#57 |
That's a clever solution. That being said, if you ever decided to remove that hook you'll never get that bar back out again.
#58 |
Drives: 2013 MT FR-S Asphalt
OP, stupid question- did you use the square brackets or just screw directly into the sheet metal?
#59 |
Drives: 13 Firestorm FR-S
screwed right into the sheet metal. even if you change your mind in the future, you'll never see the holes up there. Well. . unless you're locked in the trunk, bit then you've got bigger problems :P
-Rich H.
Current: 16 Porsche Cayman, 09 Tacoma 4WD, 13 Highlander 4WD, 12 Yamaha WR250R
Past: 13 10-Series FR-S, 13 FR-S, 11 S4, 07 Corolla, 98 Tacoma 4WD, 03 Corolla, 89 Camry, 90 Celica GT-S, 87 Celica GT-S |
#60 |
Drives: Scion FRS A/T raven
back in the days, we just used modified clothing hangers. works like a charm!
#61 |
Drives: '13 FR-S Ultramarine manual
I put mine up this weekend - used zip ties - needed not just the ones through the holes but also one to keep the bracket located. While I was in there, I added one to hold the 3rd brake light wire up against the frame - was hanging down an inch - zip ties are cheap...
'13 FR-S - Ultramarine manual
(GONE) '98.5 Contour SVT - modded (and threw rod with buyer) '01 Camry 5S-FE (wife's old car) '11 Odyssey EX-L - familymobile and hauler - food-encrusted carpets and other appropriate features |
#62 |
Drives: Subaru BRZ 2014 Limited WRB
I tried the zip tie method, but found this location is too visible for my liking; I didn't notice that the OP actually mounted his farther into the trunk, and I think that's a better location.
Plus, I do have one of those organizer type "boxes" that I keep in the trunk, so I'd prefer to have the organizer on one side, and the hook mounted on the other. So I guess I'll be drilling through the sheet metal. Hey OP, you said you went straight into the sheet metal? Did you pre-drill or use self-tapping sheet metal screws? Any advice on screw size? -Z |
#63 | |
I don't take drilling lightly, I just believe it to be the "right" way to mount something like this. I probably spent 20 mins laying on my back in there surveying the location and making ONE-HUNDRED PERCENT sure it was safe to drill in that spot. -Rich H.
| The Following User Says Thank You to NetMagi For This Useful Post: | zinzan (02-26-2014) |
| Tags |
| bag, grocery, hook, luggage, trunk |
| Stock Nav swap from BRZ to FR-S & Five Axis trunk spoiler install on BRZ trunk? | 07stealth350z | DIY (Do-It-Yourself) Guides | 8 | 08-27-2020 04:27 PM |
| WTB/WTT : black brz trunk spoiler or trunk swap | ph0en1xtk | Exterior Parts (Aero, Lighting, Etc.) | 1 | 03-19-2013 12:03 PM |
| WTT: My WR blue spoiler/trunk for your trunk (SoCal) | itisthumper | Exterior Parts (Aero, Lighting, Etc.) | 0 | 10-23-2012 04:27 PM |
| WTT: DGM BRZ Limited trunk w/ spoiler for wingless DGM trunk | No Limit Motorsport | Exterior Parts (Aero, Lighting, Etc.) | 5 | 10-03-2012 10:03 PM |
| WTT: DGM BRZ Limited trunk w/ spoiler for wingless DGM trunk | No Limit Motorsport | NY / NJ / CT / PA | 6 | 09-27-2012 11:14 AM |
