Old 02-09-2013, 07:27 PM   #57
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
Originally Posted by Lee358 View Post
I keep going into safe mode every once in a while since i did the update.
hmmm I'm not an expert with Jailbreaks by any means. But if it were mine, I would probably back everything up and do a full restore via itunes. Then try latest Jailbreak 1.2
2URGSE
JPxM0Dz is offline   Reply With Quote
Old 02-09-2013, 08:37 PM   #58
DBacon1052
DBacon1052's Avatar
Drives: Argento FR-S
What do you have installed? Some apps are not iOS 6 compatible
If you take a picture of the list of things your have installed and post it here, I'll probably be able to tell you your problem
DBacon1052 is offline   Reply With Quote
Old 02-10-2013, 12:55 AM   #59
Lee358
Lee358's Avatar
Drives: nissan frontier, DGM MT BRZ
Size:  136.0 KBName:  ImageUploadedByTapatalk1360475712.550457.jpg
Size:  140.8 KBName:  ImageUploadedByTapatalk1360475719.267175.jpg
Size:  135.0 KBName:  ImageUploadedByTapatalk1360475725.733792.jpg
Size:  143.9 KBName:  ImageUploadedByTapatalk1360475732.650598.jpg
This is what i have installed
Lee358 is offline   Reply With Quote
Old 02-10-2013, 01:03 AM   #60
DBacon1052
DBacon1052's Avatar
Im almost 100% sure its the BlurriedNCbackground tweak. I installed a couple of NC tweaks and it made my iphone crash. You might want to uninstall and see if that fixes it. You have the iPhone 5 right?
Old 02-10-2013, 01:06 AM   #61
Lee358
Lee358's Avatar
Originally Posted by DBacon1052 View Post
Im almost 100% sure its the NCBlurriedbackground tweak. I installed a couple of NC tweaks and it made my iphone crash. You might want to uninstall and see if that fixes it. You have the iPhone 5 right?
yes i have a 5. the weird part is ive had that since monday my phone didnt start crashing till the update. ill try it tho!
Old 02-10-2013, 01:07 AM   #62
Lee358
Lee358's Avatar
ive already been told by a friend only install one thing at a time to try test it and see if it makes the phone crash and what not so i have been doing that.
Old 02-10-2013, 01:20 AM   #63
DBacon1052
DBacon1052's Avatar
Yes thats unfortunately how you're going to have to do it. Especially for this jailbreak because its not only a new firmware, but a completely different phone with new processors and pixel ratios.
If you're going to be installing a lot of tweaks, be sure to snap a picture of all the stuff it installs with it. For Instance, if you install lockinfo, it also installs a bunch of other packages with it. BUT if you delete lockinfo, it will NOT delete those "dependencies" with it. Dependencies can also be the problem.
The Following User Says Thank You to DBacon1052 For This Useful Post:
Lee358 (02-10-2013)
Old 02-10-2013, 01:25 AM   #64
Lee358
Lee358's Avatar
ahh ok great info to know! thank you!
Old 02-10-2013, 01:33 AM   #65
DBacon1052
DBacon1052's Avatar
If it does not stop the crashing, you can do one other thing, but it kinda sucks.
What you do is go into your packages and you find "Mobile Substrate" and you remove it. Mobile Substrate is basically the foundation for all of the tweaks on Cydia. When you remove it, it will erase almost everything you have installed through Cydia (including the dependent packages that may be causing the crash)
Do these steps
1. Click on mobile substrate and click modify then remove
2. Click on continue queuing
3. Click on mobile substrate again and click modify then reinstall
4. You should now see a bunch of packages in the remove section and mobile substrate in the reinstall section
5. Hit confirm
This is basically just a way that you can restart from scratch without actually restoring and re-jailbreaking your phone.
Lee358 (02-10-2013)
Old 02-10-2013, 05:54 PM   #66
Lee358
Lee358's Avatar
Do these steps
5. Hit confirm
I just did this rebooting my phone now
Old 11-26-2013, 01:28 AM   #67
ericerjames
Drives: toyota
Originally Posted by jshadeck View Post
Check google, theres alot of really good blog posts that show up covering this in great detail. Quick n generic, its free, its easy, the jailbreak itself does nothing to your device, what it does is gives u cydia, a non apple controlled app store (so much more than "apps") and allows you to literally change,tweak, add features and usability that i have been missing since the day the i5 came out, im now right back where i was w the i4S and sooo happy
Untethered jailbreaks do not require a computer. Everything required to enter the jailbroken state is contained on the iPhone.
See more: Six Disadvantages of Jailbreak Released by Apple
ericerjames is offline   Reply With Quote
Old 11-26-2013, 01:34 AM   #68
#944_10_Series_FRS
#944_10_Series_FRS's Avatar
Drives: 2013 10 series FRS #944
Seriously? This is your 1st post and your reply/bring back a 10 month old post?
#944_10_Series_FRS is offline   Reply With Quote
iPad Mini dash kit for FT86 Esoteric Electronics | Audio | NAV | Infotainment 92 08-04-2014 07:54 PM
iPad mini - now a possible replacement for the stereo. kappaknight Electronics | Audio | NAV | Infotainment 32 02-11-2013 11:59 PM
Anyone have an iPad mini rmjjensen Electronics | Audio | NAV | Infotainment 14 01-08-2013 04:42 PM
Iphone/Ipod USB Connection russv Electronics | Audio | NAV | Infotainment 3 07-31-2012 10:07 AM
iPod/iPhone connectivity? Tomcat9700 Scion FR-S / Toyota 86 GT86 General Forum 9 01-08-2012 06:45 PM
