View Poll Results: Have you had an issue with your Direct Injection System?
I have had a DI issue and was fixed under warranty (Subaru) 10 12.35%
I had a DI issue that caused Engine Failure and was fixed under warranty (Subaru) 2 2.47%
I have had a DI issue and was fixed under warranty (Toyota) 31 38.27%
I have had a DI issue that caused Engine Failure and was fixed under warranty (Toyota) 3 3.70%
I have had a DI issue and denied warranty by (Subaru) 7 8.64%
I have had a DI issue and denied warranty by (Toyota) 14 17.28%
I had a DI issue that caused Engine Failure and was Denied warranty (Subaru) 8 9.88%
I had a DI issue that caused Engine Failure and was Denied warranty (Toyota) 6 7.41%
Voters: 81. You may not vote on this poll
Old 06-09-2013, 12:57 PM   #57
2forme
Originally Posted by pheoxs View Post
Yes it can, it seems to be happening due the heat from knock/donation during very certain conditions (quickly shifting gears at high rpm). There is a transient ignition map for this and is what is adjusted in the newer software.
I really don't get why everyone is freaking out about this. Do people not remember the cel/cam problem our cars first had, go look in the stickied thread, there were 200+ cases ranging from small fixes to new engines but now we don't hear much about it anymore because it was dealt with, changes were made and now it's not really an issue.
There have only been ~12 members on here that have had seal problems so far. There are 25,000 86s on the road... let Toyota and Subaru deal with the problem just like the last cel problem.
You all bought a brand new platform, with a brand new engine and now lots of you are up up arms that everything isn't perfect from the get go. Everything goes through updates, changes, service bulletins, recalls, that's the trade off for hopping to a new platform right away.
Sent from my Nexus 4 using Tapatalk 2
Carbonblue is right. I know someone with the issue who doesn't drive his car in the manner described. He's not on here but you can send me the questions and I will call him.
Old 06-09-2013, 01:39 PM   #58
fatoni
i think people are freaking out because they bought a new car that had a serious flaw due to the manufacturer and they arent acknowledging the warranty. this leaves them with a car without a motor. 2800 lbs is not too heavy for a car but its an absolute pig for a paper weight.
Old 06-09-2013, 01:41 PM   #59
vtmike
vtmike's Avatar
Drives: Scion FR-S
0.6 seconds is very easy time to achieve an up shift. I find it hard to believe anyone owning one of these cars for any amount of time has not taken it to or near redline and performed an up shift in under 0.6 seconds before getting back on throttle in the next gear.
vtmike is offline   Reply With Quote
Old 06-09-2013, 04:42 PM   #60
Carwhisperer
Drives: A lot of supercars.
Who would want to lug their engine during a spirited drive because they would have to wait just under 1 second to shift into the next gear? I wouldn't want to. Hope they solve this soon. 2 of my DI went out within a month of each other. I have 4 brand new DI's now. We'll see what happens.
Carwhisperer is offline   Reply With Quote
Old 06-09-2013, 08:01 PM   #61
Dezoris
Dezoris's Avatar
I just had my first symptom today. Under throttle I heard what sounded like a high pressure pop come from the hood. like if you popped an air hose off under pressure.
The question is how long before this starts does it cause engine damage.
I plan on taking out the injectors this week to look at them to see the state.
Old 06-09-2013, 08:39 PM   #62
Didn't take our engine very long... less than 2500 combined miles in our case.
We have over 25k miles on our car. Yeah, we drive it a lot (adds up quick when you drop by a lot of meets)...
Old 06-09-2013, 09:42 PM   #63
Dezoris
Dezoris's Avatar
More frustrating is I have to either take all the parts off the car for warranty purposes or just do it myself.
What were the labor times to pull the injectors for you Mike?
Old 06-09-2013, 09:48 PM   #64
Dezoris
Dezoris's Avatar
dbl post hotdogs
Old 06-09-2013, 10:28 PM   #65
I have no idea; the dealer did the teardown, but my understanding is that anyone who's got an enthusiast's experience (aka me) should be able to pull them in under an hour.
Now, putting on new seals/collars is a whole different story.
Old 06-09-2013, 11:45 PM   #66
wootwoot
Drives: FRS
Why is replacing the seals a big deal if pulling the injectors is easy?
wootwoot is offline   Reply With Quote
Old 06-10-2013, 12:01 AM   #67
Dezoris
Dezoris's Avatar
Eyeballing the service manual shows a specific tool to install one of the seals.
Mike do you have all the part numbers for these parts?
Old 06-10-2013, 12:26 AM   #68
wootwoot
Drives: FRS
Someone has already sourced the special tool. One guy bought the actual Toyota one and provided a part number. Another member found a universal tool that he claimed would work. It is in one of the injector issue threads. Can't recall which one at the moment.
Old 06-10-2013, 09:48 AM   #69
Bg8780
Bg8780's Avatar
Drives: '13 Black Subaru BRZ Limited
Had the popping noise again. Happened twice this weekend.
Bg8780 is offline   Reply With Quote
Old 06-11-2013, 09:17 PM   #70
FastLane1000
FastLane1000's Avatar
Drives: White FR-S, 6M
What octane are you running? E10? Any track time? Miles on your car?
FastLane1000 is offline   Reply With Quote
direct injector, engine, failure, meet regal's paranoia, poll, regal's witch hunt, regalnoia, seal, sealions, silly sausage
Injector / seal failure or Miss-fire codes.. please post here mad_sb Engine, Exhaust, Transmission 378 04-24-2020 06:33 PM
Direct Injector Leaking Carwhisperer Issues | Warranty | Recalls / TSB 356 03-13-2020 12:35 PM
Fuel Injector Cleaner Purdue FR-S Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-18-2013 06:54 AM
Wilwood Failure SubieNate Suspension | Chassis | Brakes -- Sponsored by 949 Racing 46 04-09-2013 08:32 PM
Ringland Failure? iLuveKetchup BRZ First-Gen (2012+) — General Topics 9 01-30-2012 12:25 PM
