#57 | |
Drives: DGM BRZ Limited
255* sounds about right for the power this engine produces. Now, I can see some 280* cams working wonders for the high revving builds. This engine already has awesome compression, higher revs will really lift power. I can see an easy 20whp coming from relatively "mild" cam upgrades in the future. In a few years time, we will start seeing some big stuff for these cars. Cams/Headers etc with 8500rpm will be a riot. I don't think we're going to see Honda power numbers out there (realistically). The GT86 may get closer, but there are design limitations in play here that will limit power production. However, with a bit of mods I can see surpassing 220whp pretty commonplace. On pump gas. The cams are definitely going to limit power production. |
#58 | |
Drives: 2001 jeep wrangler
#59 |
Drives: AE86, 2x GT86, TE27
It'll do more than 250hp. Can get a 4age to 230hp. Can get a 3sge blacktop beams to 280hp.
But yes time will tell. |
| The Following User Says Thank You to diss7 For This Useful Post: | Dephective (12-28-2013) |
#60 | |
Drives: '13 Whiteout FRS
Stock stroke (lighter forged pistons), wider bore, stock compression (obviously aftermarket pistons), cams mild enough to be streetable but noticeable over stock, titanium valves, springs, retainers, modified stock intake, header, 2.5" exhaust, and closed loop tuning (think Hydra/Haltech EMS) and you will see 240whp and still be streetable. Even accepting current assumptions that bore is very limited to increases, say .1L Not pointless if you''ve already got the motor out to be built anyways, plus the cylinders should be machined and honed properly before a proper build, cost would be negligible and gain would be 10-15hp maybe. Most guys spend a few grand to get that through bolt-ons. Maybe Knife-edge the crank while you've got it out. Rev to 8400, not be Dr. Jekyl/Mr. Hyde like a VTEC Honda, but still scream like an s2000 but make more tq. Sure you may spend a lot doing it, but you would have to seriously fuck something up to kill that motor, and you would have stupid immediate response at the track, and you are already set up for boost if you ever wanted it later on. Side note, unrelated to thread: Anyone who goes lower static compression just to run more boost is thinking backwards. High compression, low PSI boost makes more power with more response with DI than conventional thought of lower compression and throw more boost at it. 15PSI on a GTX30 kit on a motor like what I outlined above would make any dyno queen drool, and that's not even it's efficiency range yet hah.
Previous:
'01 Accord-daily '93 Rx7-fire breathing track monster 545hp 397tq 2300lb. '06 Mazdaspeed6 one helluva love-hate relationship Last edited by Dephective; 12-28-2013 at 03:37 AM. |
| The Following User Says Thank You to Dephective For This Useful Post: | Victor Draken (12-28-2013) |
#61 | |
#62 | ||
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
9. 50-shot of NOS.. 10. 50-shot of NOS.. cos your gonna need two of them.. by tonight Quote:
And yeah, tall poppy syndrome sucks. Too many jealous or resentful people, that's why we can't have nice things. |
#63 |
#64 |
Loving the thread and NA threads like this. I decided the minute I bought this car I wouldn't be doing FI on it. I never have really liked the idea to make NA cars from the factory FI with aftermarket kits.
