Old 10-26-2013, 03:32 PM   #57
jeebus
Drives: 2015 Mustang GT (on order)
Originally Posted by shiv@vishnu View Post
From the testing we have done, dyno looks the same. But with the earlier map, the brief MAF voltage spikes would make ecu follow the high load cells that had big ignition correction values. This caused the knock activity in the 2500-3200rpm area. The new map just accounts for the MAF spike and limits total timing under load.
Hmm, it feels less peppy down there to me. Seems about the same everywhere else though.
jeebus is offline   Reply With Quote
Old 10-26-2013, 05:36 PM   #58
TopGearSolutions
TopGearSolutions's Avatar
Drives: C6 Corvette Z06
Stage 2 W00T
TopGearSolutions is offline   Reply With Quote
Old 10-26-2013, 09:29 PM   #59
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
I just loaded 1.3b as well and it does seem not to have that pull right before 3k rpms anymore.
Another thing I noticed is the crickets seem to have gotten really loud after loading 1.3b. When I go to start the engine it would chirp very loud on a slightly warmed up engine. The kind of loud chirping that would only show up after being run very hot (track and/or very hot ambient temps) with the factory tune. Not sure if anyone else is also getting this.
Intent > Content
Old 10-26-2013, 10:30 PM   #60
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
You can do a file comparison between v1.3 and v1.31 and you'll see the only change is ignition advance map at moderate to ful load below ~3500rpm. This should only effect ignition advance learning during those load/rpm conditions. Definitely won't make a difference to any cricket noise issue. For those who prefer the feel of the earlier map versions, by all means still run it. Next revision I'll see if we can add more timing down low without sacrificing stability. Buy this is the stuff end users can do themselves once we enable datalogging/viewing.
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
solidONE (10-26-2013)
Old 10-26-2013, 10:45 PM   #61
solidONE
solidONE's Avatar
Awesome! Can't wait for the data logging features. I also noticed that the OFT auto updated something when I plugged it into my laptop to load the new 1.31 map.
Edit: I actually went from 1.2 to 1.31. Did not get a chance to try 1.3.
Intent > Content
Old 10-27-2013, 12:26 AM   #62
SliverBrz
Drives: Silver 2013 BRZ limited
so do i remove the o2 spacer?? anyone?
SliverBrz is offline   Reply With Quote
Old 10-27-2013, 03:15 PM   #63
jeebus
there's no way the tune did anything to your crickets. Probably just some especially ethanol-y gas.
Yeah, I did a file comparison and that's how I found it. I'll leave 1.31 on there for now as I'd rather have a bit more knock correction than that tad bit of extra pep down there. Once datalogging is enabled I plan on testing minor changes to that area.
Old 10-27-2013, 04:10 PM   #64
RSH
Drives: 2014 BRZ Limited
I have 93 here. Any reason i shouldn't just use 1.2 based on your observations of 1.3?
RSH is offline   Reply With Quote
Old 10-27-2013, 05:13 PM   #65
jeebus
I say run whichever one you prefer, and once datalogging is here, fine tune it a bit. If anything, 1.2 still felt safer than the stock tune.
Old 10-27-2013, 10:13 PM   #66
clintavo
I cant find the 2.0 tune. Is it still up?
clintavo is offline   Reply With Quote
Old 10-27-2013, 10:20 PM   #67
tonylop33
Certified Car Nut
tonylop33's Avatar
Drives: 2013 BRZ WRB Limited 6MT
If you download either the 1.2 or the 1.31 beta map files, you will find both stg1 and stg 2 in the zip files.
Prior cars: 2011 GT-R (still owned), 2007 Saleen Parnelli Jones Mustang, 2007 Mini Cooper S, 2004 MazdaSpeed Miata Turbo, 2003 G35 Sports Coupe, 2002 WRX, 2001 Z28 SS, 2000 300ZX, 1995 BMW M3, 1882 Nissan 280ZX, 1981 RX7, 1978 Camaro Z28, 1968 Shelby GT 350
tonylop33 is offline   Reply With Quote
The Following User Says Thank You to tonylop33 For This Useful Post:
clintavo (10-28-2013)
Old 10-27-2013, 10:29 PM   #68
clintavo
Got it. Thanks!
Old 10-28-2013, 12:05 AM   #69
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
@solidONE not sure about cali but i'd imagine winter blend fuels have started showing up in most places. that or just higher ethanol content.
I run ethanol free myself.
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 10-28-2013, 12:24 AM   #70
ck-GT86
ck-GT86's Avatar
Drives: '13 Raven FR-S, MT
Updated to 1.31 today, and decided to add some 101 octane to my tank. I can't get over how fun the car is with the bump in octane, just wish it wasn't so freaking expensive ($7.50-ish a gallon)
Also, I've modified my intake snorkel, see below
http://www.ft86club.com/forums/showp...0&postcount=24
.ck
|| My Build Thread ||
ck-GT86 is offline   Reply With Quote
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
Quick Review-OpenFlash (Dyno Test) - Stock vs. Vishnu Stage 1.0 vs. Vishnu Stage 1.1 FRSTEVE Software Tuning 105 08-04-2017 04:48 AM
anyone trying to use the openflash tablet with forced induction? FRSTEVE Software Tuning 69 12-07-2014 04:07 PM
Is Openflash tablet detectable? Boofneenee Software Tuning 25 05-02-2014 10:03 PM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 08:45 PM
