Old 06-05-2013, 12:07 PM   #57
SeeSharkySwim
SeeSharkySwim's Avatar
Drives: Scion FRS
remember that oils with elevated levels of zinc such as 300v can negatively affect the catalyst substrate
SeeSharkySwim is offline   Reply With Quote
Old 06-05-2013, 02:43 PM   #58
bluesubie
Actually, it's the phosphorus that can negatively affect the catalyst substrate: http://www.gf-5.com/the_story/performance/
Although I think this is a bit exxagerated. You have to be burning a lot of oil for it to even get to the cat. If it was that big of a problem, then nasioc, iwsti, legacygt.com, bobistheoilguy.com, any many other enthusiast forums, would be full of failed cat threads due to running mixed fleet gas/diesel oils like Rotella T6.
Some race oils contain reasonable amounts of phosphorus, while some oils (like Red Line's pure race oil) have much higher levels (double the amount of their street oils).
I'm currently running Motul 300V 0W-40 which has 975 ppm's of phosphorus (according to Blackstone virgin oil analysis), while the API SN Mobil1 0W40 that I've run in the past contains 1,000 ppm's of phosphorus (according to Mobil1.com). OTOH, I believe that Mobil1 Race Oils have high levels similar to Red Line's pure race oils. Miller's Nanodrive has p levels slightly higher than 300V, IIRC.
:happy0180:
-Dennis
bluesubie is offline   Reply With Quote
Old 06-05-2013, 06:06 PM   #59
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
Originally Posted by AZP Installs View Post
We've been doing oil changes on Subies for 10+ years.
Over that time we've done 6,000+ oil changes on Subies.
We've found Mobile 1 and Subaru Synthetic to consume the most amount of oil between changes, on average about 1Q per 3,000 miles. While Motul 8100 C3 X-Clean 5w30 and Amsoil 5w30 both generally go 5,000-7,000+ without consuming any oil or <1 Quart and still yield great blackstone results.
-Mike Paisan
11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts.
Call directly as We carry almost every manufacturer now, so before you buy parts call us.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
which mobile 1 oil were you using? regular? extended performance? race?
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
Old 05-12-2014, 09:00 AM   #60
mister.bond
Drives: BRZ Subaru
Please to all :
I want only to know one thing
CAN I USE the 300V 0w20 Oil for my BRZ Streetcar/ Dailydriver
without damaging my Engine or other things on my car ?????
YES or NO
Greetings Thomas
mister.bond is offline   Reply With Quote
Old 05-12-2014, 09:14 AM   #61
bluesubie
Originally Posted by mister.bond View Post
Please to all :
YES or NO
Greetings Thomas
Like with many things in life, there are no guarantees.
Well, you likely will not damage your engine, but specs like ILSAC GF4/GF5 and ACEA C3 (which 300V does not meet) have maximum limits on phosphorus as to prolong catalytic converter life. IMO, you would need to be burning a fair amount of oil for it to get to your cats in the first place.
I've run nothing but GF4 and GF5 oil in my naturally aspirated 2000 Impreza 2.5RS and had to have the cats replaced. OTOH, I've run mainly higher SAPS oil in my 2004 Forester XT and haven't had any problems. One gentleman on bobistheoilguy.com has been running high ZDDP HDEO/diesel oil in petrol cars since the 1960's with no problems!
-Dennis
Old 05-12-2014, 09:27 AM   #62
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
Please to all :
YES or NO
Greetings Thomas
What change interval?
What kind of driving.
What mods?
It is not rated for these cars so if you do damage it, SOA is not going to cover it. I know that Dennis will argue but Motul tech dept has advised us to not use the 300v in extended interval changes for street cars that heat cycle often. It is meant as a racing oil.
Personally in a street car the 0-20 Motul x series will be more than enough IMO.
Mike
AZP Installs is offline   Reply With Quote
Old 05-12-2014, 10:38 AM   #63
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Please to all :
YES or NO
Greetings Thomas
It has been argued that 300V and other race oils will last 3000 race miles and up to 7500 street-only miles. Read this: http://www.ft86club.com/forums/showt...14#post1657614
There are some race oils that are perfectly safe to run in a street car. Millers Nanodrive is one of them. I trust the engineers selling Millers oils here in the US and that's why I've been running their Nanodrive race oil in my car since last summer and it has been great through 3k miles and 6 track days. I will be changing mine around the 3k interval going forward since I track my BRZ often. The verifiable 6 WHP gain from just an oil change is nice too.
Old 05-12-2014, 11:39 AM   #64
AZP Installs
I'm planning to do 3k changes on my BRZ which sees 2-3 track days a month and about 700/wk in DD miles. So at that rate, I'll be changing it about 1x a month with 2-3 track days on the oil.
-Mike Paisan
Maintaining, Modifying and Educating TriState Enthusiasts since 2001.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs
Old 05-12-2014, 03:45 PM   #65
bluesubie
What mods?
Mike
mister.bond does not care about SoA.
It is not API certified but 300V can safely handle a 5-6k mile interval. It is fine to use as a street oil and we have uoa's on this forum to back that up.
Sorry, but you cannot prove to me that it cannot handle a typical street/tracked interval of 5-6k miles, regardless of who you're speaking with. Is it overkill for most applications? Absolutely. Will Motul Eco-lite 0W-20 be fine for most intervals here and up to Subaru's/Toyota's 7,500 mile maximum interval (longer than 300V)? Absolutely.
BTW, there are no "x-series" oils in the Motul line-up that are 0W-20. The only 8100 oil by Motul that is a 0W-20 in N. America is Eco-lite. Is there a new oil that's not on Motul's web site? Or maybe you're thinking of X-clean 5W-30 and 5W-40?
http://www.motul.com/us/en-us
-Dennis
Old 05-12-2014, 03:55 PM   #66
gramicci101
Off Topic
I'm planning to do 3k changes on my BRZ which sees ... about 700/wk in DD miles.
36,000 miles a year? That's impressive.
Old 05-12-2014, 04:27 PM   #67
AZP Installs
Yup 36-40k a year. I put 20k on my touareg diesel since nov 1 already.
Mike
Old 05-12-2014, 04:30 PM   #68
gramicci101
Off Topic
Is there an Iron Butt association for cars, or is it just for motorcycles?
Old 05-12-2014, 04:34 PM   #69
AZP Installs
-Dennis
Sorry was referring to the x-lite 0-30 which would be the closest to the 0-20 required.
I'm not going to get in a pissing match with you but if a manufacturer of said oil doesn't recommend it for street use I am going to advise them as such. Unless you and your uoa's would like to take on the liability by recommending something the manufacturer doesn't even recommend.
Mike
Old 05-13-2014, 03:58 AM   #70
mister.bond
Drives: BRZ Subaru
so, i want to change oil EVERY 3200 Miles
( that is round about every 5000 Kilometer in Germany )
So, then i can Use the 300 V ? and even the Protection is good enough ?
i know i want 0w20 , but i want to choose the correct one without looking
at the costs.
"Come Race Me Bro" Encounters GH05T FR-S / BRZ vs.... 2565 02-28-2023 09:34 AM
New 4-2-1 Long Tube Header Anorexic 86 Engine, Exhaust, Transmission 28 08-25-2013 03:28 PM
WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset GC GTS Aero Kit Australia Classifieds 16 03-22-2013 05:49 AM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 05:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
