| Off-Topic Lounge [WARNING: NO POLITICS] For all off-topic discussion topics. |
#57 | |
F Z1LLA
Drives: Lexus IS-F Series 2
hmmm I'm not an expert with Jailbreaks by any means. But if it were mine, I would probably back everything up and do a full restore via itunes. Then try latest Jailbreak 1.2
2URGSE |
#58 | |
Drives: Argento FR-S
If you take a picture of the list of things your have installed and post it here, I'll probably be able to tell you your problem |
#59 |
Drives: nissan frontier, DGM MT BRZ
This is what i have installed Sent from my iPhone using Tapatalk |
#60 |
Im almost 100% sure its the BlurriedNCbackground tweak. I installed a couple of NC tweaks and it made my iphone crash. You might want to uninstall and see if that fixes it. You have the iPhone 5 right?
#61 |
yes i have a 5. the weird part is ive had that since monday my phone didnt start crashing till the update. ill try it tho!
#62 |
ive already been told by a friend only install one thing at a time to try test it and see if it makes the phone crash and what not so i have been doing that.
#63 | |
If you're going to be installing a lot of tweaks, be sure to snap a picture of all the stuff it installs with it. For Instance, if you install lockinfo, it also installs a bunch of other packages with it. BUT if you delete lockinfo, it will NOT delete those "dependencies" with it. Dependencies can also be the problem. |
| The Following User Says Thank You to DBacon1052 For This Useful Post: | Lee358 (02-10-2013) |
#64 | |
#65 | |
What you do is go into your packages and you find "Mobile Substrate" and you remove it. Mobile Substrate is basically the foundation for all of the tweaks on Cydia. When you remove it, it will erase almost everything you have installed through Cydia (including the dependent packages that may be causing the crash) Do these steps 1. Click on mobile substrate and click modify then remove 2. Click on continue queuing 3. Click on mobile substrate again and click modify then reinstall 4. You should now see a bunch of packages in the remove section and mobile substrate in the reinstall section 5. Hit confirm This is basically just a way that you can restart from scratch without actually restoring and re-jailbreaking your phone. |
#66 | |
#67 | |
Drives: toyota
See more: Six Disadvantages of Jailbreak Released by Apple Last edited by ericerjames; 01-01-2014 at 04:17 AM. |
#68 | |
Drives: 2013 10 series FRS #944
| iPad Mini dash kit for FT86 | Esoteric | Electronics | Audio | NAV | Infotainment | 92 | 08-04-2014 08:54 PM |
| iPad mini - now a possible replacement for the stereo. | kappaknight | Electronics | Audio | NAV | Infotainment | 32 | 02-12-2013 12:59 AM |
| Anyone have an iPad mini | rmjjensen | Electronics | Audio | NAV | Infotainment | 14 | 01-08-2013 05:42 PM |
| Iphone/Ipod USB Connection | russv | Electronics | Audio | NAV | Infotainment | 3 | 07-31-2012 11:07 AM |
| iPod/iPhone connectivity? | Tomcat9700 | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 01-08-2012 07:45 PM |
