Old 05-07-2014, 01:56 PM   #57
xxscaxx
Drives: 2013 SWP BRZ
Originally Posted by tim35ct View Post
heres a pic
Man could that be any smaller? LOL
I am actually doing the same thing, but the finish is going to be awesome... nice job though
xxscaxx is offline   Reply With Quote
Old 05-09-2014, 03:39 AM   #58
SilverlightPony
SilverlightPony's Avatar
Drives: '13 Subaru BRZ, '06 Toyota 4Runner
Many steps in a good direction. I'd really want these on the wheel where they're supposed to be, though.
Any word on that WRX wheel?
SilverlightPony is offline   Reply With Quote
Old 06-12-2014, 09:45 AM   #59
xxscaxx
Keep in mind the Wrx wheel also has the cruise control buttons on it. You would have to rewire and solder the circuit board in order to make that switch (did this on my 05 STi with an 08 STi steering wheel). If you didn't you would need to run the cc stalk from our wheel. You also would still have to pass the wires through the clock spring which would mean having to pin new wires into the factory harness on both sides (think there's enough blanks for wires for the radio controls).
It's a lot more involved..trust me lol
Old 10-18-2014, 05:15 PM   #60
DrunkMonkey45
DrunkMonkey45's Avatar
Drives: 2015 Brz Series.Blue
Did anyone ever figure out a nice place to mount the buttons?
DrunkMonkey45 is offline   Reply With Quote
Old 05-06-2016, 11:08 PM   #61
asnatlas
Drives: 2013 - BRZ - SWP
Bump...
asnatlas is offline   Reply With Quote
Old 09-12-2016, 10:00 AM   #62
Julia@SimplicityInSound
Drives: 2013 Scion FRS
These are a set I did with KIA steering wheel controls. Small enough to fit where I wanted, and all the buttons I wanted on the left side of the steering wheel. I molded fiberglass covers around it, wrapped in "leather" wrap, all is working wonderfully. Sometime in the near future, I plan to redo the right side of the cover and mold it around the top half a bit more.
Last edited by Julia@SimplicityInSound; 12-20-2016 at 10:04 PM. Reason: Fixed broken link
Julia@SimplicityInSound is offline   Reply With Quote
Old 09-12-2016, 02:23 PM   #63
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
curious on no tangled wires and how much u had to cut into the wheel itself
lbroskee is offline   Reply With Quote
Old 09-12-2016, 03:03 PM   #64
No tangled wires here. I re-pinned the stock harness going into the clock spring with the KIA SWC harness. Same thing in the column... I added additional pins to the harness running out, and ran those wires to a steering wheel control module behind the radio. As for cutting, I removed about 1/4" or so from the wheel.
Last edited by Julia@SimplicityInSound; 12-20-2016 at 10:06 PM. Reason: Fixed broken link
Old 09-12-2016, 08:22 PM   #65
shaynek
shaynek's Avatar
Drives: BRZ Limited; GR86
Planning on selling? interested in buying a set
shaynek is offline   Reply With Quote
Old 09-12-2016, 08:32 PM   #66
The harness is pretty easy to wire up. I purchased a stock KIA harness and then swapped the plug that connects to the clock spring with the Scion plug, added pins for steering wheel wires and illumination, then added new sleeves to protect the wires. I think the harness is about $22 on ebay. It took 2 weeks to ship from Korea. I also found the controls themselves on ebay for about $20 or less even, from someone in the states. I wouldn't mind doing a write up in the future... I'll probably get around to one when I finish the new covers.
Old 09-12-2016, 08:35 PM   #67
gramicci101
Off Topic
This looks so much better than the 2017 OEM buttons. Great job.
Old 09-12-2016, 09:11 PM   #68
shaynek
shaynek's Avatar
please do a write up. i love the way it came out!
Old 12-19-2016, 04:48 PM   #69
No1der
No1der
No1der's Avatar
Drives: BRZ Limited Satin White
Please do write up!
No1der is offline   Reply With Quote
Old 12-20-2016, 10:07 PM   #70
I will try to create a write-up in the next month... Sorry for the wait, I've been busy.
TRD Steering Wheel DSOmegaX Cosmetic Modification (Interior/Exterior/Lighting) 26 04-30-2016 06:15 PM
WTB: Stock steering wheel (wheel not airbag) mobybrz Interior Parts (Incl. Lighting) 2 09-11-2014 02:23 PM
steering wheel help ft86me DIY (Do-It-Yourself) Guides 3 04-22-2013 04:26 AM
Different Steering Wheel?- NOT? BRZfan Cosmetic Modification (Interior/Exterior/Lighting) 10 03-07-2013 09:01 PM
Volume control with Bluetooth audio finch1750 Electronics | Audio | NAV | Infotainment 5 02-17-2013 04:48 AM