My thinking, with stock 200 hp at the crank, if I can get anywhere around 250-275 hp at the crank with just bolt ons with pump gas tune that's pretty badass combo for this car at stock weight. Then take some weight off with simple mods getting it down 150-200 lbs. At that point you have a 10:1 lb to chp car at such a light weight it's going to be dang potent as a sports car. At a bargain sports car price. Getting 250 hp at the crank is already very possible on E85 and not far off on pump gas. Once we start seeing cams and head modifications my goals will be cake to achieve. |
#65 | |
Drives: 1997 Eagle Talon TSi AWD
Stroker kit is not possible, will never happen (not enough clearance to make a stroker kit sadly) Cams are not available right now as replacement parts from Toyota so no blanks can be made for machining. N/A power on a 2.0L engine is negligible. It will never hit over 210whp is the most you'll ever see. You can only make big N/A power on big "V" engines unfortunately. It takes $30,000 to build an engine in the VW world on N/A 2.0L to make 200-210whp. Forged pistons+rods, head studs, block sleeves + turbo = the way to go for any substantial power |
#66 |
#67 | ||
And as far as cams not being available, sure the cheapest way is to machine OEM units, but in that case you could always just machine yours. Also, apparently you aren't aware that cams don't have to be machined, they can be made from scratch, which isn't necessarily any more difficult. COMP Cams makes there's from a blank metal rod (with your choice of alloy, forged or cast). Cam design isn't rocket science either, it takes professionals a day, 2-3 tops to design one in CAD once they have the stock dimensions and intended use of the design. I'm sure if wasn't stupid aggressive they would market the design as a "shelf" item and you wouldn't incur development costs. Also like has been stated before TODA Racing is well on the way to offering cams. Even if no stroker kit was possible, cams that breath till 8400rpm (not just possible, realistic low ball) will yield a decent gain in power, and that would still be streetable (this is of course subjective) I actually like the sound of a lumpy cammed out idle. Low end torque is just for fuel efficiency, if I was to pass, just drop down a gear and wind it up.
Previous:
'01 Accord-daily '93 Rx7-fire breathing track monster 545hp 397tq 2300lb. '06 Mazdaspeed6 one helluva love-hate relationship |
| The Following User Says Thank You to Dephective For This Useful Post: | industrial (12-28-2013) |
#68 |
Add lightness!
Drives: 17' WRX
Perhaps DSG has a different definition of "big power". I think most of us staying NA are just looking for ~250whp idealistically. That'd be with every bolt on and a fully built engine. Most big power guys think 300whp isn't enough and it's true that we will never see 300whp+ NA.
#69 | |
Thanks for your condescending tone. "Uh..." However, building a K20 engine that isn't streetable isn't what people are looking for here (cams and springs causing idle oil pressure...). They also aren't making any numbers much higher than 215whp on standard available fuels. Also, 12k to build an N/A engine to make 200~whp is not good in any way. Any FI kit for this car yields higher results for less than half the cost. As for cams, I'm well aware of the manufacturing process. I was speaking more in current availability for this platform. I know that there isn't a huge demanding for cams so I know that some of the larger manufacturers are looking to get new OEM cores to start their prototypes. As of now, you can't buy them as a replacement part. That's not to say someone won't develop them from a blank core but it's not happening anytime soon. You're all worried about voiding your warranties and staying N/A but good luck on a warranty claim running cams, pistons, rods. The bolt-on tunes seem pretty good, don't get me wrong. But staying N/A looking at cams and all these other mods that will yield very little results for high costs isn't in anyone's best interest. The only time N/A will become feasible is when there is an entire after market valvetrain available and the revs can be raised (with a cam of course). Even then, a bolt-on turbo kit at 6-8psi will make more power safely all day long. I ran into this "N/A" issue in the Mitsu 4G Eclipse GT V6 crowd. A big N/A V6 that nothing made a huge difference on. There was a supercharger kit but the company that designed it didn't even make an intercooler for it lol. All in all, N/A is good if you want to run some bolt-ons but don't expect some miracle cam to do anything on an N/A 2.0L. In N/A format, this platform will never exceed 210whp. This is good power and I'd be happy with that, but FI is definitely the way to go for this engine to make any sort of substantial power IMO |
| The Following 3 Users Say Thank You to Jason@DSG For This Useful Post: |
#70 |
Because compromise ®
Drives: Red Herring
This thread should have been called "conjecture".
| The Following User Says Thank You to Captain Snooze For This Useful Post: | Koa (12-15-2014) |
| "Clicking" or "knocking" caused by rear seat pull down lever. | husker741 | Issues | Warranty | Recalls / TSB | 6 | 11-27-2013 03:30 PM |
| "My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") | levifig | BRZ First-Gen (2012+) — General Topics | 48 | 08-09-2013 07:34 PM |
| Which Markets have "GT86" and "Toyota" badges on trunk? | Tanuki | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 02-10-2013 06:23 PM |
| Agency Power Intake?? "FT86 website" | ScionFrsFan | Engine, Exhaust, Transmission | 14 | 12-03-2012 07:25 AM |
