Old 11-21-2013, 05:57 PM   #57
nunonuna
nunonuna's Avatar
Originally Posted by sero901 View Post
Any chance you can describe/picture this. would be much appreciated!
I posted pictures to help. And I will try my best to decribe it. Please understand if I don't make it clear since Eng is my second language. Sorry~
Also sorry for low quality image but the area is too tight.
As you can see, there are two switches. One(second image) pressed in with clutch pedal pressed in & other one(top image) gets pressed with clutch pedal released.
The top one is what you have to deal with. Behind the switch there is harness with wires (part of it shows in one of the pictures).
There are two wires and you need to connect those wires to each other.
I used quick splice (attached picture). NOT t-tap.
This quick splice has one hole closed. And to run the both wires through the quick splice, you need to cut and remove small little plastic wall in splice. I'm sorry I don't know any better way to describe it.
Then you just use that modified splice to grap both wires.
Sent from my Galaxy Nexus using Tapatalk
nunonuna is offline   Reply With Quote
Old 11-21-2013, 06:02 PM   #58
nunonuna
nunonuna's Avatar
If I remember, I will try to draw on the picture and reupload when I get home.
Old 11-21-2013, 06:04 PM   #59
nunonuna
nunonuna's Avatar
Originally Posted by MemphisR View Post
would you be able to use the factory handles in place of yours?
Do you mean door handle?
If so, yes stock handle works fine. You just need to use remote to unlock and lock the door.
Old 11-21-2013, 09:14 PM   #60
Pablitomarrero
Pablitomarrero's Avatar
Drives: FR-S 10 series
any body know how to remove the steering column cover? I already separated the two halfs but I cant remove the clips holding the cloth to the dash as i dont understand the clips...help!
Pablitomarrero is offline   Reply With Quote
Old 11-21-2013, 09:18 PM   #61
nunonuna
nunonuna's Avatar
Carefully pull it hard? That's what I did at least. Lol
Old 11-21-2013, 09:19 PM   #62
Pablitomarrero
From where the rear edges? Just yank it?
Old 11-22-2013, 12:05 AM   #63
MemphisR
Memphis
MemphisR's Avatar
Drives: 1989 MR2 S/C, 2014 Scion FR-S
Sorry, I meant if you were to use the factory keyless entry handles with the built in sensors, in place of your own. I like the product, but I am not overly fond of the buttons.
"It's ok... It's not structural."- Mikey
MemphisR is offline   Reply With Quote
Old 11-22-2013, 11:27 AM   #64
Chaetagnath
Drives: Whiteout FRS
That's a good question. It's something I've thought about trying for a while. If I ever get around to it I'll let you know.
Chaetagnath is offline   Reply With Quote
Old 12-13-2013, 12:44 PM   #65
sero901
sero901's Avatar
Drives: 2014 Scion FRS
Quick note for anyone doing this.... i got the key lock out with the ignition on the car, pulled out a little black piece (thinking it was the steering wheel lock). When did i find out it was not? when i turned the wheel to the other side to put the other screw in. I had to break the plastic to get the ignition back out to remove the lock (when the internals are out the key wont disengage the lock). Just a quick side note! Happy installs! lol
P.S. Thank you OP, don't know how this would have turned out without this DIY!
sero901 is offline   Reply With Quote
Old 12-13-2013, 06:35 PM   #66
Low&Slow
Low&Slow's Avatar
Drives: 10 Series #845
Have these instructions been confirmed to work with an oem push to start system?
Low&Slow is offline   Reply With Quote
Old 12-23-2013, 09:18 PM   #67
trueno86power
[||•]=(86)=[•||]
trueno86power's Avatar
Drives: 2017 Toyota 86
Got a question for Chaetagnath!
I've just finished a remote start installation, everything work fine but the damn door lock just wont work.
I was hook on the door lock switch wire ( At BCM G/Y O/G or at kick panel Blue - Pink ) my remote start give negative output and the timing don't seem to work for the BCM.
How did you hook up your door lock?
trueno86power
GR | TOM'S | TRD
2017 Toyota 86
trueno86power is offline   Reply With Quote
Old 02-22-2014, 07:33 PM   #68
bryan767
bryan767's Avatar
Drives: 13' AVO Whiteout
Wow, great write up! Not sure if I'm going to try to tackle this.
bryan767 is offline   Reply With Quote
Old 02-26-2014, 04:09 PM   #69
SPEEDGOD
I don't lie.
SPEEDGOD's Avatar
Drives: AE86 Successor
Can anyone contact the manufacturer/company I can't reach them
Sent from my SM-N900W8 using Tapatalk
I'll get a Mustang for way less if I wanted more power.
SPEEDGOD is offline   Reply With Quote
Old 02-26-2014, 04:19 PM   #70
Chaetagnath
They usually respond fairly well when contacted at this email address: info@easygosystem.com
easygo, remote start
STI Push Button Start Proud of BOXER Cosmetic Modification (Interior/Exterior/Lighting) 117 08-05-2019 05:19 PM
Push Button start... usptwins DIY (Do-It-Yourself) Guides 155 07-31-2019 11:10 AM
Q: push button start frs blanco Electronics | Audio | NAV | Infotainment 8 08-09-2013 04:58 PM
BRZ STI push to start button notFRS Interior Parts (Incl. Lighting) 4 04-24-2013 12:24 PM
TRD push start button nix Australia Classifieds 1 11-27-2012 12:53 AM
