Old 11-13-2013, 09:26 PM   #57
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
Originally Posted by Rev Works View Post
The only cutting we had to do was cut the stock Fan shroud in half and replace one side of the fans with a slim-line radiator fan which is included in the kit. Other than that the kit works with every other component on the car. The Washer bottle does get removed, due to the Intercooler pipe routing using the space where it would normally be. As James said though, it is as simple as getting a smaller universal bottle and placing it somewhere in the engine bay if one needs to retain the washer bottle.
-Matt
thanks guys!!!!
So if the a larger radiator is installed that means smaller fans required all round?
Yeah to keep the car legal in this nanny state(Queensland) we will require the washer bottle doesn't matter where it is as long as i have one and it has an indicator for how full it is.
Like this more and more... Very keen to see the pricing since we have now seen it meets my goals
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 11-13-2013, 09:34 PM   #58
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by DriftEightSix View Post
thanks guys!!!!
Bigger radiator does not mean needing slim fans on both sides. Most all bigger radiators do not move the fans position in the engine bay, they add the space towards the front of the car.
The Following 3 Users Say Thank You to Sportsguy83 For This Useful Post:
DriftEightSix (11-14-2013), jamesm (11-13-2013), Rev Works (11-14-2013)
Old 03-11-2014, 03:42 PM   #59
Rev Works
Rev Works's Avatar
Drives: 2013 STi
Turbo kit video up!!
[ame="https://www.youtube.com/watch?v=O9h20-ZQ6js"]Rev Works FR-S/BRZ Turbo kit - GTX2867 12psi - YouTube[/ame]
Rev Works is offline   Reply With Quote
The Following 2 Users Say Thank You to Rev Works For This Useful Post:
DriftEightSix (03-11-2014), Sportsguy83 (03-12-2014)
Old 03-11-2014, 04:04 PM   #60
drewdrifter
drewdrifter's Avatar
Drives: 2013 Scion FRS asphalt
So does this mean Ur turbo kit is done and ready?
drewdrifter is offline   Reply With Quote
Old 03-11-2014, 09:12 PM   #61
xwd
How about a dyno plot somewhere in the video? As intriguing as it is watching a car on a dyno...
Old 03-11-2014, 09:20 PM   #62
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Post #50 has plot at end of video.
Old 03-11-2014, 09:22 PM   #63
jamesm
we had some issues with a vacuum/boost leak during the tuning that caused it to go rich on the dyno.. kind of a last minute thing. they'll probably release more dynos of that particular car after we get it dialed in better now that the leak is fixed.
here's mine (same kit) @ 11 and 15psi on e65 to hold you over. wastegate spring wouldn't hold to redline on the higher boost pull.. got a new one coming soon and we'll head back at 20-24psi . as someone said above, there's a plot at the end of the video on post #50 of the kit on pump gas as well.
[ame="http://www.youtube.com/watch?v=k6Ty_5kdBRU"]http://www.youtube.com/watch?v=k6Ty_5kdBRU[/ame]
The Following User Says Thank You to jamesm For This Useful Post:
xwd (03-11-2014)
Old 03-12-2014, 07:09 AM   #64
Sportsguy83
Drives: Limited BRZ
I want a slice of those PSI's!
The Following User Says Thank You to Sportsguy83 For This Useful Post:
jamesm (03-12-2014)
Old 03-12-2014, 01:21 PM   #65
xwd
Seeing your dynojet numbers of around 344whp at 11psi on E65 makes the Revolution numbers of 311 at 8psi on 91 octane seem a little...suspect. But I think that's just due to the generous "sea level correction" being used on their dyno. I also found some old numbers from FBM more inline with the numbers you are seeing.
Sprintex Supercharger Sneak Peak!!! invisage Forced Induction 52 03-03-2013 06:11 AM
A Sneaky Sneak Peak? White64Goat Other Vehicles & General Automotive Discussions 2 02-20-2013 04:03 PM
Sneak Peak Video of Crawfords Turbo BRZ WingsofWar Forced Induction 48 10-18-2012 10:14 PM
Invidia N1 - Sneak Peak **FT-86 SpeedFactory** FT-86 SpeedFactory Engine, Exhaust, Transmission 54 10-02-2012 10:48 PM
Sneak peak at first Aussie turbo kit MZ21 AUSTRALIA 133 09-22-2012 03:45 AM
