Old 08-04-2013, 02:38 PM   #57
KONVERTER
KONVERTER's Avatar
See above post...
That is how much of a lip pretty much any car has...
Sent from my Nexus 4 using Tapatalk 4
KONVERTER is offline   Reply With Quote
Old 08-04-2013, 04:58 PM   #58
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
My Enkei RPF1's came from the Tire Rack with Gorilla PLASTIC hub-centric rings. I ran them this way at the track in June. The fronts heated to the point that they warped and glued themselves to the hub. When I used a pliers to remove them, they did come off, but in several pieces. The plastic had no strength left whatsoever after this heat-cycling. They were very brittle and unusably warped.
I like running with hub-centric rings. I just had to replace a stud and lug because of a cross-threaded lug nut. Yes, this could have been my fault – maybe I just wasn't careful enough, but I can tell you it is much easier to not do this sort of thing with a hub centric ring helping to line everything up.
My new plan is to order a set of aluminum alloy hub-centric rings (from the Touge Factory in the previous post – thanks to them as these things are difficult to find), and make sure to put anti-sieze on the hub.
Old 09-02-2013, 09:38 PM   #59
chriscross_tnt
chriscross_tnt's Avatar
Drives: 02 maxima 6spd sold 2013 frs daily
Originally Posted by wparsons View Post
I'm running 225/45's on 17x8's, they fit great. My speed still reads dead on compared to GPS.
offset on the rims?
chriscross_tnt is offline   Reply With Quote
Old 09-03-2013, 10:39 AM   #60
wparsons
wparsons's Avatar
Mine are +45.
flickr
Old 06-29-2014, 12:06 PM   #61
Quentin
Drives: ‘16 4Runner, ‘19 Corolla HB
So, is it my imagination, or does the spoke dip a lot more to the base of the rim on the 45 offset versus the 35 offset? Anyone have a side by side photo? Shame that the 9" wide RPF1s require suspension mods to fit. The clearly look the best.
Quentin is offline   Reply With Quote
Old 11-13-2014, 10:44 AM   #62
astar23
Drives: 2013 Scion Fr-s
anyone got more pics of this set up on stock suspension?
astar23 is offline   Reply With Quote
Old 08-04-2015, 08:44 PM   #63
timmydatooth
Drives: Scion Frs
+1 to more pics on stock suspension. So has it came to a final conclusion which is better offset for our cars? +35 or +45?
timmydatooth is offline   Reply With Quote
Old 11-16-2015, 12:46 AM   #64
perryair
junior mafia
Drives: ‘20 sti limited
got these last week. best combination of looks, affordability, flushness and performance/weight savings and non excessive tire width that i could find.
20 sti limited | 17 bmw m240i | 16 scion im |15 brz limited {prokit, 17x8 +35 rpf1, bfg comp 2 a/s, stg 2, jdl uel, voodoo knob} | 05 honda civic | 06 scion tc | 95 mustang gt | 89 chevy s-10 cameo
perryair is offline   Reply With Quote
The Following User Says Thank You to perryair For This Useful Post:
Mr.Impreza (12-19-2015)
Old 12-19-2015, 09:42 PM   #65
Mr.Impreza
Mr.Fujitsubo
Mr.Impreza's Avatar
Drives: 2018 STI
Wow beautiful! What tire specs are you running?
2018 Subaru WRX STI ~ The Weekend Car ~
2015 Toyota 86 ~ The Sold Car ~ Build Journal
OFT Stage 1 Tune Review
Mr.Impreza is offline   Reply With Quote
Old 12-20-2015, 01:14 AM   #66
perryair
junior mafia
i got bfg comp 2 all season 225/45 17s. they were the right mix of affordable, highly rated and cold weather useful for me. we dont really 'do' winters in tn but it does dip regularly below the acceptable temp for pure summer tires for 3-4 months of the year. theyre a little taller than the stock 215s but its only by about 1% total.
Mr.Impreza (12-20-2015)
Old 12-20-2015, 12:08 PM   #67
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
When you have a chance, I'd be very interested in your evaluation of the BFGs. We don't do winter at all down here, but I hope to take the car on a couple of CC trips in the spring/early summer that have a chance to encounter some cooler temps. I'm sure I could get summer tires warmed up, but I'm drawn the UHP all seasons.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 12-20-2015, 04:18 PM   #68
perryair
junior mafia
well i can only really speak for street driving, i dont autox or track my car. in any way that could truly test them at the real limits. but i can say that they are definitely stickier than the stock primacys though not sure how much that might be due to the added width. when they break away they feel communicative beforehand but they do break away fast right after they tell you that theyre going to. they feel easy to regain grip afterwards as well. the steering feels just as communicative as before and theyre not too loud (though theyve only got about 400 mi on them).
theres a long sweeping highway exit that has a right turn left with height change and i can comfortably take it over 60mph whereas before it would start to break away by then with the primacies. i also have experienced no loss of traction even with the 20-30 degree nights weve been having. dont know how much help that is but id recommend them at least based on my experience so far.
Capt Spaulding (12-20-2015)
Old 12-29-2016, 02:30 PM   #69
skyline r34
Drives: scion frs
Anybody have 245x40 on 18x8.0
skyline r34 is offline   Reply With Quote
Old 10-12-2020, 03:40 PM   #70
dasting
Drives: 2013 BRZ Limited
Data point - Eibach Pro-Kit lowering springs (~1" drop), SPC 14mm lower camber crash bolt at front. -2.4* front camber, -2.0 rear. No spacers. 235/45-17 Hankook RS4s.
2013 BRZ Limited, NASA Instructor, ex-spec miata racer
dasting is offline   Reply With Quote
Wheel Directory: Enkei RPF1 17x9.0 +35 D1cker Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 801 06-18-2024 06:31 AM
Wheel Directory: Enkei RPF1 17x8.0 +45 track_warrior Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 163 03-17-2022 02:00 AM
Wheel Directory: Enkei RPF1 18x9.5 +38 FRS8SIX Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 297 02-15-2018 03:50 PM
Wheel Directory: Enkei RSM9 17x8.0 +48 AsianStyle Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 02-17-2014 06:50 AM
Wheel Directory: Enkei RS+M 17x8.0 +35 FT-86 SpeedFactory Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 37 02-12-2014 04:26 PM
