Old 09-14-2014, 10:33 AM   #57
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Originally Posted by s2d4 View Post
Where were you thinking of putting it?
Well that's what I was asking @coyote. Seems like the only simple spot would be to relocate the battery to the trunk and then put the water tank where the battery lives. But the thought of that has me thinking the tank will soak with under hood heat. Maybe running the tank in the trunk but then now you have to deal with a bunch more plumbing- not to mention having to upgrade to a more powerful pump to flow more water more quickly.
All in all, it just makes more sense to go with an A2A with this car but it's refreshing seeing something different for a change.
hmong337 is offline   Reply With Quote
Old 09-14-2014, 12:02 PM   #58
s2d4
s2d4's Avatar
The A/CLA/GLA 45 variants also use W2A, running at 1.8bar all day every day.
The amount of water just means higher thermal mass so longer to heat up, what's more important is how heat is being drawn out.
My setup on the AW11 always has the fan and pump on, the worst I've seen is 100 degrees from the supercharger(yes, they run ridiculously hot) and 50 degrees after the cooler (which is what the 45 AMG runs at), this is after 2 hours of thrashing about in 40 degree heat.
Old 09-15-2014, 08:16 AM   #59
coyote
coyote's Avatar
Drives: Slowly
I didn't do this to be different. I am doing it because it is the best solution for this car. My testing already shows that and we are still improving it.
Sent from my Nexus 4 using Tapatalk
coyote is offline   Reply With Quote
Old 09-15-2014, 11:39 AM   #60
xwd
Doug from TopSpeed was just using the washer fluid tank and that's what I was planning on using since it's fairly large and will hold over a gallon. He just had a hose dumping straight into the top of it and then modified the bottom and had the pump mounted down there. I got an extra washer bottle and was going to do the same but put a quick disconnect fluid fitting on the bottom where the stock pump usually sits. The shape is so odd though you can't really access the inside of the bottom of the tank. There is a seam in the middle though so I was going to cut it in half and then epoxy it back together if I can't figure something else out.
Old 09-15-2014, 01:22 PM   #61
hmong337
Emperor JDM
hmong337's Avatar
@dwx
Noble idea but I prefer not modifying anything that hinders street driving duties. That includes using the washer fluid as subbed for a water tank.
Not sure where else I would stick the water resevoir. I'm still on the battery location but with good heat shielding and a lid large enough to dump clumps of ice into the resevoir.
Old 09-15-2014, 05:14 PM   #62
kanundrum
Drives: 2013 Whiteout FR-S
Ptuning hinted at a V-Mount Setup along with a few other serious goodies it maybe on their road map soon enough
Old 09-15-2014, 05:53 PM   #63
xwd
@dwx
Yeah can't beat the battery location.
Old 10-01-2014, 07:29 PM   #64
coyote
coyote's Avatar
Drives: Slowly
Turbo Yoda has been in Japan with the MCM guys, but gets back today. That means airbox version 4 will be completed and the car will be ready for its final tune.
Unfortunately I have to go to Sydney for WTAC, so that won't occur until the end of the month. After a year and a half of prototyping, we are almost finished.
Then track testing (as this has always been about making a turbo BR86 that is good for more than just a few dyno pulls), then it will all go into production.
Old 10-01-2014, 10:26 PM   #65
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
passenger footwell, because racecar
Old 10-02-2014, 02:54 PM   #66
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Can you ask Turbo Yoda if it will work on my Honda?
Old 10-02-2014, 03:21 PM   #67
themajesticone
themajesticone's Avatar
Drives: '13 UM86
Originally Posted by glorydays View Post
how about no intercooler?
Their kit is now for sale on their website
JRSC C30 91 oct | JDL UEL Header | Tomei Overpipe | Milltek Front Pipe | Milltek Catback | SPL LCA v2 | FA 500 v5 Coilovers 6k/7k | SPC Front Camber Bolts | Enkei RPF1 17x9 +35 | 245/40 Michelin Pilot Super Sport
themajesticone is offline   Reply With Quote
Old 10-03-2014, 02:51 AM   #68
coyote
coyote's Avatar
Drives: Slowly
No
Old 11-18-2014, 12:42 PM   #69
hmong337
Emperor JDM
hmong337's Avatar
No
Any progress?
Old 11-18-2014, 01:29 PM   #70
King Tut
NASA SpecE30 Racer
King Tut's Avatar
No
You did know that was a joke from the MCM episode where Moog was annoying Turbo Yoda?
How bad is turbo without intercooler? mid_life_crisis Forced Induction 50 06-23-2013 12:57 PM
2010 Les Paul Traditional $1700 ExWhyZer0 Miscellaneous 5 03-11-2013 06:03 PM
Another turbo with but water to air intercooler ahaghshenas Forced Induction 8 09-24-2012 02:22 AM
