| Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) Wash, Wax, Details, Repairs |
#57 | |
#58 |
Drives: 2JZ FRS
It can be sanded/scuffed with 800 grit and a grey scuff pad, more pearl mid coat added then cleared. The base color doesn't have to be sprayed again
#59 |
Drives: DGM BRZ
Thought I'd chime in to let others know it's not just Whiteout paint owners. The whole color lineup has these problems from the factory. As someone else previously mentioned, it's the differences between surfaces. If you'll notice, the front bumper and rear bumper are different colors than say the fenders, hood, and trunk. I'm speculating because the black color of the ABS plastic possibly?
In either case, whatever body shop you take it to make sure of course they're reputable and do great work but also that they confirm the color code via your VIN#. Case in point for my DGM (which IMHO is much harder to match than Whiteout) has several different blends from factory according to the paint supply store. Some VIN#'s call for more blue, green, etc. so that will have an effect on the overall color hue. In my example, the first paint run (without using the VIN#) the part came out with a very noticeable green hue (when it was supposed to be more purple). The second run, again without using VIN# info, came out with a blue hue. Finally, my body shop friend talked it over with the paint supply store and provided my VIN#. We discovered my VIN# had indeed more purple color added to the mix. |
#60 |
Drives: 2JZ FRS
The vin isn't the best way to match up a color. In some systems entering a vin will show you the most popular choice chosen for that model by other body shops using the same mixing system but that's about it. Every paint system has variant decks which contain the available variants for every paint code that has variants. Enter the paint code in your mixing computer, take out the variant deck that the computer calls for, match up the variants to the car in question with a 3m sun gun or clear daylight. If nothing is close enough to blend out then its time to start tinting and spraying test cards
| Tags |
| bumper, color match, good body shop, new bumper |
| White out paint match ?? | xpicer | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 9 | 10-11-2012 12:04 PM |
| Son of a @#$*&!!! I found out my dealer drilled holes on the front bumper | RYU | Scion FR-S / Toyota 86 GT86 General Forum | 40 | 09-12-2012 07:23 AM |
| Front license plate: Why you don't want the dealer to drill your bumper | CircuitJerk | Issues | Warranty | Recalls / TSB | 53 | 08-27-2012 02:02 AM |
| weak paint on bumper | 1strwdcar | Cosmetic Modification (Interior/Exterior/Lighting) | 6 | 08-15-2012 09:19 PM |
| Bumper Plugs for License Plate holes by dealer? | mikeg7827 | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 6 | 08-13-2012 05:33 PM |
