Old 05-01-2013, 03:35 AM   #57
sw20kosh
Drives: 2013 Black FR-S
Originally Posted by ft_sjo View Post
It would if the leak was after the MAF sensor.
This is what I had in mind. As I said, "metered air"... so anywhere after the MAF.
Old 05-01-2013, 03:53 AM   #58
ft_sjo
Drives: GT86
It's a bit concerning that such an incorrect statement would come from a vendor who supposedly tunes these things.
Old 05-01-2013, 06:34 AM   #59
86pro
Drives: frs
are you serious? Dont knock FA20Club and keep on topic. you guys didnt see the second post? plus i would imagine after your "metered air " is measure by maf the cpu does the rest so yes it doesnt matter. What you think would happen if you didnt have maf in , engine wont run properly. lets keep on topic and hope he gets it fixed soon.
86pro is offline   Reply With Quote
Old 05-01-2013, 07:26 AM   #60
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
First of all, its ECU not "CPU". Second, if your MAF sensor "meters" 10 lbs. of air, it will insert X amount of gasoline into the mix needed to properly mix with 10 lbs of air. If that "metered" air is lost via a leak AFTER the MAF sensor, the car does not know about the leak and it will still input X amount of gas required for 10 lbs of air. This will make an extremely rich condition.
Also, No one here is saying "remove the MAF sensor, or run without MAF sensor".
The Following User Says Thank You to Sportsguy83 For This Useful Post:
ft_sjo (05-01-2013)
Old 05-01-2013, 07:30 AM   #61
Sportsguy83
Drives: Limited BRZ
Originally Posted by whitefrs View Post
John told me that PSI was set to 7.
can this increase just by error
John @Visconti can you please confirm these
Did John tell you boos cut was set to 7, or that the WG spring was set to 7?
Like I initially thought, it seems you are hitting boost cut because that event where the car is building boost and around 4K RPM's it just STOPS and RPM's die down to idle level is exactly what happened to me on overboost.
BUT, you should check all couplers and connections because such a high AFR (8) does seem like you might have a boost leak after MAF.
Old 05-01-2013, 08:09 AM   #62
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
+1
SloS14 is offline   Reply With Quote
Old 05-01-2013, 10:16 AM   #63
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
The one time I have blown a coupler off with my FBM kit, it was the throttle body coupler that came off.
Old 05-01-2013, 10:21 AM   #64
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
But what i dont understand is how did a coupler or anything came loose when i was not using the car
Old 05-01-2013, 10:26 AM   #65
King Tut
NASA SpecE30 Racer
King Tut's Avatar
The couplers come loose when you hit boost.
Old 05-01-2013, 10:32 AM   #66
ft_sjo
Drives: GT86
I assume the TB isn't swaged as it was never designed for boost?
Old 05-01-2013, 10:36 AM   #67
King Tut
NASA SpecE30 Racer
King Tut's Avatar
It has a lip at the end to help the coupler and clamp, but it isn't as big as the rolled lips on the piping in the kit.
Old 05-01-2013, 10:39 AM   #68
rusty959
Drives: DGM BRZ limited
My suggestion:
Stop driving the car for a few days. In those few days, spend all the time you can learning about turbo systems, how they work. All the while be going to your car with the hood popped to figure out where everything is. Know how everything works. Have slight ideas what might happen if any piece were to fail. Then while you are at it, learn what everything else in the engine bay does.
At the end of these few days, figure out how to make a boost leak checker. You can get the parts at lowes for like $30. Check if you have a boost leak. If there are some, fix them, see if the problem still happens, and then report back.
Here is an example of one:
[ame="http://www.youtube.com/watch?v=atretf9u-Mc"]Boost Leak Tester DIY - YouTube[/ame]
I didn't watch the video to see if its actually good, so look around and decide the best way you want to do it. Regardless, no turbo car should be without one.
rusty959 is offline   Reply With Quote
The Following 2 Users Say Thank You to rusty959 For This Useful Post:
Sportsguy83 (05-01-2013), xxscaxx (05-01-2013)
Old 05-01-2013, 11:31 AM   #69
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Thanks for you help guys
My friend owns a turbo honda and he knows his stuff so he will check it today.
Old 05-01-2013, 11:35 AM   #70
mad_sb
Drives: 2013 Asphalt FR-S
lets say im driving and then when i hit boost the car slows down and looses all the power.
im not sure how to explain it
I'm guessing boost leak.. and possibly borked clutch.
91 MR2 Turbo with KO Racing GT35R for sale/trade for FR-S turbo kit Unleashed Cars for Sale/Trade 8 02-20-2013 06:26 PM
No CEL problems here BRZranger Issues | Warranty | Recalls / TSB 41 12-08-2012 01:36 PM
Turbo Tuesday 12/4/2012 (Dynamic Turbo Miami) F3dzo Southeast 46 12-06-2012 01:49 PM
Using Subarus other turbo Boxers as an idea, how much HP could a turbo BRZ/FR-S have? HitTheGas BRZ First-Gen (2012+) — General Topics 12 02-21-2012 01:24 PM
Geneva Preview: Techart to debut 911 Turbo, Turbo S vh_supra26 Other Vehicles & General Automotive Discussions 1 02-22-2010 06:20 PM
