#57 |
Drives: FR-S stock for now
Yes, if you are a track only car then higher spring rates would be required based on the tire grip patch. Your tire is a spring with a breakaway rate based on the contact patch so the spring rate has to match the tire. The shock can change the speed at which the rate is increased before the break away occurs. I guess that's a long way of saying the more grip the more spring/damping needed. Spiderman cape extra not batman, sticky not slippery.
DougW |
#58 |
The Based God
Drives: 87 Supra, 92 240SX, 13 BRZ Turbo
I think I found what I want...
Milltek Full Exhaust (Overpipe, Cat-delete, Catback), AVO Turbo kit , Perrin Crank Pulley , ACT Clutch Kit , ACT Prolite Flywheel 10.5lb , Axel-Exchange Driveshaft, Sparco Assetto Gara 17x7.5, Hankook Ventus V2s 225/45/17, Michelin Pilot Super Sports 225/45/17, Rally Armor Mudflaps, Viscontiproof tune Courtesy of Drift Office LLC
#59 | |
While I appreciate this and see great benefit in it...
Personally I would not another electronic variable. The concept of re flashing my shocks on a car with a mostly sloppy stamped steel suspension seems over kill. Looking forward to seeing how useful this is however. Quote:
#60 |
I hear you, it's the same efi/carb argument both work in a given window just as well. I wonder what this chassis looks like on a 7 post shaker, maybe I'll call in some favors?
DougW |
#61 |
Now if the spring rate could also be variable...
#62 |
Need an upper/lower a arm suspension for that and use a blade spring with 0.250 of total travel, now you are talking about 1500-2000lb springs and high volume shock valving. Not this week.
DougW |
#63 | |
Drives: 2013 Asphalt FR-S
~Namaste~ Last edited by mad_sb; 08-21-2013 at 01:24 PM. |
#64 |
currently useless vsc sport button
So what's wrong with the vsc button?DougW |
#65 |
That Guy
Drives: 2013 asphalt FRS MT
I have no idea what it does. Honestly, I've tried it once or twice, now I just turn off the traction control all together and be done with it. If you wanted to re-purpose that button I highly doubt anyone buying this system would care.
#66 |
The VSC applies the brakes based on how out of control you are in yaw. It did a good job last winter when I was driving back from Charlotte during an ice storm. Several times I was crossed up and it pulled it back in line, I was playing with it on and off just to see what it does, finally the little picture hung me a bird and hid under the speedo until I got home. Ha Ha but it does work. Maybe include the snow switch for the manuals, don't know the cost.
DougW |
#67 | |
That Guy
#68 |
Seems pretty cool and they aren't super expensive.
Just for giggles I contacted a local company, Magneshock who makes Magneto-Rheological shocks. Right now they only have the ability to pre-program compression/rebound curves, although the controller can store 2500 different profiles, but they said race teams have built their own realtime controller for them. Not cheap though. >$10K.
#69 |
Yea, I've known those guys for 30 years he got screwed out of the MR patent thanks to a military contract. I used to have a business on Buford highway in the 70s/80s before I moved to the SC mountains. MR fluid is neat stuff but is expensive and abrasive, the new Corvette is going to the Bilstein Damptronics both because of cost and warranty issues. With MR you can build the valve stack in software by just using an orifice but at $750 a pint just can't do it for the street market. Illegal in most pro racing.
DougW |
#70 |
Drives: 2013 SWP BRZ
I'll be available for Road Atlanta and Barber testing!
| Anyone ETA on Bilstein coilovers? | Hanakuso | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 53 | 01-31-2014 11:26 AM |
| Bilstein Damptronic on an FRS | DougW | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 16 | 08-10-2013 12:15 AM |
| All Bilstein and Muteki 10% off during month of July! | Infamous Performance | Brakes, Suspension, Chassis | 24 | 07-31-2013 01:52 PM |
| All Bilstein and Muteki 10% off during month of July! | Infamous Performance | Wheels and Tires | 24 | 07-31-2013 01:51 PM |
| Bilstein Shocks | wahsaihin | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 05-23-2013 03:12 PM |
