#57 |
Yes, Toyota fr-s
Drives: 1991 MR2 Turbo T-Top, Gen3 3SGTE
Thanks WoW and OrbitalE for your responses... That is what I had in mind. Reducing your rotating assembly’s weight would improve your ability to reach higher revs faster and in theory putting you power to the ground faster.
Sounds more for a NA build (pulleys, flywheel, driveshaft, and all your internal rotating assembly) rather than for a FI application though. |
#58 | |
Drives: Attitude
#59 | |
Opinionated
Drives: Something Red
Most of the cars I drive have nets for windows.
#60 |
Rocket Surgeon
Drives: PSM GGA OMG
#61 |
Yes, Toyota fr-s
I agree, it doesn't have anything to do with the engine. The only reason I said it wouldn't be for an FI'd car is because with added boost, it wouldn't make sence to spend the extra cash on this mod. On NA applications, you want to put the power you have to the ground more effectively since it tends to be lower number than for a boosted car. just a thought, thats all.
Kinna thinking about buying one of these motors before buying the car... |
#62 |
Drives: BRZ(sold), STI
I might be slow, but that the first time I saw a picture of the proper side of strut-to-knuckle bolts. Still not close enough to say 100% there's no camber adjustment. I know MotoIQ claimed there is no adjustment, but they didn't have a proper pic.
#63 |
Drives: ex500r
#64 |
Drives: Sheeveek Si
NASTY looking header, can't wait to see a better design there!
____"In essence they're identical, and identically excellent." Ollie Marriage TOP GEAR____ |
#65 | |||
Drives: car
There are a lot of people in this thread making assumptions or hating on designs they don't fully understand.
What are you talking about? It's separating the exhaust ports according to the firing order. It's basically an OEM 4-2-1 header designed to eliminate interference from the blowdown pulses. That's why the front and rear cylinders combine into separate tubes. How else could you do it besides tweaking the runner lengths a bit? Space is tight... I guarantee you that those headers will last much much longer than almost any aftermarket piece. Look at those flex pipes. It's probably a dual-wall design too, which is better at holding heat in. And yes there is a cat... you can't build a car that doesn't pass emissions standards. So you could pick up a few HP by changing it out for a less restrictive one, assuming that it won't throw a code when you do so. |
#66 |
Drives: Sheeveek Si
"It's probably a dual-wall design too, which is better at holding heat in."
Didnt think! True that, true that! Just not a pretty piece. I was imagining a lythe stainless piece with a much smaller cat since D.I. burns cleaner for emission~
#67 |
Attack By Demons
Drives: 2022 BRZ (pre ordered)
i can't wait either
#attackbydemons #imcomingbackbish
#68 |
Drives: car
I'll agree it's not pretty, but if you take off the heatshields most OEM exhaust manifolds look like that now in terms of the color and the welds.
#69 | ||
Drives: Audi A3
Also, the one piece block is the reason for the "bent" connecting rods. These are needed to ease (maybe make possible) the assembly of the engine. |
#70 |
Rocket Surgeon
Drives: PSM GGA OMG
You are incorrect about it being a one-piece block. It is still formed from two halves, how else would they get the crankshaft in? The asymmetric connecting rods allow the motor to be assembled in the traditional manner, with the pistons, rods and wrist pins put together outside of the block and inserted as a unit. On the EJ, the rods had to be attached to the crank before putting the block halves together with the pistons and pins inserted afterwards as the connecting rod bolts were inaccessible once the blocks were assembled. Having the bolts rotated downward allows them to be accessed from below, this speeds up the production process and makes it cheaper for Subaru.
| Scion FR-S Concept First Official Pics/Videos + NYIAS Pics and Press Conference | Hachiroku | Scion FR-S / Toyota 86 GT86 General Forum | 856 | 06-14-2018 02:53 PM |
| Subframe/Drivetrain Thoughts.... | TrackDog | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 11-10-2011 10:53 PM |
| Dyno testing and "drivetrain loss" | serialk11r | Other Vehicles & General Automotive Discussions | 5 | 11-03-2011 08:55 AM |
| Drivetrain experts! Name this car! :) | aspera | Engine, Exhaust, Transmission | 200 | 08-15-2010 11:41 PM |
