Old 03-28-2015, 03:18 AM   #57
king83c10
king83c10's Avatar
Drives: 2013 FRS
With coil overs you should be good. I am running the 18x8.5 in the front on the eibach prokit and have about 3mm between the tire and spring. That's with a 225/40, coil overs have smaller diameter springs so you should have a lot more room to play with. There are people running the 18x9.5 up front on coil overs and they are clearing the springs.
2013 Scion FRS::Revworks uel header::Motiv front pipe::Motiv over pipe::Invidia N1::Perrin CAI::Eibach prokit::Enkie Raijin wheels::30% tint::OFT stg2uel::TWM performance M1 Abrams shift knob::Winjet black headlights::8000k OLM HID Kit::Muteki SR48 Lug Nuts
king83c10 is offline   Reply With Quote
Old 03-28-2015, 11:21 PM   #58
Jamesbrz
Drives: White BRZ
What size tyre seems to be the best fit with no stretch on 8.5 inch?
Jamesbrz is offline   Reply With Quote
Old 02-24-2016, 12:41 AM   #59
mathcore.zt
mathcore.zt's Avatar
Drives: 2015 Limited BRZ
Just put the raijins on today and i love them. Was going to go with gunmetal but decided on the hyper silver last minute.
mathcore.zt is offline   Reply With Quote
Old 03-11-2016, 12:02 AM   #60
bhbnuckle
bhbnuckle's Avatar
Drives: 2013 Asphalt FR-S/2003 Honda Accord
Im just wondering if 18x8.5 +45 with 225/40/18 bridgestone potenza will rub in the front.
Im running eibach prokit
bhbnuckle is offline   Reply With Quote
Old 03-13-2016, 06:21 PM   #61
PMok
Codename: Stitch
PMok's Avatar
I had same setup (see above), no rubbing but will depend in part on your camber.
Old 11-28-2016, 03:25 PM   #62
ragequitfail
Drives: 2015 FR-S
How much camber did you have with no rubbing issues?
I will have the same setup as you with 18x8.5 +45 but I have the eibach sportline instead of the pro.
ragequitfail is offline   Reply With Quote
Old 11-28-2016, 03:51 PM   #63
PMok
Codename: Stitch
PMok's Avatar
I had about -1.5 degree on the front.
I eventually went to Tein coilovers and had -3 degrees each side.
#becauseracecar
Wheel Directory: Enkei RSF5 18x8.0 +45 ericmpena Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 85 06-18-2022 04:07 PM
Wheel Directory: Enkei Raijin 18x8.5 +45 / 18x9.5 +45 GuerillaRacing Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 221 08-01-2019 10:30 AM
Wheel Directory: Enkei RS05RR 18x8.5 +42 dabocx Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 206 03-02-2018 05:23 AM
Wheel Directory: Enkei NT03+M 18x8.0 +35 Tunz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 45 06-16-2016 11:31 PM
Wheel Directory: Enkei Tenjin 18x8.5 +45/18x9.5 +45 Sciby Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 11-10-2014 12:53 AM
