 12:19 PM   #61
jamesm
i would have to disagree with this. i don't often find myself making full-throttle runs from 2.5k rpm in my actual daily usage of the car. i find transient response above 3-3.5k to be a far more important metric of how a given turbo setup performs, in terms of it's impact on real-life driving.
i guess it depends what you're going for in the end, but to me i'd want to base my decision on data gained by replicating how i actually intend to use the car, or will likely use it.
Old 02-26-2014, 01:09 PM   #62
I didn't necessarily mean stomping on the gas at low RPM. It can be done at high RPM, because the test is for transient response.
SirBrass (02-26-2014)
Old 02-26-2014, 01:42 PM   #63
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
I'm more into some slow lorris...name him speedy or something
XXR's? Maybe not right the choice... dem00n Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 12-20-2013 02:32 AM
Rim choice Karl07 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 07-19-2013 07:31 PM
What is your first mod choice? genometuning Scion FR-S / Toyota 86 GT86 General Forum 43 08-31-2012 12:53 PM
