#57 | |
Drives: '14 DGM BRZ Limited 6MT
#58 | |
Drives: 2014 Subaru BRZ
#59 |
FRS 10 series #0239
Drives: #0239 FRS 10 series silver ignition
any pictures of ride height before and after on Stock wheels? the after pictures aren't reachable
Drop in K&N filter, CX Racing oil cooler, Tomei Expreme UEL headers, Invidia N1 Catback, OFT stage 2, Raceland coilovers, stage one Exedy clutch kit, Stoptech drilled and slotted rotors and Hawk HPS street pads
10 series #0239 |
#60 |
Drives: 2013 SWP BRZ
Any help is appreciated!
I installed Tein Street Basis Z coilovers last weekend. Like the regular street basis, the design reuses the stock top hats and the height adjustment also effects the spring preload. One thing that has me confused is when installed, i set the height at about 5 or 6 threads (30%-40% from all the way down) just for a starting point, with the car in the air and suspension at full droop, the spring was still loose. There is no preload at that height. I had to raise the height adjustment collar to half way up the threads (about 10 threads) to reach any level of spring preload. Because of this, my front end is barely lower than stock height. I'm not necessarily upset about the ride height, it just seems like i did something wrong. Since it doesn't make sense that Tein would design it where the bottom half of their allotted height adjustment shouldn't be used since there isn't any preload. |
#61 | |
Drives: 2014 FR-S
The spring being loose is OK because once you do put the car on the ground, the shock will get shorter putting normal compression on the spring, this system is design to do that. With that the car will never see that much shock travel to loosen the spring to what you saw when it was up in the air. You could put the collars all the way to the lowest setting and still be OK, just as an example you don't have to do this. |
| The Following User Says Thank You to KnightRyderx2 For This Useful Post: | Goya (03-23-2017) |
#62 | |
![]() I've heard that from a few people but I wanted to make sure. You can see why it made me feel uneasy. |
#63 |
Drives: 2014 FR-S
#64 |
Drives: 2013 Scion Frs
To OP what springs did you use to lower the street basis z even more for the fronts? I’m currently on max settings for the front and wanted to go a little bit lower
| Tags |
| kevin@rad |
| Tein Street Advance BRZ/GT-86/FR-S Coilovers Released in Japan | JSC Speed | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 76 | 08-13-2014 09:50 AM |
| Tein Street Basis coilover, Koni struts and shocks | JoeBoxer | Brakes, Suspension, Chassis | 6 | 12-25-2012 10:43 AM |
| Syd: 2nd Hand Tein Street Advance Coilovers $900 | 86drift | Australia Classifieds | 4 | 12-19-2012 12:04 AM |
| TEIN Street Basis Coilovers for BRZ/FR-S at Redline360 | Redline360 | Brakes, Suspension, Chassis | 2 | 07-05-2012 09:36 AM |
