#58 | |
Drives: 13 SWP BRZ LTD 6MT
| The Following 2 Users Say Thank You to slates74 For This Useful Post: | whataboutbob (08-19-2013), xjohnx (08-19-2013) |
#59 |
Drives: 2013 FR-S, 2016 Miata Club
We'll see how long it takes them to send one out. I'll take pics of the install and give my feedback. I doubt I'll hear any whining if there is any. I'm running a full exhaust. Looking forward to it!
| The Following User Says Thank You to JimmyMac For This Useful Post: | number1Tango (08-21-2013) |
#60 |
Grip>Slip
#61 |
I'm just curious, are these built to order?
#62 |
Just the tip
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
I ordered mine Friday night. They made one Monday and shipped it Tuesday so should have it end of this week hopefully.
Current: 2013 Lightning Red Subaru BRZ Limited
Past (sold): Click here to see previous cars and bikes ![]() |
| The Following User Says Thank You to stockysnail For This Useful Post: | JimmyMac (08-21-2013) |
#63 | |
degrees
Drives: 6MT BRZ
. Last edited by 37; 08-21-2013 at 10:48 PM. Reason: Recovered last sentence |
| The Following User Says Thank You to 37 For This Useful Post: | 8686 (08-21-2013) |
#64 |
Drives: '13 Whiteout FRS
BTW, Aluminum is corrosion resistant. That's one of the desirable attributes of aluminum. For example, marine companies like to use it instead of steel, not only because of the weight, but it takes much higher quality steels to meet the same corrosion resistance of aluminum.
Salt shouldn't be your worry. OEM shaft is more likely to corrode. I'd be more worried about the shaft vaulting me in the instance of a failure. 1 pieces tend to do that.
Previous:
'01 Accord-daily '93 Rx7-fire breathing track monster 545hp 397tq 2300lb. '06 Mazdaspeed6 one helluva love-hate relationship |
#65 |
Mannnnn, no package this week.... I've been shafted!!!
#66 |
Drives: They have four wheels
Can you find out what aluminum they use for the yokes and shaft? Also what tolerances they balance to? TIA.
#67 |
Drives: 2012 GLI
The aluminum used is Alcoa certified 6061. Tolerance for straightness is between .000-.003 and the balance is between .000-.001. Check out Wrist20 on IG to see a video showing the quality or click on the link.
http://instagram.com/p/dVDiLaAqZz/ Last edited by Wrist20; 08-26-2013 at 11:19 AM. |
#68 |
What he said. They also said the ends are forged aluminum and the joints are hd spicer.
#69 |
Look what brown just dropped off. I wonder what it could be?
![]() I'll give you a hint...
| The Following 2 Users Say Thank You to JimmyMac For This Useful Post: | 37 (08-27-2013), FastLane1000 (08-27-2013) |
#70 |
degrees
Drives: 6MT BRZ
| DIY: Driveshaft Shop (DSS) Carbon Fibre Driveshaft | F1point4 | DIY (Do-It-Yourself) Guides | 67 | 04-17-2021 06:21 PM |
| PST vs Driveshaft Shop CF Driveshaft? | RehabJeff86 | Engine, Exhaust, Transmission | 4 | 08-26-2013 01:39 AM |
| DriveShaft's and Axle's | Driveshaft Shop | Engine, Exhaust, Transmission | 34 | 08-21-2013 06:17 PM |
| Driveshaft Shop CF Driveshaft installed. | Hawaiian | Engine, Exhaust, Transmission | 5 | 08-13-2013 03:04 PM |
| GFB 3-Piece lightweight aluminum pulley kit | Touge Factory | Engine, Exhaust, Transmission | 60 | 06-03-2013 02:52 PM |
